Polaroid P40LED13 powers up then shuts down
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Polaroid P40LED13 powers up then shuts down
    Your mb is at fault still, you need to heat it up and see if it shuts off faster.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Freeze spray U46 common fault on thse see if it stays on longer.
      • london-freddie
        • May 2015
        • 472
        spent far too much time now warming boards and components nothing seems to make it shut down, just seems to do it when it feels like it sometimes 10 - 15 mins sometimes 30 -45 mins between shut downs. I have noticed though it seems to start back up pretty quick certainly a lot quicker than a normal power up from switched off.
        Is it possible I have installed the wrong core update, or would it just not start with wrong update.
        May try and source a used mainboard and put that in
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Did you download the Vestel Driver 17mb82-2 ? Also got image of the menu system ? Also dont give up yet I wouldn't, if you do I have a board for this set for £20.
          • london-freddie
            • May 2015
            • 472
            think update i got off vesteldriver.com was 17mb80*** awkward as all in turkish, I think it is still a software fault on this tv
            mainboard number is 23115995 23115994
            do you want a picture of menu if so which page of menu
            may well have the board off you if it will sort this tv
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #26
              Just the menu in general. Also link I use:
              http://www.vesteldriver.com/TV_MB82_CORE_UPDATE.html
              • london-freddie
                • May 2015
                • 472
                Yes that is the link that i used to download from MB82 V.0.84
                just powered up the tv again to take pics of menu, while taking them tv switched off about 6 times different colours on screen each time red, green, pink etc
                will download pics in a few minutes
                • london-freddie
                  • May 2015
                  • 472
                  menu pics
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Thats really odd, at this point Im unsure whats causing it to crash like this mate with out having it in front of me Will have a check on the web and let you know if I find anything got to be firmware related unless you missed something obvious. I presume you left the Usb in till the set came back on too ?
                    • london-freddie
                      • May 2015
                      • 472
                      update!!!! replaced mainboard tv now been working fine for nearly a week now, thanks again all
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Good work
                        • speedypro
                          • Feb 2013
                          • 561
                          #32
                          I, too, have this same issue. Used air can on chips but tv turns on then back off. Are you saying this is a MB and not a power board issue?
                          Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
                          • Alastair E
                            Chief Womble
                            • Mar 2013
                            • 1963
                            • U.K.
                            #33
                            Corrupted F/W on mainboard causes this fault. on the MB82 Vestel...
                            TELEFIX
                            • speedypro
                              • Feb 2013
                              • 561
                              #34
                              I have downloaded the firmware, in this thread, and it updated. Once the tv finish updated the tv powers on but instantly shuts off. Same as before.
                              • speedypro
                                • Feb 2013
                                • 561
                                #35
                                Update. Nothing to do with F/W. Ive remove the led red/black wire from psu and shine a light on tv and I can see images so led driver fail. What to replace?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  Charles Hyde do an USB stick firmware update
                                  http://www.chsinteractive.co.uk/elec...d-p40led13.htm
                                  • speedypro
                                    • Feb 2013
                                    • 561
                                    #37
                                    LED issue, not F/W. Works if backlight wire removed from psu
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #38
                                      probably a shorted led time to strip down and test them i guess
                                      • speedypro
                                        • Feb 2013
                                        • 561
                                        #39
                                        Yup! I will decline. Last time I cracked the screen! It's sooo.....thin. I'll tell the customer I can repair it.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #40
                                          yes that whats bothers me with customers sets too be honest if it was my own i would try the repair, the last 40 in set i repaired i used some think lining wallaper and slid it slowly under the lcd glass then gripped both sides of the lining paper and lifted the lcd up (so acted like a support i guess) it worked ok plus no finger prints on lcd/diffusers.I do find putting the plastic lcd surround back on the hardest thats how i cracked one.
                                          • lowpost99@gmail.com
                                            Help with Dell Latitude E5470 that shuts down when moved at all. Powers up, but no charge, power jack has brown burn marks
                                            by lowpost99@gmail.com
                                            I have a Dell E5470 that powers up and boots windows no problem. Using a non-standard universal type charger, it shuts down immediately if moved, (power short in that charger or AC power jack) because the battery has no charge and isn't charging orange/white lights blinking on the front. When first powered up, BIOS power alarm stated that it could not detect the voltage setting and I had to dis-able the message to get past this. It got into Windows fine, as long as not moved, so I dis-assembled it looking for a cold solder joint on the power jack that I thought might be lifting off the MB, but...
                                            09-03-2024, 02:57 PM
                                          • platinumsteel
                                            hp labtop 15-db008 Powers On then Shuts Off
                                            by platinumsteel
                                            Hi guys have an issue with a friends labtop that has no signs of liquid damage.They said it just stopped turning on.When i press the power button it turns on normally like 35-500millamp draw and it posts and i have picture. But like after 4 seconds after it posts an image it shuts off completely.If i press power button again same thing happens. Did all basic troubleshooting with the motherboard like fresh thermal paste with it completely out the chasis with battery disconnected. Thermal camera shows these two mosfets heating up more than anything else when i press the power button.I have provided...
                                            10-28-2023, 10:51 AM
                                          • survivalbloke
                                            Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                                            by survivalbloke
                                            I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                                            Any ideas?
                                            01-08-2024, 12:12 PM
                                          • huzo
                                            HP Omen shuts down when loading OS
                                            by huzo
                                            The model is 15ec-1061nm
                                            Board number is DAG3EDMB8D0​
                                            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
                                            10-29-2024, 12:05 AM
                                          • malogro
                                            Acer Nitro 5 AN515-55-55M1 [GH51G mb] powers on, no vcc_core
                                            by malogro
                                            Hello all,
                                            I'm stumped on this guy, so wanted to see if anyone has any further ideas:
                                            Intro:
                                            This is an Acer Nitro 5 AN515-55-55M1 with unknown prior history (bought "as-is" on eBay). It charges the battery and powers on from both AC adapter and battery, so I think this rules out main power issues.
                                            Upon attempt to boot, it will "reboot" (meaning powers down and then powers on again) only once, and then stays stuck in a status of lights on / no post / no monitor. Powering on with fn+esc maxes out the fans on first boot attempt,...
                                            04-14-2023, 04:44 PM
