Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4535
    • Russia
    #1441
    Re: Eeprom dump thread!
    Originally posted by g.pol
    hi i need dump software for lg49uf853v-ze (eax 66165202)
    thanks
    lg 49uf853v-ze eax66165202(1.1) ic102 24c256
    • g.pol
      • Dec 2012
      • 17
      • greece
      #1442
      Hello
      with which programmer can I read the eeprom 24G256, from the TV LG 55UF8007-ZA (EAX66165204)
      can CH341A read?
      thanks
      • lotas
        • Jan 2016
        • 4535
        • Russia
        #1443
        24G256 - BR24G256
        Yes, you can, insert it into the block for eeprom. Select the microcircuit, then "I2C", then "Generic" and select _24C256.
        • jimbofz
          • Apr 2013
          • 539
          • uk
          #1444
          can anyone help with eeprom dump for
          TECKNIKA LCD32-56 board :cv306 h-x 27t1005a
          contacted umc, they supplied incorrect f.w: cv306_merge.bin
          now menus wont come up ,
          (original fault loss of sound after 3 seconds)
          • lotas
            • Jan 2016
            • 4535
            • Russia
            #1445
            Do you still have the native, not working dump?
            • jimbofz
              • Apr 2013
              • 539
              • uk
              #1446
              yes i have the cv306-merge.bin file from umc
              • jimbofz
                • Apr 2013
                • 539
                • uk
                #1447
                heres the bin file from umc
                sorry when i try to upload .bin file i get invalid file message?
                • lotas
                  • Jan 2016
                  • 4535
                  • Russia
                  #1448
                  No, I need to dump his old native (not working), which was before the update.
                  • jimbofz
                    • Apr 2013
                    • 539
                    • uk
                    #1449
                    ok i will remove eeprom
                    and read and save the contents .using my ch341
                    but how do i upload the bin file on this forum ?
                    as .bin files cant be uploaded?
                    • lotas
                      • Jan 2016
                      • 4535
                      • Russia
                      #1450
                      The file (Dump), which you now want to read, has already been updated with an incorrect "cv306-merge.bin" file, but I need it before the update, the bin file can be packed into winrar.
                      • jimbofz
                        • Apr 2013
                        • 539
                        • uk
                        #1451
                        removed spi read and packed to winrar
                        • jimbofz
                          • Apr 2013
                          • 539
                          • uk
                          #1452
                          heres the umc supplied MERGE ..bin
                          heres hoping you can help thanks
                          • lotas
                            • Jan 2016
                            • 4535
                            • Russia
                            #1453
                            How do you read dump? your dump size is very large, I asked you that you have an old dump left, the one that you did not update with the update.
                            • jimbofz
                              • Apr 2013
                              • 539
                              • uk
                              #1454
                              sorry my mistake .i did not read the data before the update
                              the tv was fine but no sound ,after the umc update no menu or sound
                              i read the spi using ch341a the spi number is 25q328vsig
                              the nearest on the list of programmer ,i used w25q256fv
                              does that matter ?
                              im still learning as ive only used the ch341a a few times
                              i did try the update a few times ,could that be why the dump is larger than normal?
                              • lotas
                                • Jan 2016
                                • 4535
                                • Russia
                                #1455
                                Is it native spi flash? There should be 25Q32 or 25Q64, but not like 25Q256.
                                And if there is no sound, this does not mean that the matter is in the firmware, there may be another problem in the hardware.
                                Do you have such a mother?
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  • uk
                                  #1456
                                  this ic is the original
                                  it does not look like it was changed in the past
                                  its possible that the spi number is 25q32"b"vsig
                                  not 25q328vsig
                                  as the markings are so small ive used two magnifiers to get the best chance of accurate reading
                                  the pic looks similar but not the same
                                  the board markings are CV306H-X
                                  then the second number is 27T1005A D
                                  I should add the original fault was :the sound would be ok for a few seconds
                                  • lotas
                                    • Jan 2016
                                    • 4535
                                    • Russia
                                    #1457
                                    Count again, like 25Q32, and lay it out again, the size should be 4Mb.
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      • uk
                                      #1458
                                      here it is fingers crossed
                                      • lotas
                                        • Jan 2016
                                        • 4535
                                        • Russia
                                        #1459
                                        Try
                                        • jimbofz
                                          • Apr 2013
                                          • 539
                                          • uk
                                          #1460
                                          thanks lotas
                                          should i erase the spi with ch341a first?
                                          then load the fresh dump to it ?
                                          or should i refit the chip in tv then use usb to write fresh dump
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
