EVGA 430W PSU Correct voltages but computer won't turn on
  • objecttothis
    • Oct 2024
    • 9
    I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch marks on the PCB. I'm knowledgeable enough to know that I don't want to go rooting around in this thing without the main cap being first discharged, but the most involved board repair I've ever done was replacing an HDMI port on a RTX 3070. All that said, it's not an expensive part to replace so I don't feel like I must repair it, but I want to try to repair it if there is an obvious part in the PSU that would cause shorting green to ground manually to turn the PSU on but it would not work to turn on the PSU with the case power button (which I assume shorts green to ground) when the ATX connector is plugged in (attempted on two different motherboards). Again, I believe it's something on the PSU because a different PSU works fine.
    • 31115
    check the power-good signal on the atx connector
    it tells the motherboard when the power is stable for the board to start up
      master hoarder
      • May 2008
      • 12175
      1st suspect here would be the 5VSB rail. Can you load it with something like 1 Amp of load and will it still be within spec? ... i.e. 5V +/-5%, (4.75 to 5.25V)
      If you have some 12V auto bulbs, that should be easy enough. IIRC, I'm using a 20W 12V bulb, and it draws right around 1 Amp of current at 5V. If the 5VSB circuit is faulty, this should show it.
      Now if the 5VSB is tested and found good above...
      my 2nd suspect would be that something might have happened to the voltage level of the PSU's PS_ON signal, where perhaps your server mini-board is not pulling it to a low enough level that it recognizes to know that it's supposed to turn on. In other words, if your server mini-board is only pulling the PS_ON signal down to something like 0.5V, but the PSU is expecting to see it lower that, say, 0.3-0.4V for example.
      To check for this, connect the PSU to your mini-server board, but do NOT connect it to AC power yet. Next, take a multimeter and connect the black probe (-) to a ground wire and connect the red probe (+) to the PSU's PS_ON signal wire (just shove it in the ATX connector as it's plugged into the motherboard.) Now turn on the multimeter and connect AC power to the PSU, watching what the PS_ON signal line does. Hopefully you should see it go up and stay above 3.3V. Now press the power button on the computer (or motherboard) and see what value does the PS_ON go down to. Also look if the PSU fan spins up briefly and stops or not, as that may indicate a different problem not related to the PS_ON line.
      And that's about all I can think of right now.
      If you can, maybe post some pictures of the insides of the PSU as well. Sometimes it's good to see what you're seeing, in case we see something that you don't.
      • redbomb65
        msi mpg z390m gaming edge ac missing voltages and wont turn on when pressing the power button
        by redbomb65
        hi i have a msi mpg z390m gaming edge ac mb. that wont turn on when i short the 2 pins on the front connectror.
        im new in electrionic repair. and i hope that someone will share a bit knowledge, thoughts or ideas with me and others, to repair that damm thing ;D
        1. thought psu problem. nope psu is good. i even bought a psu tester to be save.
        2. thought a short somewhere that the psu goes in short save mode. nope... no short to measure with my multimeter to ground. psu and mainboard starts with all cabels plugget in, when i bridge green and black on the 24 pin.
        cpu isnt...
        01-24-2024, 08:36 PM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • novice1
        Acer Aspire E5-574G - Not Powering On
        by novice1
        Laptop name Acer Aspire E5-574G. Processor = i7-6500u. GPU = NVIDIA GEFORCE 940M. Motherboard Model = DA0ZRWMB6G0
        This laptop was not powering on at all so I started investigating. The blue light would come on for a second, and then disappear. Fan would sometimes turn on for a second and then shut off immediately, and at other times would not turn on at all.
        To start with, about 3 months ago I had no clue about soldering, motherboard schematics, board view, and then I stumbled about this forum and other stuff online. I have never done any of those before. But to ask...
        11-03-2023, 05:53 PM
      • Capacitorial
        Powersupply has all the voltages - Monitor still no power
        by Capacitorial
        Hello guys,
        I have a Philips 240B7QPJEB. The monitor seems completely dead.
        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
        The weird thing is, that the Power LED is powered over the TCON board.
        On The TCON...
        12-28-2024, 02:12 PM
