Eeprom dump thread!
This is a sticky topic.
Good morning . I am really sorry is Ves500qndp-2d-n42 exactly .Any help please , i have problem with the bios . As it says memory running out and need to reset Tv goes on and off
ThanksComment
https://drive.google.com/file/d/18X5...nclLW870i/viewComment
Here is a working dump of eMMC (Samsung) on ​​Sony KD-55XG8596 1-983-791-12.
Good morning, I come once again to ask for help to resolve the situation with this TV that needs to update the firmware, if anyone could send help I would appreciate it
THOMSON 55UA6406W MOTHER BOARD 40-NT67ES-MAC4HG SOFTWARE:V8-NT67F01-LF1V378
THANK YOUComment
I'm looking for a dump for the LG PF1000U projector (chassis FM51E), (NAND Hynix H27U1G8F2CTR SPI_FLASH: MX25L8035EM2I, EPROM 24C256C).
There is no epk file available anywhere
This device attempts to turn on and responds to both buttons and the remote control:
It exits standby, runs the fans for 5 seconds, then spins them at 100% for another 5 seconds judging by the sound, and then goes back into standby.
The problem seems to be a corrupted NAND as it appears to me:
[ 0.110000] NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3.3V 8-bit)
[ 0.110000] redirect_size = 400000, redirect_start = 7c00000
[ 0.110000] Loading nand bad block info(00000000+00020000)...
[ 0.119000] Mstar nand-flash partition definition
[ 0.119000] mtd info: # of partitions = 23
[ 0.119000] Creating 23 MTD partitions on "NAND 128MiB 3.3V 8-bit":
[ 0.119000] 0x00000000-0x00020000: "bbminfo"
[ 0.120000] 0x00040000-0x00060000: "mtdinfo"
[ 0.121000] 0x00160000-0x00760000: "rootfs"
[ 0.121000] 0x00760000-0x007c0000: "lginit"
[ 0.122000] 0x007c0000-0x007e0000: "crc32info"
[ 0.123000] 0x007e0000-0x00800000: "model"
[ 0.124000] 0x00800000-0x00900000: "logo"
[ 0.124000] 0x00900000-0x00a00000: "cmndata"
[ 0.125000] 0x00a00000-0x01200000: "nvram"
[ 0.126000] 0x01200000-0x01300000: "user"
[ 0.127000] 0x01300000-0x01400000: "ezcal"
[ 0.128000] 0x01400000-0x014a0000: "estream"
[ 0.128000] 0x014a0000-0x01620000: "opsrclib"
[ 0.129000] 0x01620000-0x018a0000: "kernel"
[ 0.130000] 0x018a0000-0x03560000: "lgapp"
[ 0.131000] 0x03560000-0x04fa0000: "lgres"
[ 0.132000] 0x04fa0000-0x05be0000: "lgfont"
[ 0.132000] 0x05be0000-0x05c00000: "tplist"
[ 0.133000] 0x05c00000-0x07640000: "lgres"
[ 0.134000] 0x00080000-0x000a0000: "cert"
[ 0.135000] 0x000a0000-0x00140000: "authcxt"
[ 0.136000] 0x00060000-0x00080000: "hdcp2"
[ 0.137000] 0x00140000-0x00160000: "keyrsrv"
[ 0.138000] mod_nand_init is invoked
[ 0.138000] GE driver inits
[ 0.138000] mod_iic_init is invoked
[ 0.138000] model option = 0xfc
[ 0.138000] Mstar_emac: [PHY Addr] ==> :0
[ 0.138000] Mstar_emac: alloRAM_VA_BASE = 0xA0C40000 alloRAM_PA_BASE= 0xC40000 alloRAM_SIZE= 0x100000
[ 0.139000] RBQP_BASE = c44000
[ 0.140000] [SCALER][000173] _mod_scaler_init
[ 0.140000] [TTX_DRV][00508]init 170
[ 0.140000] MDrv_CC_Init
[ 0.140000] init 172
[ 0.140000] [DEMOD_DRV][00369]init 245
[ 0.140000] [BDMA_DRV][00629]init 251
[ 0.141000] TCP cubic registered
[ 0.141000] NET: Registered protocol family 17
[ 0.142000] RPC: Registered udp transport module.
[ 0.142000] RPC: Registered tcp transport module.
[ 0.142000] Adding user_initcall[0] = 0x803a1314
[ 0.142000] Adding user_initcall[1] = 0x803a1320
[ 0.142000] Adding user_initcall[2] = 0x803a66f8
[ 0.144000] VFS: Mounted root (squashfs filesystem) readonly.
[ 0.150000] VFS: Mounted lginit (squashfs filesystem) readonly.
[ 0.150000] Freeing unused kernel memory: 132k freed
[ 0.204000] SQUASHFS error: Can't find a SQUASHFS superblock on mtdblock19
[ 0.225000] Empty flash at 0x000213bc ends at 0x00021800
[ 0.234000] Empty flash at 0x00023200 ends at 0x00023800
[ 0.242000] Empty flash at 0x00024bbc ends at 0x00025000
[ 0.250000] Empty flash at 0x000271ec ends at 0x00027800
[ 0.250000] jffs2_scan_inode_node(): CRC failed on node at 0x00028fe0: Read 0xffffffff, calculated 0x916f9a2e
[ 0.258000] Empty flash at 0x00029120 ends at 0x00029800
[ 0.264000] Empty flash at 0x0002ab84 ends at 0x0002b000
[ 0.289000] Empty flash at 0x00040878 ends at 0x00041000
[ 0.289000] jffs2_scan_dirent_node(): Node CRC failed on node at 0x000427f4: Read 0xffffffff, calculated 0x2322e93d
Thank you in advance!
​Comment
sorry does anyone have the dump for this hitachi tv?
25L1606E thanks e nel caso va cambiato anche lo status reg?​
25L1606E thanks and if so should the status reg also be changed?​Comment
HI, this are some little dumps from TV Sharp LC-40LE730E...Comment
sorry lotas this is already ready do i have to change the status reg? in case can you tell me what the status reg is thanksComment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
