Samsung ue48h6400 horizontal lines
    Re: Samsung ue48h6400 horizontal lines
    Haha I haven't messed... I want to but haven't. Hopefully tcon will be here Friday or Saturday.
      Put another tcon board in and the same lines. What else is there before I concede it's the panel.
        you can try putting some "light pressure" on the tabs along the side in "roughly" the area associated with / near the lines and see if it changes anything. you might get lucky.
          Originally posted by budwich View Post
          you can try putting some "light pressure" on the tabs along the side of the side in the "rough" area associated with / near the lines and see if it changes anything. you might get lucky.
          its horizontal line not vertical one. its T-CON if the LVDS are good.
            Well I've got a replacement tcon board in same lines. I've put the lvds cable in switched the panel side into the av board side same lines. It's over the top of menus. Anything else to check?
              The kids have just been watching a 3d film and from I could tell there was no horizontal lines. Is there hope for the panel after all?
                Anyone got any more ideas? I could get another lvds cable just in case it's the cable. Any chance it's an average board fault even tho the lines go over the menus.
                  Could you try and apply a little pressure on the mainboard while the tv is on and see if the lines go away?
                    I could give it a go. On a red screen no lines. Just certain shades and colours
                      1- check the firmware version , there are new upgrade released on 5 Oct.2016
                      2- download this attached and play them from usb on your tv. and tell which photo will show the horizontal line.
                        Thanks diah I will do this test asap but might be tomorrow now. Beer and the away time ��
                          I'm good just screen mirror off my phone? Much quicker for me.
                          Firmware is upto date.
                            Had a quick go this morning with the images. The ones with all the black white squares, no visible lines.
                            the green busy images there is only lines visible on the darker green patches.
                            CVB image there is lines once the black to white is off the black and into the grey colours.
                            The solids red, green and blue no lines.
                            Any thought's
                              Any thought's
                              each image should at least 1 minute show on the TV..... and write down the file name which had line?
                                OK, I will do it properly in a bit.
                                  Lines visible on
                                  CBV-32SH01
                                  Coloured blocks random07
                                  FacesCS12
                                  FB7
                                  FG6
                                  FM4
                                  FM7
                                  FR6
                                  Most of them really but some I have to be really close the screen to see them and only then because I know where to looking.
                                  Does this give any useful information? Does it sound like a panel issue and not a cable or board issue?
                                    Lines visible on
                                    CBV-32SH01 Coloured blocks random07 FacesCS12 FB7 FG6 FM4 FM7 FR6
                                    with this stress test its absolute we have issue with low frequency only .
                                    did you have Line when you play 3D as its 120Hz ?
                                    you can try to log in the service mode. while the TV ON Press the remote -control keys in this sequence
                                    power off - mute - 1-8-2 -power on
                                    1- navigate to SVC read and listed how many operation hour had the display
                                    then at same page of SVC go don to reset all.
                                    after reset all go back again to first page of this mode and go in Option and make factory reset.
                                      BS Ive had it where a horizontal tab driver caused equally spaced lines on an Led set also alot of other panels in the same way mainly samsung ones dont spend another penny on it OP it will need a new panel or the failed edge driver remove.
                                        I don't See lines in 3d mode. Might have to watch everything in 3d haha
                                          amazing idea.. i can imagine whole family at day wearing 3D dark glasses..LOL
                                          rest it first and let see..
