Eeprom dump thread!
This is a sticky topic.
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    #1401
    Re: Eeprom dump thread!
    Originally posted by lotas
    The software in the dump is fine, try with a clean eeprom.
    Thanks a lot...
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      #1402
      Originally posted by KYBOSH
      I jumping into the firmware dump game and wasted to see if I could find the dump for a Samsung UN55MU800. The board number is CY-SM055FLLV6H. The chip is a WINBOND 25Q32JVIG. I did a quick search on this thread but didn't see anything. Perhaps I am not searching for it correctly?
      Thank you in advance!
      I finally got around to getting the dump!
      I the chip is a Winbond 25Q32JVIG but that chip is not specifically supported so I used W25Q32FV instead. Attached is the dump from that read. Would someone please have a look a fix it for me? If I didnt read it right please let me know what I did incorrectly and I will sort it out ASAP. Thank you !
      • Dawarr
        • Mar 2021
        • Gemany
        #1403
        hi,
        Medion/vestel
        X14903
        MD-32030
        49"
        BOARD: 17MB130P 23462734 ?V3(NOT SURE) ser.nr.7970800
        PANEL: VES490QNDL-2D-N31 (LG32)
        PS: 17ips72
        hope u rescue me.
        thank u in advance
        greetz
        • KYBOSH
          • Oct 2011
          • 581
          • Unknown
          #1404
          Got another one for you good people.
          Samsung UN55HU8550
          Bootloop at Startup "SmartTV" logo.
          I found 2 chips but I am not sure which one is the firmware so Im including both.
          Both were relatively close to the processor and both were marked with a marker at the factory.
          • lotas
            • Jan 2016
            • 4859
            • Russia
            #1405
            Samsung UN55HU8550
            If you have a bootloop, then the problem is in the eMMC firmware.
            • KYBOSH
              • Oct 2011
              • 581
              • Unknown
              #1406
              You are amazing Sir.
              Thank you for the knowledge.
              I will proceed accordingly.
              Any hope for the panel dump in Post #1412?
              • lotas
                • Jan 2016
                • 4859
                • Russia
                #1407
                What is this firmware from the panel bar from? If so, then I haven't encountered any problems with them.
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #1408
                  The dump is from the LCD Panel board of Samsung UN55MU800.
                  The display panel's number is CY-SM055FLLV6H.
                  The LCD panel board that this W25Q32JVIG resides on is BN96-41982A (see attached picture).
                  It is believed that there is an issue with it as the panel is not getting picture but the mainboard is believed to be good and there are no shorted components on the LCD panel board.
                  Thank you very much!
                  • lotas
                    • Jan 2016
                    • 4859
                    • Russia
                    #1409
                    There is nothing special in it and does not affect the image (correction of broken pixels is set at the factory for each panel and the contents are different for them), the T-con firmware can be responsible for the image, it is located on the 25Q80 motherboard.
                    • KYBOSH
                      • Oct 2011
                      • 581
                      • Unknown
                      #1410
                      I very much appreciate the guidance Lotas. It was suggested that this maybe a source of my No Picture problem.
                      Are you able to check my EEPROM dump in post #1414 to see if it is in order?
                      That would be another unknown i cam eliminate as a source of my issues.
                      • cheeky2
                        • Dec 2012
                        • 339
                        • uk
                        #1411
                        I have this corrupted Blaupukt 32 147I-GB-5B-HBKUP-UK screen LVW320SSDX E2 V1 main TP.MSD309.BP85 C12415 that will not turn on could someone have a look at it for me and see where the corruption is please? I see Lotas has the relevant skills to do this.
                        I am going to try and work out how to do this in future so any tips would be appreciated in working it out as I try to understand and resolve problems myself.
                        • lotas
                          • Jan 2016
                          • 4859
                          • Russia
                          #1412
                          Hello, there was no time, dump is ready (there was a problem in it), try it.
                          • cheeky2
                            • Dec 2012
                            • 339
                            • uk
                            #1413
                            Thanks Lotas. It will take a few days before I can try it. I will let you know how it goes when it's done.
                            Regards Anthony
                            • lotas
                              • Jan 2016
                              • 4859
                              • Russia
                              #1414
                              Ok.
                              • luzmina
                                • May 2015
                                • 17
                                • US
                                #1415
                                I need bin file for TV Westinghouse Model: DWM32H1G1 using chip MSD3393LUM, attached is the broken bin file, Thanks
                                • lotas
                                  • Jan 2016
                                  • 4859
                                  • Russia
                                  #1416
                                  What is the motherboard number?
                                  • luzmina
                                    • May 2015
                                    • 17
                                    • US
                                    #1417
                                    St3393lup-a1h
                                    • lotas
                                      • Jan 2016
                                      • 4859
                                      • Russia
                                      #1418
                                      Try.
                                      • luzmina
                                        • May 2015
                                        • 17
                                        • US
                                        #1419
                                        You Fixed it!!! I downloaded the EEPROM bin like 50 times, with freeze and without, always get the same CHKSUM, so it was heavy corrupted. Attached is a picture of the TV working, all menus work fine and the sound too, Thanks
                                        • lotas
                                          • Jan 2016
                                          • 4859
                                          • Russia
                                          #1420
                                          Ok., Yes, your dump was badly damaged.
