LG 50ln5700 led strip fire photos
  • mcross
    • Sep 2011
    • 201
    Customer bring this in,,,LG 50ln5700 led strip fire, after testing , all was fire just no bl... replaced complete set of strips and the firmware update to stop this from happening again is important. had to have smelled that!
    Mike
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 50ln5700 led strip fire photos
    For fuck sake Lg ! Mothercunts need suing for such a bad design ! Thanks for the photos, as well as FW update be sure to turn tbe Bl way down.
    • mcross
      • Sep 2011
      • 201
      Crazy right?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        More dangerous than crazy.
        • JeffJ
          • Apr 2012
          • 189
          This has made me decide not to bother fixing my 47ln5750.
          • Hamie
            • Apr 2014
            • 1383
            The LN series strikes again.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              That looks nasty. And you thought Samsung were the only ones having trouble with fires...
              A working TV? How boring!
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Ha!
                Even after 80 odd years--They Still Cant make a TV set--That doesn't catch fire!
                --Such nonsense should be a thing of the distant thermionic past!
                --Make 'em for nowt, pile 'em up high, sell 'em cheap with no longevity--who cares if down the road it buggers up someone's whole day, We'll sell ya Yet Another Turd!
                TELEFIX
                • JeffJ
                  • Apr 2012
                  • 189
                  We once had a toaster oven catch fire from the control unit while it was off. We contacted GE, they sent some one to our house to pick it up, they dropped off their best Toaster oven they make free of charge and refunded us the full retail price of the unit that caught fire. And it was 3 years old.
                  Some companies take this stuff serious, not sure if LG does but might give them a ring?
                    Originally posted by hamie
                    the ln series strikes again.
                    +1, +2, +3 .........
                      • 31196
                      so what am i seeing, the pcb shorting against the backplate, or arcing between the tracks on the board?
                      it's very uniform along the length!
                      • CapLeaker
                        Leaking Member
                        • 8327
                        I guess there is no shortage on these catching fire... there are a few threads about the exact same thing in this forum.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          It seems to be shorting the return trace out which is why thats burning up. Very odd.
                            One LED failing short circuit in a series chain causing other LEDs to fail catastrophically and then leading to the array basically being a short across the power board output would be my guess.
                            • mcross
                              • Sep 2011
                              • 201
                              The psb is only putting out 76.1v now. the legend states 110.v to LED, they just flash at boot. ideas?
                              mike
                              • mcross
                                • Sep 2011
                                • 201
                                mike
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Driver Ic return probably damaged due to shorted/burnt string.
                                  • edugimeno
                                    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                    by edugimeno
                                    Hi There!
                                    I'm trying to help my friend who owns a restaurant be just bought.
                                    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                    It's stuck using, I guess, the 2 sided tape that comes with the strip
                                    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                    09-05-2024, 09:34 AM
                                  • adelage
                                    220v Led strip flickering
                                    by adelage
                                    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                                    I know that the best solution would be to get a voltage...
                                    11-03-2024, 09:49 AM
                                  • benareeno
                                    Adjustable dc power supply and tcl led strip
                                    by benareeno
                                    I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
                                    I have an adjustable dc power supply and was trying around 9 volts.
                                    I have a pic of a single diode...where to put pos and neg terminals to light it up?
                                    Pic of middle of strip..is this where i light the entire strip?
                                    And pic of end...or does this light the entire strip?
                                    Where to put pos and neg for single diode..multiple diodes and the entire...
                                    07-11-2021, 02:31 PM
                                  • spleenharvester
                                    Reverse engineering of DoCreate DHJ567 handheld spot welder
                                    by spleenharvester
                                    Hello everyone
                                    I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                    Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                    05-08-2025, 02:52 PM
                                  • mikey5791
                                    Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
                                    by mikey5791
                                    Got this working ips led monitor by the brand of
                                    Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
                                    Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
                                    09-04-2023, 03:50 AM
