RCA LED52B45RQ Will not turn on
  • nstlfrk
    • Apr 2014
    • 166
    So I have this unit and I can seem to pin point the issue. See pictures as well.
    1. On the power board the right plug with the on/off seems to have all power as it should. The on/off even registers with the touch of the power button.
    2. The bottom plugs that go to the LEDs measure around 80 volts. Is this correct?
    3. When you press the power button the LED on the front does turn on red and stay on till you press the button again.
    What am I missing or is there a common issue with these setups? Thanks in advance for any help regarding this.
    Re: RCA LED52B45RQ Will not turn on
    Need higher resolution pictures, I cannot read the labels for the connector pins when zoom in.
    • nstlfrk
      • Apr 2014
      • 166
      Here are some. Thanks
      • CapLeaker
        Leaking Member
        • 8326
        still cant read nothing, same as before.
        • nstlfrk
          • Apr 2014
          • 166
          Are there any other places you need?
            Any pin labels for the LED connectors?
            Also need straight shot of the bottom side of that power supply/LED driver board.
            • nstlfrk
              • Apr 2014
              • 166
              Here they are and the LEDS + reads 75 to 80 volts
                So if you leave the red probe on the LED+ and Black probe on the GND then turn on the TV, the Voltage on the LED+ did not jump up higher than 80V and then comes down to 80V later? The units look s to have 6 strings of LED and 6 LED controller circuits.
                • nstlfrk
                  • Apr 2014
                  • 166
                  The highest the voltage went was 81.9 volts and when you press the power button to turn the tv off it gradually drops to nothing.
                  By the way the led lights up red for stand by when off but goes off with no other colors when the power button is pressed
                  • CapLeaker
                    Leaking Member
                    • 8326
                    Measure all 6 strings.
                    • nstlfrk
                      • Apr 2014
                      • 166
                      All 6 measure the same.
                        You have 6 LED - for 6 strings of LEDs so ALL L- (3 per connector, pin 1, 2, 3 are L-, they are the Cathode return for each one the 3 strings) are all the same?
                        • nstlfrk
                          • Apr 2014
                          • 166
                          Yes they all 3 (as in the red ones) on each plug measure the same. Is this a good thing?
                          LED+ Measure 81.9 The others do not.
                            NOPE, I am talking about the L-, there are 3 pins for three L- (L MINUS), PIN 1, 2, and 3 of each LED connector.
                            • nstlfrk
                              • Apr 2014
                              • 166
                              Pins 1, 2, 3 all measure a ground. Pin 4 is open and pins 5, 6, 7 all measure 81.9 volts.
                              • CapLeaker
                                Leaking Member
                                • 8326
                                Is the backlight on?
                                • nstlfrk
                                  • Apr 2014
                                  • 166
                                  Nope
                                    'Pins 1, 2, 3 all measure a ground. Pin 4 is open and pins 5, 6, 7 all measure 81.9 volts.' so WHAT ARE the DCV reading of pin 1, 2, and 3? We know that you are getting the 81.9vdc pin 5, 6, and 7 FEEDING the Anode of the LED strings but we still do not know what all three Cathode return DCV are on each connectors. I AM NOT going to keep on asking the same question over and over again. At which post you tell us the DCV reading of L- pin 1,2, and 3?
                                    'Pins 1, 2, 3 all measure a ground.' What the hell does that mean?
                                    I asked for L- and you keep giving us the L+ readings:
                                    The RED WIRES ARE L+
                                    • nstlfrk
                                      • Apr 2014
                                      • 166
                                      For some reason I was not catching on as I re read all your statements I still did not GET IT.. Sorry to frustrate you. I will take this reading over my lunch hour and report back.
                                      Thanks for sticking in there and helping I do appreciate it.
                                      • nstlfrk
                                        • Apr 2014
                                        • 166
                                        BUDM
                                        Ok all 3 of the L- pins on both connectors measure zero when the power button is pressed to turn on and the stand by led is off.
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • DynaxSC
                                          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                                          by DynaxSC
                                          Hi
                                          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                                          08-04-2025, 12:20 PM
                                        • Woodsworth
                                          PS3 CECHC03 60GB YLOD Troubleshooting
                                          by Woodsworth
                                          I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                          START
                                          Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                          03-19-2024, 07:58 AM
                                        • robante15
                                          Acer Aspire 4520 won't turn on after reboot
                                          by robante15
                                          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                          If I remove the...
                                          04-06-2024, 06:50 PM
                                        • objecttothis
                                          EVGA 430W PSU Correct voltages but computer won't turn on
                                          by objecttothis
                                          I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
                                          02-08-2025, 11:19 AM
