Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4455
    • Russia
    #1461
    Re: Eeprom dump thread!
    On the programmer - erase, write down my dump, check and solder back to the motherboard.
    • jimbofz
      • Apr 2013
      • 537
      • uk
      #1462
      thanks for all your help
      now i have same fault
      so i will order a new spi chip and reload your dump
      it could simply be the chip is faulty
      all the supplies are good and clean
      i will report back
      • lotas
        • Jan 2016
        • 4455
        • Russia
        #1463
        If you saved your old dump before updating via usb, then you could know for sure whether the problem is in the firmware or not. Always before experimenting with your firmware, you need to make a backup of your dumps, so that if something is wrong, then they can be returned back.
        • jimbofz
          • Apr 2013
          • 537
          • uk
          #1464
          i now understand thanks for advice
          • jimbofz
            • Apr 2013
            • 537
            • uk
            #1465
            hi can anyone help with dump for philips 65PUS6162,05
            MB NUM:715G8709 MOE BOO 005N
            maybe the same as 55inch model?
            chassis TPM17.7E LA
            • yokoono
              • Apr 2010
              • 475
              #1466
              Chassis TPM17.7E LA or TMP17.7E LA ?.
              • jimbofz
                • Apr 2013
                • 537
                • uk
                #1467
                im confused?
                • jimbofz
                  • Apr 2013
                  • 537
                  • uk
                  #1468
                  sorry its TPM i must remember to wear my glasses
                  • luzmina
                    • May 2015
                    • 16
                    • US
                    #1469
                    jimbofz: in those Chinese tvs, if the only issue is no sound the problem is the sound amp, make sure the sound IC has power before replacing it, if no sound after replacing it then the issue is the microcomputer.
                    • lotas
                      • Jan 2016
                      • 4455
                      • Russia
                      #1470
                      chassis TPM17.7E LA
                      Here the error is not "O", but "0" correctly so 715G8709 M0E B00 005N
                      • yokoono
                        • Apr 2010
                        • 475
                        #1471
                        Software pkg
                        https://files.fm/u/eqd8g2ejw
                        • jimbofz
                          • Apr 2013
                          • 537
                          • uk
                          #1472
                          Originally posted by lotas
                          Try
                          many thanks
                          new spi chip with your dump works fine on technika
                          • jimbofz
                            • Apr 2013
                            • 537
                            • uk
                            #1473
                            Originally posted by yokoono
                            many thanks for this dump
                            im having problem writing extracted .bin file to chip
                            my new chip is :st m24128b wmn6p
                            the ch341a programmer only has up to
                            m24c64 when you select manufacturer st from list
                            when i select atmel at24c128bi get
                            "chip memory with contents disagreement " message
                            can you advise please
                            • lotas
                              • Jan 2016
                              • 4455
                              • Russia
                              #1474
                              What program do you have for CH341A?
                              • jimbofz
                                • Apr 2013
                                • 537
                                • uk
                                #1475
                                version 1.30
                                • lotas
                                  • Jan 2016
                                  • 4455
                                  • Russia
                                  #1476
                                  version 1.30
                                  Install this program
                                  https://www.badcaps.net/forum/showpo...7&postcount=51
                                  • lotas
                                    • Jan 2016
                                    • 4455
                                    • Russia
                                    #1477
                                    Or this
                                    • Slimmwill
                                      • Dec 2021
                                      #1478
                                      can you help looking for firmeware for a hisense h55m3300 can anybody help
                                      • jimbofz
                                        • Apr 2013
                                        • 537
                                        • uk
                                        #1479
                                        ok installed siberia prog
                                        LOOKS GOOD DESIGN ,
                                        connected ch341a with new blank eeprom soldered on : m24128 bwmn6p
                                        changed language to english
                                        entered
                                        ;EEPROM 24XX
                                        24C128
                                        i get:recognition error?
                                        any ideas ?
                                        • lotas
                                          • Jan 2016
                                          • 4455
                                          • Russia
                                          #1480
                                          Do you correctly insert it (eeprom) into the programmer? Post a photo of how it's installed.
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
