vizio m601d-a3r panel or tcon failure
  • crosstalk
    • Feb 2014
    • 68
    • Usa
    Hello. I have a vizio m601d-a3r with a sharp panel. Trouble is a few horizontal lines and left side is quite dark. Backlight seems ok. I have tried cleaning/reseating the ribbon cables, but no change. Tab bonds don't seem to affect the picture either.
    I am thinking bad panel, but want to get your opinion on whether you have seen this kind of failure with a tcon.
    Re: vizio m601d-a3r panel or tcon failure
    Horizon line like that will be the panel.
    • crosstalk
      • Feb 2014
      • 68
      • Usa
      Thanks--I was thinking the panel also (gate drivers). I have read the long 70" vizio thread about removing gate drivers on one side. Not sure it applies to this panel, I might pull off the gate driver chip tab on the bottom of the left side just to see what happens.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Deffo panel failure. Try removing tabs but doubt it will make it any better.
        • crosstalk
          • Feb 2014
          • 68
          • Usa
          Thanks again. At least I didn't pay anything for it--I did have to go pick it up though.
          • Nick's Tvs
            • Jan 2014
            • 621
            Crosstalk
            I don't see lines from your picture you posted. Looks like it could be the left side LED strips going out.
            If you were to remove the panel, can you see if the left LED strip lights up?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Originally posted by Nick's Tvs
              Crosstalk
              Look closer lol, horizontal as well.
              • Nick's Tvs
                • Jan 2014
                • 621
                Oh yeah that first picture the white line looks like its part of the commercial but second picture I see what you are talking about.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Yeah he did say the Bl seems fine, I presume he meant on that side
                  • crosstalk
                    • Feb 2014
                    • 68
                    • Usa
                    Yes--backlight is uniformly illuminating. I was hoping from the original description of the problem that the "darker on the left" description was a backlight problem.
                    • asot550
                      • Dec 2017
                      • 5
                      This is a really old thread, but my panel looks almost exactly the same as yours with the horizontal line in nearly the exact same place. Did you ever figure out if it was the panel or if the gate drivers were causing an issue?
                      • crosstalk
                        • Feb 2014
                        • 68
                        • Usa
                        I scrapped it as a bad panel.
                        • budwich
                          • Jul 2015
                          • 3097
                          Its a "panel issue"... it doesn't matter whither is a gate driver issue or "panel" problem (you threw something at the display, cracked the screen), neither are "fixable"... BUT the panel can be "saved" in these kinds of cases by removing the tabs cables from the failed side. This has been done by a lot of people and lots of thread "post this time period" that "discovered" this "technique". IF you are using the tv for just "normal viewing", odds are that you won't notice the difference between a "saved tab operation" and the original tv display.
                          • asot550
                            • Dec 2017
                            • 5
                            Great, thanks budwich! Time to do some surgery on this guy! Found it in the garbage so if it doesn't work out I'm not out anything but my time.
                            • asot550
                              • Dec 2017
                              • 5
                              For posterity, I was able to get things working again with the tab trick! Here's the steps for anyone that stumbles on this in the future:
                              https://www.badcaps.net/forum/showpo...44&postcount=8
                              • budwich
                                • Jul 2015
                                • 3097
                                yep.... Lucky the "scrapper" wasn't scrapped... :-)
                                • howardc64
                                  by howardc64
                                  Yesterday, 05:17 PM
                                • x_orange90_x
                                  TCL 50S535 bad tcon or panel issue?
                                  by x_orange90_x
                                  Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                  03-29-2025, 11:02 PM
                                • advant
                                  by advant
                                  02-03-2020, 12:25 AM
                                • mmartell
                                  General Questions on the Relationship Between Mainboard, TCON and Panel
                                  by mmartell
                                  My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                                  I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                                  And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                                  01-06-2024, 01:32 PM
                                • Lee M.
                                  Amazon Fire TV Omni K24NE5 tcon or panel bad?
                                  by Lee M.
                                  TV came on with BL on but blank screen. Disconnected one of the ribbon cables from tcon to panel driver board and now I have half of the screen working normally. Any way to tell if the problem is with the tcon or the panel driver board or the panel itself? Should I just replace the tcon and see what happens?
                                  05-12-2023, 05:47 PM
