Eeprom dump thread!
This is a sticky topic.
  • jimbofz
    • Apr 2013
    • 539
    • uk
    #1481
    Re: Eeprom dump thread!
    heres what has loaded and a pic of how ch341a is configured
    • lotas
      • Jan 2016
      • 4855
      • Russia
      #1482
      Everything seems to be correct, click on the check.
      • jimbofz
        • Apr 2013
        • 539
        • uk
        #1483
        data and buffer the same
        so it looks good ill try it and let you know if it works
        thanks again for all your help
        • lotas
          • Jan 2016
          • 4855
          • Russia
          #1484
          Ok!
          • jimbofz
            • Apr 2013
            • 539
            • uk
            #1485
            Originally posted by lotas
            Ok!
            same symptoms
            well at least i know eeprom is not causing the fault
            original post phil pus6162/05 dated 6.4.22
            trying to find replacement mb for this 65inch model
            is proving to be headache
            thanks for all your help lotas
            • jimbofz
              • Apr 2013
              • 539
              • uk
              #1486
              Originally posted by luzmina
              jimbofz: in those Chinese tvs, if the only issue is no sound the problem is the sound amp, make sure the sound IC has power before replacing it, if no sound after replacing it then the issue is the microcomputer.
              thanks for your post ,
              i have made a note of the sound o/p ic problem
              sadly my fault is dead but all supplies ok no sby light
              • nitsuga
                • Dec 2013
                • 12
                • mexico
                #1487
                Do you have the eeprom dump for RCA DETG185R? How can I post a new thread
                • lotas
                  • Jan 2016
                  • 4855
                  • Russia
                  #1488
                  What's the problem with the TV?
                  What is your motherboard number and what is the panel (matrix) number?
                  You can read the data (dump) from your eeprom and post it here.
                  • nitsuga
                    • Dec 2013
                    • 12
                    • mexico
                    #1489
                    the problem is only red light standby, don´t turn on. Panel HD 18.5" RCA, model DETG185R motherboard CV3393BL-C
                    Do you have Dumps of this motherboard? not necesary that brand
                    • nitsuga
                      • Dec 2013
                      • 12
                      • mexico
                      #1490
                      Is it posible to modify this dump in order to flip the screen ?
                      • lotas
                        • Jan 2016
                        • 4855
                        • Russia
                        #1491
                        Try
                        • nitsuga
                          • Dec 2013
                          • 12
                          • mexico
                          #1492
                          Thank you so much! You are a genius.
                          I wonder if you can change the panel in this firmware, Mainboard CV3393BL-C original panel is HV236WHB-M00 but I need the V236BJ1 panel,
                          the reason is that I need to flip the image, or how can I flip image? Service mode don´t work
                          • nitsuga
                            • Dec 2013
                            • 12
                            • mexico
                            #1493
                            Try
                            Thank you so much! It works
                            the reason is that I need to flip the image, or how can I flip image? Service mode doesn´t works
                            • lotas
                              • Jan 2016
                              • 4855
                              • Russia
                              #1494
                              Why does the service mode not work, or do you not know the code how to enter it?
                              • nitsuga
                                • Dec 2013
                                • 12
                                • mexico
                                #1495
                                I can enter and modify but the changes disappear when I turn off the TV
                                • Rajnhl
                                  • Oct 2018
                                  • 94
                                  • India
                                  #1496
                                  there must be function to save changes. try with ok or (>) arrow button or vol/channel + button.
                                  • BigPete
                                    • Jul 2012
                                    • 76
                                    • New Zealand
                                    #1497
                                    LG 60PB6600 Bin
                                    IC100
                                    24C256
                                    NZ version
                                    • nitsuga
                                      • Dec 2013
                                      • 12
                                      • mexico
                                      #1498
                                      Can someone make a tutorial about how to change Remote Control in a Mstar NOT SmartTV dump file? here is a PDF with some details. It´s very interesting how to fix the checksum of the Dump
                                      • luzmina
                                        • May 2015
                                        • 17
                                        • US
                                        #1499
                                        This is the hard way, hacking the binary, we need the application they use to program the MSD chips... but everything is keep secret by those companies, they do not care the huge mountains of waste they create with those 90 days warranty TV that most of them fail in the first year and good luck if you need warranty service, as they do not respond or hang the phone to you.
                                        • cheeky2
                                          • Dec 2012
                                          • 339
                                          • uk
                                          #1500
                                          Looking for the data dump from a Bush LE-40GCL-A1 with the main board TP.SIS231.PT751 with any screen model (as they only did one screen for this model T400D3-HA24-DY1).
                                          I know our Russian friends have it here: h***s://****************/dump/lcd_pdp_tv/prochee/bush_le_40gcl_a1_w_shassi_main_board_tp_sis231_pt751/248-1-0-106714 at remont
                                          but obviously I cannot register with them to gain access to the site unfortunately.
