[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
  • Destroyer-Br
    • Feb 2023
    • 23
    • Brazil
    I'm working on an Acer Nitro 5 unit with the following specs:
    • Motherboard: LA-J871P Rev: 1B
    • Model: Acer AN515-55-59MT
    • S/N: NHQ7JAL00403906A973400
    • SNID: 03902728734
    Initial Issue
    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled for testing—it worked. Disassembled once more to show the client the GPU condition, and on the final reassembly (with no physical damage or errors), the board completely stopped powering on.
    Findings So Far
    • Super I/O was shorted. Replaced with a brand-new one (pre-programmed).
      → Short is gone, but the board still won't power on.
      → Power supply draws only 0.013A (13mA).
      → Pressing power button or shorting PWRBTN pads does nothing.
    • ON/OFFBTN# line shows 3V, and when shorted manually (or using keyboard), logic state changes → Super I/O receives the signal, but no reaction afterward.
    • Replaced Super I/O again, this time using one from a donor board (same model & revision). Perfect solder job, aligned, inspected under microscope → No change.
    Power Rails & Signals
    • +3VALW is missing
      → Should be enabled by the Super I/O, but the EN signal is not generated.
    • Replaced PCH (Platform Controller Hub) and reprogrammed BIOS chip with a clean firmware → Still no change.
    • Verified:
      • 19V input present
      • +3VLP present (feeding Super I/O)
      • +5VALW present
      • PU301 replaced (no change)
      • +1.05VALW impedance OK
      • No shorts on CPU/GPU VRMs, audio, or network ICs
      • All components appear intact visually – no burns, no missing parts
      • Board is clean, no soldering accidents
    • Tested by injecting voltage manually into +3VALW rail (with previous PCH)
      → PCH slightly warmed up
      → No abnormal consumption or heating elsewhere
    Current Status
    • Board does not power on
    • All major voltages present except for +3VALW, which depends on an EN signal from the Super I/O
    • Super I/O receives power and ON/OFF signal but does not release EN to trigger power sequencing
    • I've exhausted the typical troubleshooting steps and now I'm stuck.
    Request for Help
    I strongly suspect the issue lies in the Super I/O logic or some missing condition it needs to allow the EN signal to be generated.
    If anyone has experience with this board or similar behavior, what conditions must be met for the Super I/O to enable the +3VALW rail?
    If you need voltage references or specific measurements, let me know—I'll provide whatever is needed.
    Thanks in advance!
  • Destroyer-Br
    • Feb 2023
    • 23
    • Brazil
    Additional Info
    Just to complement the information:
    • No signs of low impedance, shorts, or high consumption around JPQ1, JPQ2, or after UQ2.
    • I also tested by injecting 3.3V via PJ302 (with 19V present and the board switching 5V by itself).
      → The board draws 0.184A (184mA) in this condition.
    Regarding the initial short on the Super I/O (which was the first component replaced):
    • The short was located on the +3VLP line.
    • After replacing the Super I/O, the impedance returned to normal, the short was gone, and the +3VLP rail came back as expected, as mentioned earlier.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      +3VALW will come up only after triggering the mb as per power sequence but EC_ON should be present in off condition(seems contradictory to me).
      Have you checked RTC circuit? Main bios flashed?
      Have you checked resistance to GND on switched rails like +3VS/5VS etc.(Pg 78)?
      • Destroyer-Br
        • Feb 2023
        • 23
        • Brazil
        My response:
        Thank you for your comments. I think you may have misunderstood some parts of my explanation, so let me clarify:
        1. +3VALW Sequence
          You're correct that +3VALW only appears once the board is triggered—so I did read the start‑up sequence properly.
        2. EC_ON
          EC_ON is present even when the board is off. I confirmed this because I'm seeing +5VALWP generated by PU502, which receives 5V_EN via EC_ON directly from the SIO.
        3. Main BIOS (UT5)
          Asking whether the main BIOS is “working” doesn't make sense in this context: if the board never reaches the start‑up sequence, you won't even see +3VALW at the EEPROM pin—so it can't possibly be operating.
        4. Switched Rails (+3VS/ +5VS)
          I checked for low‑impedance shorts or unexpected current draw around JPQ1, JPQ2 and downstream of UQ2 and found none. Here are the measured resistances to ground after UQ1:
          • +5VS (after JPQ2): 3.78 kΩ
          • +3VS (after JPQ1): Rising infinitely on high‑ohm range until it eventually zeroes
        5. RTC Circuit
          Everything looks fine here:
          • DH1: 3.21 V at pin 3 (+CHGRTC)
          • +VL_RTC (pin 1): 3.00 V
          • RTC battery pin (pin 2): 0 V with the coin cell removed; restores to ~3 V when installed
          • I also verified +3VL_RTC at the PCH side—across CH47/CH48 and RH99/RH98/RH51.
        Any other ideas on what I can test next?
        • Destroyer-Br
          • Feb 2023
          • 23
          • Brazil
          Just to clarify, the correct motherboard model is LA‑L181P, not LA‑J871P.
          • Destroyer-Br
            • Feb 2023
            • 23
            • Brazil
            up
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Your problem perhaps is classic acer thermal protection for SIO detailed on page 58 of LA-L181 schematic.
              3V_EN_R is present?(I know 3V_EN is missing)
              • Destroyer-Br
                • Feb 2023
                • 23
                • Brazil
                [REPAIR REPORT] Motherboard with unstable power consumption – suspected faulty PCH or enabled Boot Guard
                Hello fellow techs,
                After a full day of troubleshooting, I've decided to call it quits on this board. I'm sharing all the steps and findings here — maybe it'll help someone else or spark new ideas.
                🛠️ Diagnosis and Repairs:
                • Initially, the board was completely dead.
                • I found PQ201 was leaking, which was disrupting the BI_GATE signal from Q1A/B, responsible for EC_RST#.
                • After fixing that, I regained EC_RST# and MAINPWON, both at 3.3V.
                • The board showed a blue LED, but the power draw stayed at just 0.02A.
                ⚙️ Actions Taken:
                • Replaced both PCH crystals YH1 and YH2.
                • The board began powering on intermittently with consumption up to 0.70A, but would sometimes drop to 0.40A.
                  • In these moments, only GPU and PCH warmed up.
                  • The CPU VRM remained partially inactive.
                • At times, it would revert to 0.02A again.
                🔍 Odd Behavior:
                • Occasionally, depending on where I touched the board (no clear pattern), the current would spike to 1.3A or even 1.8A.
                  • The CPU got very hot, and the PCH also heated up.
                  • Still, no reset occurred — the board showed typical "no POST" behavior (power cycling without boot).
                • Reflashed the BIOS, cleaned the board thoroughly, and reflowed many points — no improvement.
                • I tested countless signals — too many to list here.
                📏 Notable Measurements:
                • Signal H_PLTRST_CPU# was only 1V (resistance measured at 1108Ω).
                  • Expected: close to 10KΩ.
                • VR_ON signal present at 3.3V.
                • PLT_RST# also had 3.3V.
                • Unfortunately, I couldn't check the crystal clocks or SPI bus signals, as my oscilloscope can't handle those frequencies 😔.
                🧩 Final Status:
                • I managed to get the board into S0 state.
                • But from there, I couldn't progress any further.
                • Suspicions:
                  • Faulty PCH (possibly received a bad chip).
                  • Possibility that the machine had Boot Guard enabled, and replacing the PCH broke the security key handshake, blocking communication.
                Thanks to everyone who followed and contributed during this repair attempt!
                Unfortunately, this time I had to give up. Still, the experience was full of learning.
                Cheers!
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • ongobongo
                  Asus ROG Ally - Super IO Chip replacement
                  by ongobongo
                  anyone here who has experience with replacing the super IO chip of an ROG ally?
                  I have one on my bench which has a burnt super io (ITE 5125VG-192). On some devices the super-io downloads it's firmware from BIOS if it's empty. As i don't have a programmer for this chips i hope someone here has already changed the chip and can give me a hint if it's working with an empty chip if it needs external programming.
                  Ongo
                  11-17-2024, 11:27 AM
                • Loki_Fido
                  Clean ME for VAIO please. Super I/O just got replaced
                  by Loki_Fido
                  Hi ya folks,
                  Hope everyone's having a nice day.
                  I recently replaced the super I/O chip and now I believe i need a clean ME for the system to come online. Cause i started the laptop and it did not start.
                  Laptop details
                  Sony VAIO
                  Product name VJS111
                  Model Number VJS111D12N
                  Serial Number 7014633
                  Motherboard markings
                  FEILONG MB REV 1.03B
                  UMT-KS 2V 94V-0 E49068 A7 1545 07-01
                  Original bios file attached
                  SUPER I/O chip model ITE IT8528VG
                  Thanks a million in advance folks...
                  05-11-2025, 11:40 PM
                • Paul20
                  Swap Super I/O Lenovo Ideapad
                  by Paul20
                  Hi, I would like some advice.
                  I have two motherboards, one with a dedicated GPU and the super I/O with obvious burn marks on it, and another working motherboard without a dedicated GPU.
                  My question is: can I swap the super I/O from the motharboard without dedicated GPU to the one with dedicated GPU? Will it work anyway or is that super I/O taken from the motherboard without GPU only good on motherboards without dedicated GPU?
                  The motherboards are exactly identical even in terms of versions...the only difference concerns the dedicated GPU in one and not in the other.​
                  11-27-2023, 10:47 AM
                  Thermal pad thickness for various laptop GPU / Graphics Cards
                  ASUS Dual RTX 2070 OC 8GB
                  ASUS ROG STRIX RTX 3080 OC
                  ASUS ROG STRIX RTX 3090
                  ASUS TUF Gaming RTX 3080 OC Edition
                  ASUS TUF GTX 1660 S-O6G GAMING
                  EVGA RTX 3060 Ti XC GAMING 8GB
                  EVGA RTX 3060 XC GAMING 12GB GDDR6
                  EVGA RTX 3080 FTW3 ULTRA GAMING
                  EVGA RTX 3080 TI FTW3 ULTRA GAMING
                  EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                  Gainward RTX 2080 Phoenix GS Specs
                  Gainward RTX 3070 Phoenix 8GB
                  Gainward RTX 3080 Ti Phoenix
                  GIGABYTE AORUS RTX 3080 MASTER 10G
                  02-09-2024, 08:08 AM
