I tried it but it doesn't work, the TV keeps flashing but it doesn't turn on, the red light flashes
Eeprom dump thread!
This is a sticky topic.
The eeprom does not have a status register, but the spi flash does. When reading a dump from the spi flash, the programmer should show which status register is installed. What kind of programmer do you have, if CH341A, then what program do you use for it?Comment
http://www.mfelettronicasestri.it/DEADfile/MT29F4G08ABAEAWP@TSOP48.rar
I attach the link to the nand file if you can take a look thanksComment
I don't have access to this resource, please upload it to another file hosting service.Comment
yes do it like this copy link and open page and paste link you will see that it works otherwise send me your emailComment
I tried lotas but it doesn't work.... only thing is I didn't clean the bits.... sorry how do I clean it from the bits??? but I think it doesn't workComment
Originariamente pubblicato da MF ELETTRONICA Visualizza post
ciao lotas ho scoperto che il problema è nella nand la tv lampeggia e non si accende se ti mando il dump della mia nand puoi vedere se lo risolvi? grazie
Provalo, puliscilo dagli errori di bit...
https://drive.google.com/file/d/1utt...-rVkhZ3E9/view
ho provato questo file che mi hai inviato credo lo hai modificato? ma non funziona non ricordi?
English ???Comment
Originariamente pubblicato da MF ELETTRONICA Visualizza postciao lotas ho scoperto che il problema è nella nand la tv lampeggia e non si accende se ti mando il dump della mia nand puoi vedere se lo risolvi? grazie
I tried this file you sent me I think you modified it? but it doesn't work, don't you remember?Comment
I also have firmware for recovery via usb, but VES315WNDS panel, but you have a different panel.Last edited by lotas; 11-27-2024, 11:29 AM.Comment
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
by Ancient1Hi
I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
Right distribution board, 2 Flexs, near them:
The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
I... - Loading...
