55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
  • burbutsalos
    • Jun 2022
    • 15
    • Greece
    Hello ,
    The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
    If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
    Any ideas what to check?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4367
    • Italy - Milan
    I would have said bad mainboard (processor soldering), are you sure 100% about the repl. mainboard? If it's ok is probably something on the stripe boards on the panel..
    • Diah
      • Feb 2013
      • 6399
      wrong.. the new style blind my eyes... QLED i read it OLED LOL
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4367
        • Italy - Milan
        IN-Stop on a Samsung.. very well.. VERY WELL...
        • EazyBone
          • Jun 2023
          • 1350
          • United states
          You know you can change it to dark mode now right?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4367
            • Italy - Milan
            Thanks EB..
            I feel like saying, there are no longer the good sites of the past!
            • burbutsalos
              • Jun 2022
              • 15
              • Greece
              Yes the mainboard is from a completely identical set with broken screen (same panel type same mainboard type ). I did some tests on the panel pcb,s realized that some set of capacitors (2 on each cof ) short after some time.
              When you turn on the tv all is ok.
              After the 1 minute time those caps start to beep (short) the display goes bad and the boot loop starts with the same symptoms only this time since something has warmed up the loop happens within a few seconds and not a minute as the first rime when the set is cold
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4367
                • Italy - Milan
                to clarify you put the DMM in continuity mode across a capacitor and after some time of tv ON the DMM beeps?
                • burbutsalos
                  • Jun 2022
                  • 15
                  • Greece
                  actually yes !! But i managed to do some more tests and it gets even more confusing !!!! I tried the testing points on the pcb boards .
                  What i get makes no sense to me at least. Testing for shorts on diode mode ido not get a complete shorting beeping sound from my multimeter but rather something like a pulse sound this happens when i test vss with all the ck 's 1-8 stv with all ck's vss with stv .
                  And the clocks amongst them also.
                  The tv stays on on this status with only a very fade black horizontal line in the middle of the screen .from the right side of the panel gradually fading to normal picture.to the left side
                  This line also seems to be vanishing every 2 seconds aprox. On a certain point the screen goes half black and freezes and at that time the capacitors seem short and the set reboots.(the ones with the arrows ..the same pair in all cofs sound short)
                  Now for the craziest part !! I managed to decrease contrast and brightness and also changed the tv screen settings from dynamic to typical which is less bright. The tv stays on practically forever !! As soon as i revert to the more bright settings the issue appears again. !!
                  I did not changed any backlight setting. During the time that the tv stays on with the lowered settings i can still get the <<semi-short>> sounds from the testing points...
                  Is there any logic in all of this ?????
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    The tests you made are confuse and out of technique, what you have to do is to unsolder one by one the protection diodes in photo T1-Tx.. and after each one test the tv.. already seen this defect..
                    • burbutsalos
                      • Jun 2022
                      • 15
                      • Greece
                      Thank you Davi.p . What you say is to desolder one after the other to see if the tv stays on in the end? You say you have seen this defect is it caused by baδ diodes?
                      Also since i have the same broken panel if fthat is the problem should i try to use diodes from the broken panel f they are the same?
                      • nomoresonys
                        • 12206
                        • U.S.
                        Just test those caps in ohm mode, what do you get?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4367
                          • Italy - Milan
                          burbutsalos, YES to all questions.. pay attention to the polarity.. T stays for TVS diode.. (Trans Voltage Suppressor?) them goes short or leakage after surge.. NEVER touch the border of a TV with naked hands or discharge them before..
                          • burbutsalos
                            • Jun 2022
                            • 15
                            • Greece
                            nomoresonys when they short they all show about 16 ohms.
                            Davi.p .. I tried desoldering one by one the diodes you sujjested . unfortunatelly no luck. Now it is on a boot lloop . If a mask with tape somethinh from the riight pcd i might just get steady backlight and sound but no pictrue. Iwill try to resolder then but itseems very difficult to do.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4367
                              • Italy - Milan
                              i told you desolder one by one and test after each
                              • Takeatry
                                Yet another Samsung QLED Boot Loop
                                by Takeatry
                                Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                10-04-2024, 02:57 PM
                              • NolesFan
                                Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                by NolesFan
                                Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                10-24-2024, 06:36 PM
                              • blaster_
                                Samsung UE49MU6105K - boot loop, horizontal lines
                                by blaster_
                                Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                06-22-2022, 05:19 PM
                              • torchzack
                                Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                by torchzack
                                Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                08-28-2023, 07:42 AM
                              • No Lan
                                [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                by No Lan
                                Hey everyone,
                                Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                05-24-2025, 03:09 PM
