Samsung ue48h6400 horizontal lines
  • Rob0904
    • 57
    • Uk
    Re: Samsung ue48h6400 horizontal lines
    Haha I haven't messed... I want to but haven't. Hopefully tcon will be here Friday or Saturday.
    • Rob0904
      • 57
      • Uk
      Put another tcon board in and the same lines. What else is there before I concede it's the panel.
      • budwich
        • Jul 2015
        • 3097
        you can try putting some "light pressure" on the tabs along the side in "roughly" the area associated with / near the lines and see if it changes anything. you might get lucky.
        • Diah
          • Feb 2013
          • 6590
          Originally posted by budwich
          you can try putting some "light pressure" on the tabs along the side of the side in the "rough" area associated with / near the lines and see if it changes anything. you might get lucky.
          its horizontal line not vertical one. its T-CON if the LVDS are good.
          • Rob0904
            • 57
            • Uk
            Well I've got a replacement tcon board in same lines. I've put the lvds cable in switched the panel side into the av board side same lines. It's over the top of menus. Anything else to check?
            • Rob0904
              • 57
              • Uk
              #26
              The kids have just been watching a 3d film and from I could tell there was no horizontal lines. Is there hope for the panel after all?
              • Rob0904
                • 57
                • Uk
                #27
                Anyone got any more ideas? I could get another lvds cable just in case it's the cable. Any chance it's an average board fault even tho the lines go over the menus.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #28
                  Could you try and apply a little pressure on the mainboard while the tv is on and see if the lines go away?
                  • Rob0904
                    • 57
                    • Uk
                    #29
                    I could give it a go. On a red screen no lines. Just certain shades and colours
                    • Diah
                      • Feb 2013
                      • 6590
                      1- check the firmware version , there are new upgrade released on 5 Oct.2016
                      2- download this attached and play them from usb on your tv. and tell which photo will show the horizontal line.
                      • Rob0904
                        • 57
                        • Uk
                        #31
                        Thanks diah I will do this test asap but might be tomorrow now. Beer and the away time ��
                        • Rob0904
                          • 57
                          • Uk
                          #32
                          I'm good just screen mirror off my phone? Much quicker for me.
                          Firmware is upto date.
                          • Rob0904
                            • 57
                            • Uk
                            #33
                            Had a quick go this morning with the images. The ones with all the black white squares, no visible lines.
                            the green busy images there is only lines visible on the darker green patches.
                            CVB image there is lines once the black to white is off the black and into the grey colours.
                            The solids red, green and blue no lines.
                            Any thought's
                            • Diah
                              • Feb 2013
                              • 6590
                              Any thought's
                              each image should at least 1 minute show on the TV..... and write down the file name which had line?
                              • Rob0904
                                • 57
                                • Uk
                                #35
                                OK, I will do it properly in a bit.
                                • Rob0904
                                  • 57
                                  • Uk
                                  #36
                                  Lines visible on
                                  CBV-32SH01
                                  Coloured blocks random07
                                  FacesCS12
                                  FB7
                                  FG6
                                  FM4
                                  FM7
                                  FR6
                                  Most of them really but some I have to be really close the screen to see them and only then because I know where to looking.
                                  Does this give any useful information? Does it sound like a panel issue and not a cable or board issue?
                                  • Diah
                                    • Feb 2013
                                    • 6590
                                    Lines visible on
                                    CBV-32SH01 Coloured blocks random07 FacesCS12 FB7 FG6 FM4 FM7 FR6
                                    with this stress test its absolute we have issue with low frequency only .
                                    did you have Line when you play 3D as its 120Hz ?
                                    you can try to log in the service mode. while the TV ON Press the remote -control keys in this sequence
                                    power off - mute - 1-8-2 -power on
                                    1- navigate to SVC read and listed how many operation hour had the display
                                    then at same page of SVC go don to reset all.
                                    after reset all go back again to first page of this mode and go in Option and make factory reset.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      BS Ive had it where a horizontal tab driver caused equally spaced lines on an Led set also alot of other panels in the same way mainly samsung ones dont spend another penny on it OP it will need a new panel or the failed edge driver remove.
                                      • Rob0904
                                        • 57
                                        • Uk
                                        #39
                                        I don't See lines in 3d mode. Might have to watch everything in 3d haha
                                        • Diah
                                          • Feb 2013
                                          • 6590
                                          amazing idea.. i can imagine whole family at day wearing 3D dark glasses..LOL
                                          rest it first and let see..
                                          • noipi
                                            samsung Oled 65 Horizontal Lines and Flicker
                                            by noipi
                                            I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
                                            10-14-2025, 02:11 AM
                                          • Ihandyrepair
                                            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                            by Ihandyrepair
                                            Hi guys
                                            I just started fixing 4k TV few months ago. so I am still learning a lot
                                            I got this tv from friend complaint is ghosting or horizontal lines on image.
                                            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                            then it started to show the ghosting white image.
                                            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                            it has 3 thin small boards at the bottom of the...
                                            12-05-2022, 04:18 PM
                                          • Rubenlily
                                            Samsung QE50Q67TAU - horizontal lines
                                            by Rubenlily
                                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                            I'm no expert but I've done the tape...
                                            08-16-2023, 01:12 PM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                            by x_orange90_x
                                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                            09-04-2023, 12:09 PM
                                          • arctor
                                            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                            by arctor
                                            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                            04-26-2025, 05:22 AM
