Sony shorted screen,fixed
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Hi,thought I would post this in the hope it can save some tv's.
    Sony KDL-42ex440,completely dead,no reaction on buttons etc,as if main fuse is blown.
    Disconnected LVDS cable to t-con,tv comes alive,no picture of course.
    Reconnect LVDS,disconnect one of two ribbons to panel,tv comes alive with halve screen,other side white.
    Reconnect that ribbon,disconnect the other ribbon,tv completely dead again.
    Looked at small PCB that's attached to panel along the edge,found that the 3 larger capacitors(one by each tab) measured 2.6 ohms.Suspected them to be in parallel.
    Removed the capacitor closest to the ribbon cable connector,short gone and tv works perfectly fine again.
    Hope this will help somebody
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    Re: Sony shorted screen,fixed
    Nice work locating bad cap.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Lol,super easy to find. I posted this more for awareness,as in "don't give up on panel too soon"
      I fixed a few this way,some samsungs etc. Never had luck on LG with this.
      It would probably be a good idea to replace that cap,so far I just remove them,never had one come back yet.
      • syaoran123
        • Jun 2014
        • 178
        Thanks for sharing. Were there any visual signs of damage? What models have u tried this on?
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          Can't remember the models,it's wide spread.
          When in diagnosing I get halve screen results,I then measure all caps on those narrow boards. Been lucky with this often enough to make it an effort
          No signs of damage to caps,they just measure very low ohms.
          • mmartell
            • Oct 2013
            • 3189
            Nice save and thanks for posting it.
              BTW, the failure mode for those MLCC is shorts or bad leakage resistance.
              • ivtec
                • Dec 2008
                • 1967
                Thanks Martino good job, that's why i say Badcaps forum is the best Forum ever.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Nice work buddy, I recently had a 32" Sammy panel shorted ceramic and smd transistor changed with ones off a smashed screen (same model) and sorted it seems to be newer sets having his issue. Done a vid on it.
                  • CapLeaker
                    Leaking Member
                    • 8176
                    good detective work!
                    • supravit2000
                      Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
                      by supravit2000
                      Hi!
                      A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
                      So I reassembled the PS5 and pressed the power...
                      07-20-2024, 07:26 AM
                    • reessi
                      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                      by reessi
                      Hello:
                      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                      I started on the ACER:
                      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                      10-29-2024, 11:31 AM
                    • Carlos#2003%
                      Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                      by Carlos#2003%
                      Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                      02-15-2024, 07:52 PM
                    • Yanleb
                      Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                      by Yanleb
                      Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                      I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                      D608, good
                      D618 RF101L4S, good (See warning 1 below)
                      D619 RF101L4S, good (See warning 1 below)
                      D865 RF101L4S, shorted (See warning 1 below)
                      IC464 Inverter HA MC74HC1G14, shorted...
                      03-09-2020, 12:00 AM
                    • modtool
                      HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                      by modtool
                      Hi to all,
                      the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                      I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                      I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                      04-01-2025, 08:22 AM
