Sony PS4 ADP400DR - help needed figuring out shorted pads under capacitor C 31
  • supravit2000
    • Aug 2021
    • 11
    • bulgaria
    Hi!
    A friend of mine gave me a dead PS5 to look at. I am totally inexperienced, but when a damage is simple (i.e. failed DAP41 on PS4s, etc.), when replacing just the IC and the other very common failing parts of these consoles, problem is fixed. So I checked the voltage of the PSU - none was present. Model is ADP 400DR. I have a bunch of spare parts around, so first thing I did was to replace the IC DAP 053 (they seem quite expensive, so I put a replacement unit - TEA2016AAT. When plugged to the power outlet, 12V did come present.
    So I reassembled the PS5 and pressed the power button... to see that it was still dead. I reopened the PSU again and found out that the 12V output was gone again and the ic TEA2016AAT​ was fried (it was getting hot). After watching some youtube clips for potential solution, I tried changing couple of FET's (Q31, Q34) and so on.. but what bothers me is that the cap labelled C31 always has BOTH pads shorted to ground... I took out so many parts out trying to find the reason for that short, but just can't find it. The diodes read fine, resistors look good (I have a list to look at), no other caps are shorted... If somebody has had similar experience, I will be very happy if you help me with some clues. I attach a pic with red circle of the common ground, that cap pads, the ground of the is DAP053 and also a Gate of mosfet 10N60M2 that goes to ground...
    Thanks!!
  • gcrezz
    GameConsoleRezz
    • Jul 2024
    • 14
    It sounds like the PSU might be ok and it's going into protection mode due to a fault on the motherboard itself. Have you tried looking at the board itself yet?
    • Puuhis79
      • Nov 2020
      • 27
      • Finland
      Can you test psu with dc-load, psu is rated more than 30A could it be something to do with inc of load…
      • supravit2000
        • Aug 2021
        • 11
        • bulgaria
        Dear folks, don't bother on that issue - the console was sold long ago for spare parts. I removed literally all the caps, resistors and ic's on the board - and the short was still there. Somebody with proper knowledge could make use of it, I couldn't. Thanks anyway!!!
        • reessi
          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
          by reessi
          Hello:
          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
          I started on the ACER:
          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
          10-29-2024, 11:31 AM
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • bogosort
          iPhone 13 mini not booting, shorted test pads
          by bogosort
          I am trying to diagnose an iPhone 13 Mini that does not boot. (Amp meter shows a couple milli amps then goes to zero, looping).
          Here are some measurements I took :
          Is it worth trying to repair this?
          Thank you...
          09-22-2024, 11:11 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
