Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4597
    • Russia
    #1841
    Originally posted by Technician123
    Thanks for your patience, yes I have that motherboard, I was able to extract the following bin file from the non-working flash, I would really appreciate it if you could help me take a look at it
    The kernel and software in your dump are fine, try recording your dump with the NVM removed.
    • Technician123
      • Dec 2024
      • México
      #1842
      Thank you, unfortunately the screen still does not turn on, it only shows the standby LED.
      • hazi12
        • Jun 2015
        • 8
        • Czech Republic
        #1843
        Hello, can someone check the dump or has the original , thank you
        Samsung UE55MU6170UXZG KANT_M_BUILT_IN BN41-02568B BN94-12486N
        It responds to remote on and off, but does not turn on 12V power for pmic.
        • lotas
          • Jan 2016
          • 4597
          • Russia
          #1844
          Dump is ok.​
          • hazi12
            • Jun 2015
            • 8
            • Czech Republic
            #1845
            Dump is ok.​
            Thank you Lotas, is it possible that the failure was caused by the Emmc firmware?
            • lotas
              • Jan 2016
              • 4597
              • Russia
              #1846
              Yes, everything is possible, have the usb and hdmi ports been checked for short, low resistance relative to gnd?
              • hazi12
                • Jun 2015
                • 8
                • Czech Republic
                #1847
                Yes usb and hdmi ports fine, dc converters too, not found from the same board original firmware emmc nor w25Q40.
                • Drexter
                  • 10
                  #1848
                  Hello everyone, could someone help me check the bin file for a Samsung UN75MU6103. Ver. FB03. or if you have a working backup, would be greatly appreciated. The Standby led is turned off, still if joystick is pressed or powerd on by remote, it flashes, but nothing happens. All voltages are present and there is no short circuit on the board. Thanks in advance!.
                  • maxri
                    • May 2023
                    • 7
                    • Italy
                    #1849
                    Hi. I have a Samsung UE49MU6220KXZT that won't turn on. No led and no response to commands.
                    Can someone check the dump or has the original , thank you
                    Board BN41-02568A BN94-12571E
                    Thank you.
                    • lotas
                      • Jan 2016
                      • 4597
                      • Russia
                      #1850
                      Thank you.
                      I can check, but I don't see your dump.
                      • Drexter
                        • 10
                        #1851
                        Sorry I thought I uploaded it. Here it is. Thanks a lot!!
                        • maxri
                          • May 2023
                          • 7
                          • Italy
                          #1852
                          Sorry... i forgot the file...
                          • lotas
                            • Jan 2016
                            • 4597
                            • Russia
                            #1853
                            Try it, don’t forget about status register (0x88, 0x42).
                            • lotas
                              • Jan 2016
                              • 4597
                              • Russia
                              #1854
                              Your dump is ok, working, the problem is different.
                              • Drexter
                                • 10
                                #1855
                                Thank you very much I appreciate it!
                                • maxri
                                  • May 2023
                                  • 7
                                  • Italy
                                  #1856
                                  Try it, don't forget about status register (0x88, 0x42).
                                  With this file the led is now red and flashes when sending commands. The tv still doesn't turn on.
                                  The processor heats up even if the tv doesn't seem to do anything.
                                  I read the post about the registers and I hope I programmed the chip well.
                                  Thanks anyway for your support.​
                                  • maxri
                                    • May 2023
                                    • 7
                                    • Italy
                                    #1857
                                    hello, I would like to try again to solve the problem of my Samsung TV (UE49MU6220KXZT).
                                    I have a Xggeku T48 programmer, can you confirm that with this device the programming of the bin file and the registers happens all at once?
                                    Or is it necessary to repeat a second time for the status register?
                                    Can someone provide another bin file to try?
                                    Thanks.​
                                    • dadopo
                                      • Jan 2025
                                      • 7
                                      • Italia
                                      #1858
                                      Good morning, I would need a good dump file for my samsung ue40mu6400uxzt, I attach the original dump.
                                      Thanks in advance to anyone who can help me​
                                      • lotas
                                        • Jan 2016
                                        • 4597
                                        • Russia
                                        #1859
                                        Try your good dump file for your TV.
                                        Don't forget to set and write the status register (0x88, 0x42) after writing the corrected dump.
                                        • dadopo
                                          • Jan 2025
                                          • 7
                                          • Italia
                                          #1860
                                          Thank you for your time, but where I change the status register I attach images of my programming software, thanks again
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
