Eeprom dump thread!
This is a sticky topic.
  • totof
    • Feb 2017
    • 169
    • france
    #1321
    Re: Eeprom dump thread!
    Originally posted by lotas
    You also asked for 24С512, maybe eMMC is covered with you (they have a certain service life).
    If eMMC problem in this case I must translate that it is not repairable ?
    • lotas
      • Jan 2016
      • 4855
      • Russia
      #1322
      If you have never encountered eMMC, then it is better to replace the motherboard.
      You can find any BN41-02528A motherboard (they only have different firmware for different panels), you just need to rewrite or replace the 25Q80 (where the panel settings, T-con are located).
      • totof
        • Feb 2017
        • 169
        • france
        #1323
        I found a motherboard of the same reference extracted from a UE55KU6400 TV whose panel was broken but simply by programming the 25Q80 flash with the contents of that of my TV then the TV enters a looping start cycle
        I can try to change the eMMC but the problem will be to find the program. Is the program easy to find and what hardware is needed to program it ? Is it possible to change it and then reprogram it directly on the motherboard ?
        • cheeky2
          • Dec 2012
          • 339
          • uk
          #1324
          Originally posted by tehmatix
          Blaupunkt 32-147I-GB-5B-HBKUP-UK , tv bootloop, led red > blue > red >blue
          Desolder UF11 and use CH341 for reprogram. After , go to menu and Factory reset
          Firmware below
          What's the screen model number for this dump and the main board number?
          • totof
            • Feb 2017
            • 169
            • france
            #1325
            I finally changed the motherboard and my TV is working again.
            Attached are the dumps of the new motherboard
            • shawnpsx323
              • Jan 2022
              • 30
              Good Day All,
              Looking for dump for Samsung UN49M5300AFXZA Ver.FA01. Board number BN94-12049D.
              Assistance in getting this as I believe the original is somehow corrupted.
              Original dump attached incase it can be fixed.
              Thanks...
              • shawnpsx323
                • Jan 2022
                • 30
                Originally posted by shawnpsx323
                Good Day All,
                Thanks...
                Anything guys?
                Issue is that standby LED will flash 5 times. Power supply is good. I've tried another bios dumped from a similar board and the standby light stopped flashing, TV will turn on for few seconds and then turn off. So this is why I believe bios is corrupted. Any Help??
                • mo4nis
                  • Dec 2018
                  • 55
                  • maroc
                  #1328
                  Originally posted by cheeky2
                  I have a Blaupunkt 39/210I-GB-5B-F3HBKU-EU that has a corrupted flash ic as it is stuck in standby.
                  Main board TP.MSD309.BP85
                  screen V390HK1-LS6-Rev.C8
                  Does anyone have a working dump for this model or similar?
                  The only one I could find was on the russsian site here (which I cannot register on!)
                  Thanks in advance
                  tp.msd309.bp85 flas dump
                  • muhamad.sh
                    • Apr 2017
                    • 6
                    • turkey
                    #1329
                    Originally posted by omruu9
                    your file
                    thank you so much
                    • Diamondj421
                      • Sep 2022
                      I've spent the last few days scouring the web for a new EEPROM for my Vizio E550i-B2 with no success. Does anyone have a dump for this model?
                      • whitevolf
                        • Feb 2014
                        • 124
                        • TÜRKİYE
                        #1331
                        thanks
                        • totof
                          • Feb 2017
                          • 169
                          • france
                          #1332
                          Thank you very much lotas.
                          In fact I can't fully test the binaries because I don't have the TV at home, I only have the electronic boards and the LED bars.
                          The second binary (ue55mu6105_ic1604_II.bin) doesn't work, I don't even have the standby led.
                          On the other hand, the first binary (ue55mu6105_ic1604.bin) seems to work: I have the standby LED, the tv turns on with the remote control and the backlighting turns on fine. On the other hand, to test the image, I will have to wait to return to my parents and it will only be in several weeks.
                          I will post back to the forum at that time.
                          Hello
                          Two months later I was able to return to my parents home and test the programming of the motherboard.
                          The TV restarted without any problem and the picture is perfect.
                          Thank you lotas
                          • lotas
                            • Jan 2016
                            • 4855
                            • Russia
                            #1333
                            Hello
                            Thank you lotas
                            Hi, glad it worked out.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              #1334
                              here is the corrupted philips bin file
                              65pus6162/05
                              sorry i cant seem to upload .bin file
                              can somebody advise please
                              • jimbofz
                                • Apr 2013
                                • 539
                                • uk
                                #1335
                                hope this is correct
                                • lotas
                                  • Jan 2016
                                  • 4855
                                  • Russia
                                  #1336
                                  65pus6162/05
                                  And why is this size small, what chip did you read the dump from?
                                  • jimbofz
                                    • Apr 2013
                                    • 539
                                    • uk
                                    #1337
                                    cct ref U409
                                    M24128 BRMN6TP
                                    this is from the cct diagram
                                    the number on the chip is difficult to read
                                    :128br 713t with green paint on pin 1
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #1338
                                      second attempt
                                      re read this time selecting:
                                      24 eeprom
                                      AMTEL
                                      AT24C128
                                      from menu on left
                                      sorry im new to this
                                      • lotas
                                        • Jan 2016
                                        • 4855
                                        • Russia
                                        #1339
                                        Try it, there are two dumps from different models, but the main is the same for everyone.
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #1340
                                          thanks for your effort ,
                                          sadly fault still same
                                          but at least i know that i now have the correct eeprom data
                                          would it be worth buying a new blank eeprom and writing the bin file to it?
