220v Led strip flickering
  • adelage
    • 16
    • italy
    Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
    I know that the best solution would be to get a voltage stabiliser for the whole electrical system, but it is an expensive solution and I can't do it right now, is there an easy and cheap way to supply a stable 220v current just to the led strip?
    The strip works at 220v without a power supply, it only needs a rectifier between the strip and the main, it absorbs around 100w and it is just composed of leds and small smd resistors.
    • 32069
    if it's rectified then you could try adding a 400v or 450v capacitor after the rectifier.
    no idea how much capacitance it would take to hold the voltage up during the glitches though.
    AND the cap may be pretty big so you may have trouble hiding it
    • adelage
      • 16
      • italy
      I tried with a 450v/680uf (massive cap) and it's a bit better, but it still flickers..also, the led strip gets quite a lot brighter
        • 32069
        yea, the side effect of the smoothing is the power is continuous and not a 100Hz wave
        • adelage
          • 16
          • italy
          Do you believe an inductor in series, together with the cap, help?
            master hoarder
            • May 2008
            • 12190
            • Fixing stuff
            Going off of the idea with the rectified and smoothed (with large cap) mains... perhaps make a PWM driver circuit for the LED strip that's fed from the high voltage DC?
            In other words, you'll have: 230V AC mains --> rectifier + voltage smoothing (so about 340V DC) --> PWM driver (555 timer based?? or similar) + HV MOSFET switch --> LEDs
            So long as the LEDs are driven a little lower than what you'd get if they were directly connected to the rectified DC rail (i.e. around 230V DC on average), I imagine that should smooth things out. My guess would be that at 60-70% PWM, you'd get the same brightness as you got at 230V AC... and depending on the size (capacitance) of the DC smoothing capacitor, that will give you a bit of energy storage to smooth out the AC line transients.
            For a 100W load, I imagine something in the range of 180-330 uF for the smoothing cap should suffice. Probably may even get away with less, but longer dips in the line will may then start to affect the LED brightness again.
            BTW, you say the LEDs draw about 100W? If so, how did you measure this? 100W worth of LED light is... A LOT. Must be one helluva long LED strip.
              master hoarder
              • May 2008
              • 12190
              • Fixing stuff
              Not really.
              The line is at relatively low frequency, so you would need a HUGE inductor (a few Henry's worth) to see any noticeable results. And moreover, that can cause some tricky stuff during high transients (sparking, inductive kickback, and etc.)
              Your idea does give me an idea, though.
              Take the abovementioned PWM circuit and add an inductor (with a free-wheeling diode) in series with the LED strip, and now you'll have yourself an actual buck regulator circuit that would be acting like a current driver circuit (sort of.) With this, the PWM should give you very precise control over the average current going into the LED strip. And so long as the input cap is large enough, you may be able to sustain your LEDs at stable brightness even with pretty large dips in the power line. As a bonus, you'll get very precise dimming too.
              BTW, sorry for the double-post... but this new forum software is kinda buggy when one tries to edit a post that ends with a smiley / emoticon - it basically won't let me jump to the end of the post to add anything. I really miss the plain old HTML -only reply boxes.
              • adelage
                • 16
                • italy
                The led strip is cheap and rather inefficient, composed of just leds and resistors, that’s why it consumes a lot of power, the box says it consumes about 12w/m, and it’s 12m long, so in total we it uses about 150w (at 310v rectified around 5A).
                One important detail I forgot to mention:
                the strip is controlled by a triac dimmer device before the rectifier (which works both as a dimmer and as a relay), and without the capacitor, once I dim it down, the light flickers noticeably.
                Also, I would like to keep the solution as simple as possible, and at the moment I have no idea about how to build a controller with a 555 timer (I am still a newbie).
                The capacitor helped already a lot, and since the problem occurs only when there’s this fluctuation between 218v to 226v (307v to 318v rectified),can’t I just add a 5a 300v zener diode after the capacitor (does it even exist)?
                • adelage
                  • 16
                  • italy
                  So, I tried to calculate the zener diode using some online calculator, and the power rating for the diode is supposed to be almost 400w! I put 318v as input, 300v as output and 0.5A as load current..either I am using the calculator wrong, or I misunderstood the way a zener diode works..
                    • 32069
                    you cant use a phase-angle dimmer.
                    those work by chopping up the power and will make the flicker worse as you dim it.
                    you need high frequency PWM dimming for leds
                    • reessi
                      ACER BM320 Monitor - Horizonal Flickering Lines After a While
                      by reessi
                      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                      They are black on the right and gradually fade to nothing on the far left.
                      They start either after 5 mins or up to 2 hours after so annoying for testing.
                      They flicker continuously very fast! With a slight pause milli-second every second.
                      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                      I tested each half by removing the first the left flex from...
                      06-03-2025, 09:58 AM
                    • t4796
                      Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
                      by t4796
                      I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
                      Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
                      From the FAQ I learnt that for 110v the power...
                      10-25-2024, 06:59 PM
                    • tommy97
                      HP 15-eh0018na flickering screen
                      by tommy97
                      I’m having an odd problem with this laptop. Apart from the flickering screen, everything works perfectly fine.
                      Board : DAG7HAMB8EO REV:E
                      The display is already dimmed in the BIOS and on the login screen. As soon as I boot into Windows and try to adjust the brightness, the screen starts flickering. The flickering is also visible in the BIOS, but it’s much less noticeable.
                      So far, I’ve tried:
                      • A new screen cable
                      • The same LCD from a second, working laptop
                      • A different battery
                      • Different RAM
                      • A different SSD
                      Unfortunately, nothing...
                      08-19-2026, 03:43 PM
                    • howardc64
                      Vizio M65-F0 2 light strip (4 zones) out
                      by howardc64
                      This TV has 40 local dimming zone and 20 LED strips (each strip = 2 zones) Organization is 10 rows and 4 zones per row. Each zone is 6 LEDs so probably 3V LED for 18V total / zone.
                      40 MOSFETs ( datasheet ) on the LED driver board so I guess each is driving the voltage for 1 zone. No source to drain shorts on any MOSFET. All 3R3 resistor on source reads ~< 4ohms. Here are the voltage readings
                      There are 4 LED connectors (1-4) I've labeled A1-10 voltages for connector 1, B1-10 for connector 2, C1-10 for connector 3, and D1-10 for connector...
                      08-11-2026, 05:03 PM
                    • edugimeno
                      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                      by edugimeno
                      Hi There!
                      I'm trying to help my friend who owns a restaurant be just bought.
                      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                      It's stuck using, I guess, the 2 sided tape that comes with the strip
                      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                      09-05-2024, 09:34 AM
