Sony KDL-65W850A Dead
Re: Sony KDL-65W850A Dead
BTW I had trouble removing the LEDs without damage to the board, and using a hot air station I melted the lens slightly on this one, what temps are you using?Comment
Well I finally got the correct LEDs and replaced the bad ones. They now all light up with the tester. But still same problem, TV flashes backlight LEDs for a split second then goes out, flashing continuous green/orange on the front LED. (a code I cannot find a descritption for)
Now I'm wondering if it is a main board problem, considering the original one was bad. Is it possible this main board is bad, or an eeprom issue??Comment
Each string is right around 70V. When one was out, it would be around 65-66V.Comment
Yea I just saw that in the SM
Error of panel ID:
Green Blinking
Orange
Blinking
Blinking:0.5sec On / 0.5sec
Off
So main board may be from different panel? Will swap of IC1100 fix this?Comment
first try in service menu if there is panel id change option.
if you can not enter service menu, then try to update software with pen drive,
Regards.Comment
I don't think it will work, it clicks off in 1/2 a second then will not turn back on til unplugged. I am not sure I can find the software either.
Will switching that IC work if not?Comment
if it refuse to go stand by then you are not able to edit service menu.
best way to try changed the IC. give try, but at end you need also to rewrite the firmwareComment
I can get it in standby mode, but once I hit power it it flashes and goes to the flashing green/orange. What's the procedure for getting to the service menu?Comment
service mode... Press “i+ (info)”, “5”, “Volume +” then power on
first try to inter from stand by mode Self Diagnosis Display -Press “i+ (info)”, “5”, “Volume-” then “power onComment
By standby condition, they mean just plugged in to power but TV off correct?Comment
Unfortunately the panel is all taken apart, I want to make sure what's wrong before reassembling... Would swapping that IC resolve a panel ID error? Is there also an eeprom IC that could be the problem?Comment
by thstuffA) TV initially dead
B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
C) Was able to perform a Reset from Settings menu and completed out of box configuration.
D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical... -
by bohabohaHello to everyone in this wonderful forum.
I have this SONY LCD TV KDL_46R473a
PSU GL5 APS350 :1-888-122- 12
MAINBOARD FY13_EU IP-012C101-4010
black screen ,no STB no life almost death.
on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
Also 3,5,and 12v are on.
nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
don't know what to do next all suggestions and advice are very welcome... -
by TalynHi,
My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
Any advice? Thanks! -
by mrsithHello again lifesavers.
I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I... -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
Channel: Schematic Requests ONLY!
- Loading...
