Eeprom dump thread!
This is a sticky topic.
Re: Eeprom dump thread!
does anyone have Eeprom files for Philips 48PFA4609/98 Firmware
thanks in advanceComment
It might just help if you put the correct model number of your TV down! I thought it was a 24inch set no search on google found for your model you typed in.Comment
Attached FilesComment
model L423ed11
Can i flash in situ or does it need desoldering ?Comment
Hisence H49N5700
Sent by hisence to my email.
Their website returns a 404 error, so here it is.
Download Google Drive
Extract with 7z until you get a *.pgk file
Rename it to upgrade_loader.pkg
Check This Video: YT - Video
Update steps:
1.-When the TV is on, turn off the switch at the bottom.
2.-Unzip the file and copy the .bin file to the root of a completely empty USB memory.
3.-Insert the USB memory into the USB slot of the Smart TV
4.-Turn on the TV switch.
5.-The installation of the upgrade software will begin. You can check the installation progress on the screen or depending on the model, you can check the flashing on indicator light. The installation will take about 5 minutes.
6.-The TV will automatically restart as soon as the operation is finished.Last edited by dragometin; 06-24-2020, 11:14 AM.Comment
This is dump files : https://www.arizanotlari.com/diyarba...otlari.com.rar
This is panel files : https://www.arizanotlari.com/diyarba...otlari.com.ziphttps://www.badcaps.netComment
This is full firmware : https://www.arizanotlari.com/diyarba...otlari.com.ZIP
This is panel files : https://www.arizanotlari.com/diyarba...otlari.com.zipComment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
