Eeprom dump thread!
This is a sticky topic.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #1641
    Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen could this be a firmware fault
    Edit, please ignore above, the set has one failed led on one strip.
    • lotas
      • Jan 2016
      • 4874
      • Russia
      #1642
      Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen i have tested the leds they stay lit a 122v on led tester could this be a firmware fault
      Edit, please ignore the set has one failed led strip.
      Anything is possible, first you need to check whether 12 volts is supplied to the t-con board (whether the fuse is live) or whether this happened after an incorrect update (another panel).
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #1643
        Thanks lotas i will remember too check that next time, not sure if youve seen my edit above the set had one failed led on one strip when taking the tv apart found the set had been dropped as loads of plastic cracked etc so i have stripped the tv for parts (was a free set anyway)
        • imran333
          • Apr 2012
          • 48
          • uk
          #1644
          Need emmc dump for XBR-65X850D or for 55” version, board number is 1-980-832-11, this is USA board and Europe and UK board has same board number but board is slightly different and the dump didn’t work so really need the correct one, I don’t mind looking after the person with the dump
          • ivblgrpet
            • Jan 2024
            #1645
            Hi!
            TV Toshiba 55U6763DG
            Main: Vestel 17mb120
            SPI: MX25L1606E
            Problem: Do not turn on, flashing red/green standby, Unable to make USB update.
            ​Can you check and repair (if it needs to be repaired) this SPI dump.
            Thanks!
            • lotas
              • Jan 2016
              • 4874
              • Russia
              #1646
              Originally posted by ivblgrpet
              Hi!
              SPI: MX25L1606E
              Thanks!
              Try this dump.​
              • ivblgrpet
                • Jan 2024
                #1647
                Try this dump.​
                Thank you for very fast reply. I'll try it on monday and report results.
                • ivblgrpet
                  • Jan 2024
                  #1648
                  Try this dump.​
                  Unfortunately this dump didn't help. Same problem remains. Thank you anyway. Maybe or probably problem is not in MX25L1606E.
                  CH341A is my only tool for programming. I have the UART log. Maybe you can identificate the problem with the help of this log?
                  • lotas
                    • Jan 2016
                    • 4874
                    • Russia
                    #1649
                    You have a problem with NAND flash.
                    • ivblgrpet
                      • Jan 2024
                      #1650
                      Ok, thank you
                      • totof
                        • Feb 2017
                        • 172
                        • france
                        #1651
                        hi, i am looking for the eeprom for my Samsung UE40MU6405 -BN41-02568B / BN94-12398F.
                        The tv doesn't power on (power led always off). Backlight on when moherboard disconnected.
                        Non-working dump here.
                        Thanks​
                        • lotas
                          • Jan 2016
                          • 4874
                          • Russia
                          #1652
                          Thanks​
                          There is no need to search, other people's dumps will not help you, just restore your own one. Try it.
                          • lotas
                            • Jan 2016
                            • 4874
                            • Russia
                            #1653
                            Try it.
                            It doesn't work, what also doesn't work?
                            • totof
                              • Feb 2017
                              • 172
                              • france
                              #1654
                              Hello.
                              I have just tried now and it works very well now.
                              Thank you lotas :-)
                              • lotas
                                • Jan 2016
                                • 4874
                                • Russia
                                #1655
                                Hello.
                                Thank you lotas :-)
                                Well, great that it works!
                                • StephenU
                                  • Dec 2013
                                  • 230
                                  #1656
Name:	Toshiba update via USB.jpg
                                  Tv stuck on Toshiba Splash screen.
                                  Guys here is the Software provided by Toshiba. ## Can someone help as I keep getting - Error: PHP Max Post Size has been exceeded. when trying to upload zip file, thanks ##
                                  Toshiba: 55T6863DB
                                  Mainboard: 17MB130S - 23495635
                                  Panel number: VES550QNYL-2D-N01​
                                    SMDFlea commented
                                    Editing a comment
                                    Splitting the attachment might fix that
                                • StephenU
                                  • Dec 2013
                                  • 230
                                  #1657
                                  ok will try that now, Thanks
                                  • StephenU
                                    • Dec 2013
                                    • 230
                                    #1658
                                    Still exceeds file size for upload. When zipped file size is - 171 MB
                                    • lotas
                                      • Jan 2016
                                      • 4874
                                      • Russia
                                      #1659
                                      When archiving a file there, you can divide it into parts (part 1, part 2, ...) of a given size or upload it to the cloud and post a link to it.
                                      • StephenU
                                        • Dec 2013
                                        • 230
                                        #1660
                                        Sorry, I don't have the winzip program on this computer at the moment, only the built in windows zip program. Here is the Link to the Files if someone could kindly download and maybe upload to here?
                                        https://we.tl/t-PUefOOT7Yf
                                        Many Thanks,
                                        S.
