Samsung 50" TV flashing power light
  • keithf2
    • Aug 2010
    • 131
    When you remove the plug from the main board to the power board the back-lights all start flashing, what voltage should the BLU on/off be.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung 50" TV flashing power light
    0 research done I like it. Bl should be I believe 1.5-3v or so.
    • keithf2
      • Aug 2010
      • 131
      Is this BLU on/off the same as the Pl on/off, because when I check the circuit I get a dead short between the two pins
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Is that with the Mb unplugged ?
        • sordids999
          • May 2013
          • 2149
          Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
          Also model number of the tv please
          • keithf2
            • Aug 2010
            • 131
            Thanks for the offer but all I wanted was an answer to the question.yes that was with the board laying on the bench.
            • CapLeaker
              Leaking Member
              • 7967
              Pffft. How would you suppose we should help you without any model number or pics of the TV ? Is it a LED or a LCD or what?
              If it is a LED, Id be checking the LEDs in the panel first.
              As for your question: I am not so sure you should be poking around that thing too much without knowing very basic things what PSon and BLon pins actually do.
              • keithf2
                • Aug 2010
                • 131
                I have worked on Radar systems and naval missiles systems and I have been fixing TVs for sometime but from time to time some thing new comes out that one needs some information on and this is the case.And in the first comment I said that when the Main Board is disconnected the LED are flashing.
                  So the backlights are flashing.
                  What is the power supply board part number? BN44-??????
                  Model number of the TV?
                  BL-ON (BLUON) is steady state DC. BL-ON is usually >2.5Vdc = ON, <1Vdc = OFF, BUT some of the SAMSUNG board uses 0.7Vdc = ON, <.2Vdc = OFF.
                  • keithf2
                    • Aug 2010
                    • 131
                    Hi budm, backlights are flashing with the MB disconnected. power supply board is a BN44-00617A, Model number UE50F6200AKXXU
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Research how to test led backlights.
                      • keithf2
                        • Aug 2010
                        • 131
                        Hi Budm can you simulate the BLU voltage with 3 batteries, for test purposes
                        • CapLeaker
                          Leaking Member
                          • 7967
                          take a 1k ohm resistor and jump 5V STBY to BLon
                          • keithf2
                            • Aug 2010
                            • 131
                            Would be nice if someone said some thing " we do not know about this problem" or just go away or is this system not working anymore
                            • CapLeaker
                              Leaking Member
                              • 7967
                              easy for you to say... we don't even have a picture of your PSU so we have something to look at. I think you should know with 114 posts on your account, that we need pics. Other than that it's just guessing around.
                              Your TV is a LED. You may have a bad LED and nothing wrong with the PSU. In order to test the LEDs, you have to take the panel apart. There are tons of threads here about that.
                              • keithf2
                                • Aug 2010
                                • 131
                                Yes have taken the panel apart and have said before all the LED are working I can see the all flashing, I think it is the Power board but cannot find and diagrams, there is no bulging capacitors.
                                • CapLeaker
                                  Leaking Member
                                  • 7967
                                  Only because you see that all LED's are flashing, it doesn't proof that all LED's are O.k. There may be one that is intermittent, may be a bad connector somewhere etc.
                                  Power the led strips externally and see what happens
                                  • keithf2
                                    • Aug 2010
                                    • 131
                                    Does anyone have a diagram for a BN44-00617A, this is from a Samsung UE50F6200AKXXU television, or know where to get one
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Check google or Toms site.
                                      • keithf2
                                        • Aug 2010
                                        • 131
                                        Have already checked
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • JDC
                                          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                          by JDC
                                          ONN 100012588
                                          Issue: No Power, Then Rebooting After Main Board Change
                                          Short answer: replace main board and power board
                                          Technical answer: replace main board and Q306 & Q307 on power board.
                                          Long answer:
                                          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                          07-15-2022, 07:39 AM
