asus g752vs strange problem
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, laptop was with dead cpu, replaced. Now everything works except i have problems with audio. The problem is related with long audio cable that from one side is plugged in the motherboard and on the other side is connected to audio daughter board that goes on the top of the laptop(behind screen). The symptoms are:
    1. In bios everything ok (with long audio cable on connector j3701 connected or not),
    2. With windows installed everything ok if long audio cable on connector j3701 is not connected,
    3. With windows installed and long audio cable on connector j3701 is connected i will have symptoms of loading windows then freezes everything, or only asus logo with slow turning wheel. So basically if audio cable connected the board is not working.
    5. if its not connected then everything is fine and i can play games...and so on.
    What i did so far: checked capacitors for short, replaced ALC668, replaced u3701 and u3901 audio amp chips, replaced all ferrite bead in that area (even though they were good). Checked j3701 connector for shorts but everything is ok. Ordered another long audio cable on connector j3701 but same, ordered another audio daughter board but the same.
    When i measure heat in that area when long audio cable is connected, it is very hot...it goes to 55 C. The most heated area is around ferrite bead and audio amp chips.
    And the funniest part is if I stretch the long audio cable the windows will load normally and if i connect the audio daughter board at the end the sound is fine. But the moment i release audio cable in normal state (not stretched) the symptoms start again. Thats why i bought the second audio cable but symptoms are the same.
    I dont understand what is happening...i can make video of this really weird problem...anybody have any idea?
    schematic link: https://www.badcaps.net/forum/showth...hlight=g752vsk
  • mon2
    • 14634
    Re: asus g752vs strange problem
    Connect the audio fpc cable. Disconnect the audio board that is on the other side of the cable.
    Does the ic still heat up?
    Post pics of this cable so we can review the pin pitch. Be sure that pin #1 on the cable mates to pin #1 on the audio board.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      yes
      everything is matching...i will try to make video later..
      • mon2
        • 14634
        If you remove this floating cable, the ic will not heat up?
        If true, the cable contacts are of the wrong pitch for this connector.
        Post pics of the contacts and place it beside the connector on the logic board.
        The contacts on the cable must be shorting the audio outputs.
        • myth77
          • Feb 2017
          • 380
          • Croatia
          ok, i posted video on yotube... link https://youtu.be/TuwsnvpFhTQ
          As you can see from the first part when audio cable not connected the laptop is working fine.
          When i connect it, it will not boot and commonly it will freeze.
          When i connect it and strach cable it will work and i can even have sound on it!?
          Can someone explain what is this weird shee. going on...never seen anything like it.
          I posted here a picture of the connector, so you can see it is ok. On the first i also suspected a bad audio cable but i ordered new, but same problem. There is no short between pins.
          • mon2
            • 14634
            Have a thought that you switching power supplies nearby. This coiled up wire is acting like an inductor and the switching energy is being transferred back to the audio circuit. When you stretch the wire, the coil is effectively broken and no longer acts like an inductor.
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
              ASUS ROG G752VS(KBL)-GB367T Notebook Specification for Upgrade or Repair
              This specification for the ASUS ROG G752VS(KBL)-GB367T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G752VS(KBL)-GB367T boardview and G752VS(KBL)-GB367T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 08:00 AM
              ASUS ROG G752VS-XB72K-HID9 Notebook Specification for Upgrade or Repair
              This specification for the ASUS ROG G752VS-XB72K-HID9 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G752VS-XB72K-HID9 boardview and G752VS-XB72K-HID9 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-06-2024, 06:08 AM
            • Featurea
              Macbook air a1932 not working with audio board connected
              by Featurea
              I have macbook air a1932 2018 and it has water damage. Audio connector on motherboard was burned on PPBUS_G3H signal. Without this audio board laptop is working perfectly fine, but of course without sound and touch ID. I changed burned connector, flex cable and audio board. But connecting this all, Mac is not starting, nothing on thermal camera... Do you know what other can be damaged on this signal what can cause this behaviour? Nothing on motherboard looks burned...
              05-25-2022, 07:59 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
