Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
  • jason123
    • Oct 2015
    • 1097
    Hello folks,
    New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port, it turns active), but no display. This has 3 Output HDMIs, and they all act the same. I connect Ethernet cable to it, and my TV sees it in input options. Seems to do a FW upgrade without picture on TV is impossible?
    So it kind of functional, but not quite. Any ideas where to start even? I cleaned the Digital board. I don't see pin labels to check power levels and so on.
    Any help is appreciated.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8340
    … unless the memory is empty and all channels went back to default. Get out of the memory and back into the tuner mode then try changing the VFO frequency by pressing up or down button.
    Here is a service manual with repair charts, block diagrams and schematics.
    • jason123
      • Oct 2015
      • 1097
      Thank you. I can't get into the GUI with this receiver. I select input as FM tuner and the only 2 bottons are Tuner +/-. Not sure how to get out memory mode
      • lotas
        • Jan 2016
        • 4787
        • Russia
        Try a reset.
        • jason123
          • Oct 2015
          • 1097
          Thank you.. I attempted that multiple times. If only I can get the GUI on the screen, I think a FW update "Could" fix this.. Alas, it's not displaying anything on screen, and not even passing HDMI devices through HDMI ports.
          • jason123
            • Oct 2015
            • 1097
            I hate to dump this receiver, as the amplifier / main board is good, front panel is ok, and overall the receiver is in decent shape. Free for the taking
            • Nevillet
              Sony HiFi Tuner loosing saved stations
              by Nevillet
              Hi All,
              I have a 20+ year old Sony ST-S320 tuner that 'forgets' saved staions from memory. When I opened the case I was hoping to find a battery that could be replaced - but none was present.
              I've attached the service manual. Can anyone point to where I should be looking to fix this problem?
              Many thanks.
              https://www.badcaps.net/forum/attach...1&d=1635359677...
              10-27-2021, 12:35 PM
            • sretchko
              Sony Receiver STR-4800SD L/R Balance
              by sretchko
              Hey fellow solder fume lovers, I have a Vintage Sony Receiver STR-4800 SD that has me stumped.
              The Balance Pot has to be set at about 30 degrees (11 o'clock) to the left for the output to be balanced (see photo). I'm using an oscope, sig gen 1kHz sine, 8 ohm dummy load).
              When output is balanced (11 o'clock left) both channels clip at about 19 vac / 45 watts RMS, Amp is rated at 35 watts so I know the amp modules are good. Square wave also looks good when turning bass & treble pots and is in phase.
              I pulled the balance pot, (Dual 10K MN Taper) cleaned with...
              Badcaps Electronics Repair Forum & Schematic Search
              04-17-2024, 06:02 AM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • erickeri1234
              Sony str-dn850 home receiver no left channel.
              by erickeri1234
              Ok start off by saying I have some tv repair but not much on the receiver end.
              Picked up a Sony str-dn850 home receiver when I first plugged it in powered it up it came on and the system check relay clicked and about 3 seconds later it went into protection mode.
              I powered it off and on. Comes on no problem.
              Hooked up speakers and it started to pop and crackle but the volume was all the way down.. and I was only getting that sound out of the left channel. Right channel had no sound.. but every time I turn the volume up it has a smell crackling sound on ever volume number......
              10-04-2021, 07:45 PM
            • dkneyle
              Sony KDL-46HX850 Can't upgrade/update firmware
              by dkneyle
              Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
              Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
              09-25-2024, 10:44 PM
