Eeprom dump thread!
This is a sticky topic.
  • ransoms.juggles
    • Oct 2023
    • 6
    lotas how to you fix the firmware? Is there a specific software you use to analyze it that flags bad hex? Sorry my ignorance, I’m still learning.
    • MF ELETTRONICA
      • Jun 2024
      • 41
      • italia
      #1762
      hello everyone x lotas sorry could you check if this is ok? and if so does this also need to set the reg status? thanks
      • MF ELETTRONICA
        • Jun 2024
        • 41
        • italia
        #1763
        hi lotas can you check this too? and one thing also this I have to change the reg status? could you tell me what I have to insert is it always the same 0x88 0x42 or is it different thanks I send you file
        • lotas
          • Jan 2016
          • 4589
          • Russia
          #1764
          https://www.badcaps.net/forum/troubl...ng-ue32t5300ak
          Here is a topic where I posted two working dumps, try which one should suit you.
          • lotas
            • Jan 2016
            • 4589
            • Russia
            #1765
            Status Register (1C)
            • MF ELETTRONICA
              • Jun 2024
              • 41
              • italia
              #1766
              nothing works for me I don't understand if it's the firmware or something else
              • MF ELETTRONICA
                • Jun 2024
                • 41
                • italia
                #1767
                hi lotas sorry you gave me the dump and the tv works but there is a problem the wi fi doesn't work could you see if there is something wrong with the dump you gave me? to solve thanks
                • MF ELETTRONICA
                  • Jun 2024
                  • 41
                  • italia
                  #1768
                  I'm talking about this TV
                  • lotas
                    • Jan 2016
                    • 4589
                    • Russia
                    #1769
                    This firmware has nothing to do with the wi-fi module and has no bearing on it.
                    • MF ELETTRONICA
                      • Jun 2024
                      • 41
                      • italia
                      #1770
                      ok thank
                      • cheeky2
                        • Dec 2012
                        • 337
                        • uk
                        #1771
                        Looking for working dump for a PROSCAN PLEDED4022-UK with mainboard TP.SIS231.PT851 ​with screen V390HJ5-XCPE1 or a working dump for the same screen and main board.
                        I have looked on the web without any success for the dump of the Proscan TV.
                        Any help would be appreciated. Thanks in advance.
                        • lotas
                          • Jan 2016
                          • 4589
                          • Russia
                          #1772
                          Try...
                          • cheeky2
                            • Dec 2012
                            • 337
                            • uk
                            #1773
                            Originally posted by lotas
                            Try...
                            Thank you Lotas
                            Is the Fuego 40FG4505 a USB file as well as it is only 6748kb and not 8192kb?
                            • lotas
                              • Jan 2016
                              • 4589
                              • Russia
                              #1774
                              Thank you Lotas
                              Yes, it's USB, you can do it on the programmer...The programmer itself will add the rest (FF, FF....)
                              • cheeky2
                                • Dec 2012
                                • 337
                                • uk
                                #1775
                                Thanks I thought as much but just thought it might save me some time taking the flash ic off and programming it.
                                • Andreas_de
                                  • Jul 2024
                                  • 15
                                  • Deutschland
                                  #1776
                                  I have a Samsung UE65KU6099UXZG with no standby LED. Voltages on Motherboard are fine (5V, 3,3V, 1,8V). Here is the EEPROM dump. Maybe it is bad?
                                  • lotas
                                    • Jan 2016
                                    • 4589
                                    • Russia
                                    #1777
                                    This dump has nothing to do with standby, this spi flash belongs to T-con, look for spi flash 25Q40 on the board.
                                    • Andreas_de
                                      • Jul 2024
                                      • 15
                                      • Deutschland
                                      #1778
                                      Here is the SPI dump. Thanks for your help.
                                      • lotas
                                        • Jan 2016
                                        • 4589
                                        • Russia
                                        #1779
                                        This dump is ok, working.
                                        • Andreas_de
                                          • Jul 2024
                                          • 15
                                          • Deutschland
                                          #1780
                                          Here is a dump of a Samsung UE48HU7590: Board is HU8500 BN41-02257B. TV starts for 1 second with "Smart TV" logo and then turns off screen. No reboot loop. Maybe you can find here a defect in the SPI EEProm. I added the second EEProm which is behind the little black heatsink as well in the ZIP.
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
