Samsung 50" TV flashing power light
    When you remove the plug from the main board to the power board the back-lights all start flashing, what voltage should the BLU on/off be.
    Re: Samsung 50" TV flashing power light
    0 research done I like it. Bl should be I believe 1.5-3v or so.
      Is this BLU on/off the same as the Pl on/off, because when I check the circuit I get a dead short between the two pins
        Is that with the Mb unplugged ?
          Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
          Also model number of the tv please
            Thanks for the offer but all I wanted was an answer to the question.yes that was with the board laying on the bench.
              Pffft. How would you suppose we should help you without any model number or pics of the TV ? Is it a LED or a LCD or what?
              If it is a LED, Id be checking the LEDs in the panel first.
              As for your question: I am not so sure you should be poking around that thing too much without knowing very basic things what PSon and BLon pins actually do.
                I have worked on Radar systems and naval missiles systems and I have been fixing TVs for sometime but from time to time some thing new comes out that one needs some information on and this is the case.And in the first comment I said that when the Main Board is disconnected the LED are flashing.
                  So the backlights are flashing.
                  What is the power supply board part number? BN44-??????
                  Model number of the TV?
                  BL-ON (BLUON) is steady state DC. BL-ON is usually >2.5Vdc = ON, <1Vdc = OFF, BUT some of the SAMSUNG board uses 0.7Vdc = ON, <.2Vdc = OFF.
                    Hi budm, backlights are flashing with the MB disconnected. power supply board is a BN44-00617A, Model number UE50F6200AKXXU
                      Research how to test led backlights.
                        Hi Budm can you simulate the BLU voltage with 3 batteries, for test purposes
                          take a 1k ohm resistor and jump 5V STBY to BLon
                            Would be nice if someone said some thing " we do not know about this problem" or just go away or is this system not working anymore
                              easy for you to say... we don't even have a picture of your PSU so we have something to look at. I think you should know with 114 posts on your account, that we need pics. Other than that it's just guessing around.
                              Your TV is a LED. You may have a bad LED and nothing wrong with the PSU. In order to test the LEDs, you have to take the panel apart. There are tons of threads here about that.
                                Yes have taken the panel apart and have said before all the LED are working I can see the all flashing, I think it is the Power board but cannot find and diagrams, there is no bulging capacitors.
                                  Only because you see that all LED's are flashing, it doesn't proof that all LED's are O.k. There may be one that is intermittent, may be a bad connector somewhere etc.
                                  Power the led strips externally and see what happens
                                    Does anyone have a diagram for a BN44-00617A, this is from a Samsung UE50F6200AKXXU television, or know where to get one
                                      Check google or Toms site.
                                        Have already checked
