Element 50" LED ELEFW504 with white screen.
  • Lmterickg
    • Oct 2016
    • 13
    I recently saved the landfill from another salvageable flat screen and it has completely white screen. Already took off the back panel to inspect the power board and T Con boards. No visible capacitor damage and I cleaned all connections with IP alcohol and reconnected. Still no change and I can't locate the surface mount fuse on the T Con board to check it. Any ideas of what to look for would be greatly appreciated. I ordered a full replacement kit with power board and T Con board in the mean time.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Element 50" LED ELEFW504 with white screen.
    Fuse on Tcon
      The way the screen look I think the fuse is OK, if it is, then try having one ribbon cable between the LCD panel and the T-CON board connected one at a time to see if you will get image on half of the screen or not.
      • Lmterickg
        • Oct 2016
        • 13
        Well, when I was taking the TV apart I discovered what that crunching sound was when I was putting the stand back on. Apparently the screws that secure the stand attach to the metal panel that covers the T conn board and those screws are just long enough to barely miss the board. Well, I am glad that I ordered a new T conn board because I ruined it. Good news is that I am getting sound and when I detached the T conn from the screen, half the picture went off. Funny it was the opposite side that went off then I assumed would would turn off. Thanks for the help locating the fuse though.
        • Lmterickg
          • Oct 2016
          • 13
          Well after ordering and installing the complete TV repair kit from shopJimmy.com which includes the T conn and power board, I am getting a blank screen after installation. The menu and source list is not showing up. The backlights are working but I am getting no images. Tried the flashlight test to see if images show up with the light and nothing. Any ideas on what steps to take next? I am still getting sound and it does seem to auto select the source coming in when I plug my computer into HDMI 1. The screen isn't white anymore so I guess that's one less thing as Forest would say.
          • CapLeaker
            Leaking Member
            • 8327
            probe the LVDS with an oscilloscope while turning the OSD menu on and off all the time. This will verify if the mainboard is putting out video first place.
            • cliff_hootarski
              • Jul 2006
              • 411
              Do what budm suggests in post #3. This will help determine if it's a bad panel or not.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Originally posted by cliff_hootarski
                do what budm suggests in post #3. This will help determine if it's a bad panel or not.
                +1
                • Lmterickg
                  • Oct 2016
                  • 13
                  Ok so I disconnected one ribbon of the T conn at a time and no change to screen. The backlights are on and still blank screen with no images. I was confused as to how I go from a white screen to black screen so I hooked up the old T-Con board and disconnected one ribbon at a time and one side goes dark while the other maintains the white screen somewhat. This happened with both ribbons. Attached are pictures of the ribbon removal test of the old T-Con board. I also noticed that the T-Con boards are different in some ways. I attached pictures of them as well. The old T-Con is connected and below the new one I purchased in the kit. Thanks again for any help.
                  • Lmterickg
                    • Oct 2016
                    • 13
                    Well turns out I ordered the wrong kit for my TV. Correcting this error now and ordered right part. I would still like confirmation that my panel is fine based on the diagnostic test results of one half the screen going dark
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • maxim2511
                      LG 55EC930V OLED - swich on swich of no screen
                      by maxim2511
                      My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                      Then I get an idea to take it apart and clean boards from dust.
                      In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                      Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                      05-14-2021, 02:21 AM
                    • TheDando
                      MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 Screen Connector
                      by TheDando
                      Hey guys I've got a MSI GS66 Stealth 11ue-007us Board Number MS-16V41 VER.1 with a broken screen connector on the motherboard.I was wondering how I would go about finding a exact replacement for it.I can't seem to find any schematics that would help me so I'm kinda stumped.I did buy a screen connector that I thought was close enough but it doesn't really invoke much confidence in me that it works perfectly as plugging the screen into sometimes does output a "glitchy" image for just a few seconds.So now I'm kinda in a cross road where I'm pretty sure it could be a faulty screen but I...
                      10-28-2024, 06:59 PM
                    • thesharpfella
                      Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                      by thesharpfella
                      Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                      07-23-2024, 10:37 AM
