Philips 47PFL7403D/10
  • vazaki
    • Jan 2017
    • 21
    • Greece
    Hi there to all!!
    New to forum, first post but watching it several months silenlty.
    I need your advice:
    power supplyQ PLHC-T801A (UD)
    No response while connected to wall plug.
    I figured out that R5 is burnt. I have changed it with a new one and now when plugged in a relay is clicking all the time.
    No led blinking.
    After a minute the R5 is broke down again and everything dead.
    All caps esr measured and they are very good.
    Any advice for this issues?
    Is it truly the problem from the PSU or maybe the mainboard?
    Thanks a lot
    Nodas
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Philips 47PFL7403D/10
    You need to change u101. It is a 7 leg ic chip that is through hole soldered in.
    Put a new 120 ohm resistor in r5 and put the correct fuse back in around that r5. Also, check the solder connections under the power board, the ones under the transformers tend to burn and start on fire. Touch up all the through hole componnets with fresh solder.
    • R_J
      • 9535
      opps, wrong power supply
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Post some pics of the power board. Take one of u101, you may see a hole in the side of it, or a blown off leg.
        • vazaki
          • Jan 2017
          • 21
          • Greece
          Timmy thank you very much for your response and help.
          I have changed already:
          > U101
          > D101A,D101B,D101C,D101D
          > PC201,PC101,PC102
          The result was that relay clicking and after a little the R5 burnt again. The fuse I have changed once did not blow again.
          The solder joins are in very good condition.
          Also I have tested D106A and it seems open. the diode writes T2d 83 on it.
          do you jnow anything about this?
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            What is the mark on top of the 8 pin IC. Picture too small to read component names.
            • ducky29
              • Dec 2015
              • 370
              • Europe
              Check zd 101 and zd 103 on the back of the power supply
              • vazaki
                • Jan 2017
                • 21
                • Greece
                Oh man!!
                You are tottaly right!
                After the replacement U101 is broke down again. The spot show that ic is fried.
                • vazaki
                  • Jan 2017
                  • 21
                  • Greece
                  Zd101 tested with multimeter seems fine but
                  Zd103 shows the same value both sides with multimeter but I see that it is in parallel with an smd capacitor.
                  Do I have to desolder it to check it again?
                  Should I check with external voltage?
                  Do you know the value of the zener diode?
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    Originally posted by vazaki
                    Oh man!!
                    That's the beauty of posting photo's.
                    • ducky29
                      • Dec 2015
                      • 370
                      • Europe
                      zd101 tested with multimeter seems fine but
                      zd103 shows the same value both sides with multimeter but i see that it is in parallel with an smd capacitor.
                      Do i have to desolder it to check it again?
                      Should i check with external voltage?
                      zd101 5.6
                      zd103 18
                      • vazaki
                        • Jan 2017
                        • 21
                        • Greece
                        Thank you very much!!
                        I desolder U101 and measured again ZD101 & ZD103 with multimeter and they seem fine. Do I have to desolder them and check them again?
                        • ducky29
                          • Dec 2015
                          • 370
                          • Europe
                          No its fine
                          • vazaki
                            • Jan 2017
                            • 21
                            • Greece
                            Any other suggestions?
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              What is the part # of U101
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4326
                                • Italy - Milan
                                if you want to be helped, you can post very clear pictures of te board or even the faulty portion, both sides, with traces well distinguishable, and put marks on them to show parts changed and parts found blown.. one can have no wants to find and download schematic..
                                • tvtimmy
                                  • Mar 2015
                                  • 1160
                                  • usa
                                  U101 is FSQ510. Lots of them on ebay.
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    So it looks like output of U101 bad. What is causing failure? Transformer shorted?
                                    https://cdn.badcaps-static.com/pdfs/...f3dad871c4.pdf
                                    • vazaki
                                      • Jan 2017
                                      • 21
                                      • Greece
                                      Here are the photos!
                                      The parts that have been replaced:
                                      > R5
                                      > D101A
                                      > D101B
                                      > D101C
                                      > D101D
                                      > PC101, 102, 201
                                      Also I need your help about T2D 83 diode. I measure it with the classic way but it seems open. Is it a special type of diode?
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        R5 does not look good. Best that you check its resistance.
                                        • zen
                                          GC9660 Philips iron advice please
                                          by zen
                                          Full model GC9660/36/BI
                                          Hi all, this iron intermittently not producing steam.
                                          Anyone have experience working on them?...
                                          11-07-2022, 04:32 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
                                        • spantor
                                          Activate power board Philips 40PFH40009/88 tv
                                          by spantor
                                          Hello partners.
                                          Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                          The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                          02-11-2024, 05:07 PM
                                        • tuner2000i
                                          Philips 65PUS8518/12 distorted image after main board replacement
                                          by tuner2000i
                                          hello everyone,
                                          I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                                          The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                                          07-15-2025, 01:15 PM
