Sony KDL-65W850A Dead
    Re: Sony KDL-65W850A Dead
    The thread was long so I did not read the whole thing.
    The BL_ERROR, when TV is in standby, it should be around 3VDC, when the TV is turn on and no error is detect then it should go low and stay low, if the error is detect then it will will go back high to indicate problem, that is what is used n most SONY TV.
    No error code blinking LED on the front panel?
      BTW, I did not find the SM at ELEKTROTANYA, can you provide the link to the SM?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        Hi Budm, That's the problem. All I have to go on is the pictures provided in an earlier post and they are not very clear.
        • kevinm34232
          • May 2012
          • 1884
          Here's a few more pics, I'll be back in a few mins, thanks for the help!
          • kevinm34232
            • May 2012
            • 1884
            I had to buy the service manual online, it's 40MB, if you have somewhere I can upload it let me know, or I'll zip it and email you guys.
            I didn't find it super helpful so far.
            I can take better pictures of whatever you need too, thanks.
              Does the SM say anything about blinking LED Error codes?
              • kevinm34232
                • May 2012
                • 1884
                Yes there's quite a bit, more than this... I get no LED flashing at all though.
                • kevinm34232
                  • May 2012
                  • 1884
                  [Service Manual]
                    It is strange that you are not seeing any error blinking codes.
                    I will have to download the SM when I have the time to look through them.
                      Post 14:
                      But I was not able to jump the backlights on, I tried applying 3.3v to BL_ON along with PS_ON but nothing. It actually drags the 3.3v down.
                      That 3.3V does not sound right for it to be dragged like that.
                      • kevinm34232
                        • May 2012
                        • 1884
                        Well I don't know what the reason is, but using the 12V to the BL_ON with a 1K resistor, the voltage drops to 6V on the BL_ON, whereas the REG+12V says at 12V everywhere else.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Well the only voltage present at first is the 3.3V standby at the main board. The SM is then saying to check DC/DC converter. However, that voltage comes from the REG+12V, which only comes up when I jump PS_ON.
                          It would seem according to the SM it should be there in standby, but I am not sure.
                          Also, those test points it says to check on the main board, have no no idea what they are asking to check. They seem to point to nothing on the board.
                          • kevinm34232
                            • May 2012
                            • 1884
                            Any way by looking at those 2 power boards to know if the one to the left should have voltage at the rectifier when just plugged in? 120VAC is being supplied from the other board as shown, but only the primary board has power. Also note that the PS to right has 166V at the main caps, and 396V when PS_ON is on.
                            • Diah
                              • Feb 2013
                              • 6614
                              photo No 1, disconnect the following
                              socket from main board to audio driver
                              LVDS from main boards to T-CON
                              power on and tell which voltage you get.
                              Sony some how had no standby LED, just LED turn on at normal operation and can turn it off via menu
                              • kevinm34232
                                • May 2012
                                • 1884
                                Nothing changed..
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  i tip 90% main boards dosnt boot and send signal to PWB, freeze or heat the main boards chips then plug it on ..and check result of LED status flashing or not.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    #57
                                    Unfortunately the service manual doesn't help with the power supplies.
                                    The two boards are connected together with the white/black wires. Is there mains on both boards at the white connector points. I also see 2 white ceramic fuses on the one board by the mains in. Have they checked out as OK?
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #58
                                      APS-352 and APS-356 is second PS. BTW the second PS board, AC is connected from one to the other, but I only 1 have 1VAC at the 2nd bridge rectifier, not sure if it is supposed to kick on with a relay somehow..
                                      You say you only have 1VAC on the 2nd bridge but which bridge is it. Is it on the 352 or 356 board and what is it's component number.
                                      Photo's courtesy of Shopjimmy
                                        The Bridge on the LED power supply 356 will not get any AC to the bridge untel the board get the BL-ON signal to turn on the power relays RY6102/6103 to supply AC to the bridge D6101.
                                        Right now we know that the main board has at least one problem, it is not sending the PS-ON to turn on the power supply board.
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #60
                                          You won't have any AC voltage on bridge rectifier D6101 on the APS-356 until the relay operates. This is a 12V dc relay. Measue the coil resistance which had diode D6616 across the terminals with your meter set to ohms. It should be 12 ohms.
                                          Edit
                                          Updated coil resistance in later post
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mrsith
                                            Sony KDL-55W755C - Dead
                                            by mrsith
                                            Hello again lifesavers.
                                            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                            11-28-2022, 12:42 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
