Dead Vestel 17IPS71 power board
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Dead Vestel 17IPS71 power board
Im just going to throw my 2 pence in. Dont give up on this, keep following Buds advise. It will work out just keep trying. I want to see this work out.Last edited by ReeceyBurger123; 05-03-2016, 03:05 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
I to would agree at this point. Nothing to lose changing it, but everything to gain.Willing to help but I'm no expert.Comment
I would be suspicious of C296 a 1uF 50V smd capacitor? London-Freddie does your meter have a capacitance checker so you can test it?Willing to help but I'm no expert.Comment
@reece, do you have any of the Vestel board that uses the 6300 IC that may be you can try taking some resistance measurement on?Never stop learning
He can try removing that MLCC cap which is in parallel the Lytics cap for filtering the Voltage on the VDD pin and see.Never stop learning
I have this same Psu in another Tv which I will be taking a look at tomorrow. So will get reading then with the same Psu. That wont be till about 4pm tomorrow when I finish college and have a look at that set though.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
no meter does not have cap test
are we saying change IC U202 FAN6300Comment
Great, that will give us some idea as to what the resistance readings should be to see if we are in the right path.Never stop learning
Just checking some that I have on hand now.
17IPS19 uses Fan 6724
17IPS11 uses Fan 6724
17IPS20 uses Fan 6724 on both switching transistors.
So will get the IPS71 out tomorrow and get a look. Hopefully it uses the same chip as all Vestels differentiate in the design.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
can you point me in the direction of that MLCC cap to remove pleaseComment
If that checks out OK then I would wait and see what information ReeceyBurger123 can offer you tomorrow.Willing to help but I'm no expert.Comment
Readings coming shortly.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Right heres what I have:
C262:
Across cap 465 ohms. To ground OL
U202 Fan 6300A nothing gives a reading to ground. VCC nothing to ground either on any pins meter set to several ohms measurements.
D20:
Black on cathode, red on anode:
476Mv drop
Red on cathode, black on anode:
OL
D298:
087Mv drop
OLPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I would say your Smp Ic is probably faulty here. See what Bud and DB think.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Just to be sure, So the resistance between the HV pin and GND pin is (OP was reading about 70K Ohms)? VDD pin and GND pin is (Op was reading about 2K Ohms)?Never stop learning
London-Freddie
You now need to do the same tests as ReeceyBurger123 has kindly done for you and post back the results.Willing to help but I'm no expert.Comment
I have a hard time finding c262 in the diagram.
But from the readings Reece provided, it does look like bad IC at this point.Never stop learning
It might be hard Bud as they change the design every board. But yeah im thinking the Ic is bad, strange as normally when these Ic's fail in Vestels they blow up.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Assuming...7 Photos -
by k370Hi everyone,
I have a NM-A321 board that is dead, with no power at all.
When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:- +3VALW
- +5VAUX
- 1.2VSUS_PWRGD
- 3VALW_PGD
- 1.05VAUX_PWRGD
Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
The only place on the board where I find any voltage is on the first MOSFETs, specifically:... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
