40" RCA L40FHD41 No Picture + No Audio
Re: 40" RCA L40FHD41 No Picture + No Audio
i would touch up the solder on the cap above rs9, could ark over on that cap.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
When i was desoldering the original cap above rs9 my iron was too hot and removed the copper plating on that part of the board.
I tried scraping the board to reveal more copper underneath (saw on internet) so i could have something to solder to but made a hole there.
I tried to bridge that solder joint to what looks like a tiny transitor (followed the circuit path) - is that right?
It didn't work so i desoldered that bridge and tried to solder the cap regularly while missing the copper plating on one of the joints...
Any idea on what i can do about that ?Comment
soldering to the next component is fine.
it just looks like there is too much solder. i would remove it, bend the legs out slightly and resolder. while your at it, j12 looks to have a bad solder joint on it.
after that is done, it will be time to look at the output voltages that go to the main board.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Ok so i must have removed the short because the ticking sound coming from the power board has stopped, tv screen will turn on but still shuts off
Left side is black, right side is red now (not blue like originally)
I think by transistor i meant resistor...
On to measurements?Comment
Update:
I have since cleaned all cables on the back of the TV, now i have audio from the TV,
there's a button on the main board that seems to reset the board and resets tv to HDMI 1 (possibly by default) - laptop connected = audio!
When i first power on TV, it shows me yellow and red bars with left half of screen black, then syncs to input from laptop, plays audio and fortunately still i can see picture if i hold up flashlight to tv.
Between those red and yellow bars, half of the screen being black and then shutting off (the screen isn't really shut off) - it seems as though the backlights aren't working maybe?Comment
Update #2:
I wanted to show you guys the work I did on one of the capacitors, the one above rs9 and how i have it soldered to the next component (resistor ?) - is this okay?
I know its utter shitty work, it was my first one i did and the rest came out better, i messed stuff up and this was/is my improvised workaround.
(solder flux shite everywhere)
I would have bend the lead over to that large unused pad instead. I cannot tell how good the solder works i to the end of that SMD cap in the picture.
BTW, why the solders works look so dark instead of shiny? Even the leg of the cap looks dark.Last edited by budm; 05-26-2017, 01:45 PM.Never stop learning
I really don't know why it's so crappy looking, i lowered the heat on my iron, maybe it's too hot still?
Flux residue resides alot, i tried cleaning with alcohol and small brushes
I will remove that solder and try the pad insteadComment
I seem to remember when i first got the TV i could plug it into the wall and the TV would wait for you to press power to power it on...
Since i've changed all the capacitors, as soon as i plug into the wall outlet, the TV powers on...?Comment
since there was some initial pad damage i would check for continuity between the pins on those pads, just to make sure.
you said that you are getting a flash of picture. any chance of a pic. while it is plugged into the laptop, are you getting audio but no pic, or is the pic showing up?WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Continuity between the pins on what pad?
I'm not getting any picture per say, rather, when the TV powers on half of the screen is backlit and red, the other side is black. This lasts for a second or two until the whole screen goes dark.
With the laptop being hooked up i am getting exact same results, except i am getting audio from TV (HDMI via laptop)
No picture, but audio existsComment
Here is what it looks like now before and after with the capacitor now soldered to the pad to the right; I did remove the solder connection from the SMD chip beneath and now instead am soldered to that pad that Budm mentioned above
Where should i check continuity?Last edited by ajsterr4; 05-26-2017, 06:43 PM.Comment
that looks heaps better.
just check across the cap. if there was any stray trace, it would show low ohms.
on the ps, the connector that goes to the main board, we need to know the voltage on each pin in standbyand when powered on. use the chassis for ground.
eg.
pin no, pcb marking, stby v, power,on v.
1 12v 0.00v 11.90v
2 ps on 0.09v 4.96v
etc.
it has 2 rows of pins, so you will need to test it where the cable goes into the connector.WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?Comment
Can we see the screen shot of what you are seeing on the screen? At this point I do not believe you are having power supply problem since the backlights are on and based on what you describe what you are seeing on the screen.Never stop learning
edit
The black on the left side is not an error in the photo, the left side of the screen is faded black as such BUT when i connect HDMI to it and hold a flashlight to the (dark) screen, i can see the whole image is being shown throughout the entire screen.Last edited by ajsterr4; 05-26-2017, 08:16 PM.Comment
OK, so backlights do not stay on.Never stop learning
The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
The player processes the audio signal using two different reference frequencies. The "R"...2 Photos -
by jason123Hello folks,
New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...-
by myth77So, laptop was with dead cpu, replaced. Now everything works except i have problems with audio. The problem is related with long audio cable that from one side is plugged in the motherboard and on the other side is connected to audio daughter board that goes on the top of the laptop(behind screen). The symptoms are:
1. In bios everything ok (with long audio cable on connector j3701 connected or not),
2. With windows installed everything ok if long audio cable on connector j3701 is not connected,
3. With windows installed and long audio cable on connector j3701 is connected... -
by ItepKHello everyone! I've found this television, and I began troubleshooting it.
First, the television kept rapidly power cycling. I've warmed up the capacitors with a hairdryer, and after 3 dimmed red blinks, the backlight turned on, then turned dim, and no picture was present on the screen.
I believed that this was caused by a bad power supply producing insufficent power (I've measured 3.5v on the 5.2v rail), so I've blindly recapped the board.
After the recapping, all the voltages stableized, however, the issue in the title still remains.
I could... -
by burbutsalosHello ,
The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
Any ideas what to check?... - Loading...
