Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
  • k370
    • Oct 2014
    • 30
    • portugal
    I have a NM-A321 board that is dead, with no power at all.
    When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
    With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
    • +3VALW
    • +5VAUX
    • 1.2VSUS_PWRGD
    • 3VALW_PGD
    • 1.05VAUX_PWRGD
    Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
    The only place on the board where I find any voltage is on the first MOSFETs, specifically:
    • PQ5
    • PQ6
    • PQ15
    • PQ16
    These are driven by PU4 (BQ24770), but this IC is also not getting any voltage at all. As pointed out by another member in a related post about this board, there's no point in changing this IC until we have 3VALW. Here's the link to the post: https://www.badcaps.net/forum/troubl...-board-nm-a321
    I've already measured all the MOSFETs and checked for other shorts; everything seems fine.
    Any tips would be welcome!
    I'll also leave the board view and schematics I'm using.
    Note: PJ7 +5VDX_WALKPORT, which provides power to the USB ports, has very low impedance (20 ohms). I've lifted the pad for troubleshooting and believe that this rail doesn't impact the board turning on and showing an image. I'll worry about this later after I get the board to boot.
    https://www.badcaps.net/forum/troubl...0-lcfc-nm-a321
  • reformatt
    • Feb 2020
    • 1759
    CHGVCC voltage? ACDET? Does laptop run off a charged battery? You can also do a Sorin hack, and apply external power supply to battery terminal (around the same voltage as the battery as it's a NVDC charger) and see if the laptop comes on.
    • k370
      • Oct 2014
      • 30
      • portugal
      Thank you for the tip.
      I already injected voltage into the battery terminals and got 5V, 3.3V, and the battery LED blinking when the power button is pressed, indicating a low battery, but it still won't power on.
      Based on this test, I'm inclined to order and replace the PU4 (BQ24770).
      What do you think? Should I measure something else?
      • reformatt
        • Feb 2020
        • 1759
        You could order it, but some basic measurements around the IC would help.
        • k370
          • Oct 2014
          • 30
          • portugal
          es, you're right, taking measurements instead of relying on assumptions is always better.
          Measurements on charger (without battery):
          • Pin 1: 0.18V
          • Pin 2: 0.18V
          • Pin 3: 0.17V
          • Pin 9: 0.02V
          • Pin 14: 0.20 to 0.40V (fluctuates)
          • Pin 27: 0.02V
          Measurements on battery and charger (battery voltage at the time of measurement: 6.77V, rated battery voltage: 7.6V):
          • Pin 1: 6.40V
          • Pin 2: 6.40V
          • Pin 3: 0.93V
          • Pin 4: 0.93V
          • Pin 11: 3.30V
          • Pin 12: 3.30V
          • Pin 15: 0.28V
          • Pin 17: 6.17V
          • Pin 19: 0.63V
          • Pin 20: 6.77V
          • Pin 25: 6.52V
          • Pin 26: 6.66V
          • Pin 27: 6.77V
          • Pin 28: 6.61V
          ​I also leave a picture of the BQ24770 pinout for easier reference and analysis.
          • reformatt
            • Feb 2020
            • 1759
            With charger connected, I would expect Pin 28 to be 19V via PD2. As it's only 6.6V, then this is only being fed from the battery via PD3. So clearly you have an issue with the adaptor input circuit. For future reference, troubleshooting BQ charger IC's the most basic things for us to check are VCC, ACDET, ACOK and REGEN pins, which you have omitted above. But these are irrelevant right now.
            There is a fuse PF2, followed by two P channel FET's PQ10/PQ11. These will be under the control of PQ14A, controlled by USB_ID from the Lenovo charger. I'm assuming this is a voltage, rather than forming part of a resistor divider (as there doesn't appear to be any internal pull up etc). Assumption is that USB_ID turns on PQ14A, turning on PQ10/PQ11 and providing your volts to the your BQ IC.
            • mon2
              • 16621
              Test the voltage to ground on each pin of PD3 with both, the battery and the power adapter connected. In this case, the power adapter voltage (since it should be higher than the battery voltage) should power the Vcc pin as noted by reformatt.
              • k370
                • Oct 2014
                • 30
                • portugal
                Thank you for your help and time. I'm going to investigate further based on your suggestion. I will update my findings later for the reference of other users.
                • k370
                  • Oct 2014
                  • 30
                  • portugal
                  reformatt mon2
                  Following these tips, I was able to identify that PQ14 was damaged. I replaced it with one from another donor board, and now it works just fine. Thank you for your input; without it, the repair probably would not have been successful.
                  Regarding the short on PJ7 +5VDX_WALKPOR, I found that the problem was the U40 IC, which was shorted, as well as a USB charging control IC (TPS2546) on one of the sub-boards that I have already ordered.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • OneRefresh
                    MacBook Air A2337 (Logic Board 820-02016) - Blown tantalum capacitor and dead component near battery connector
                    by OneRefresh
                    I am troubleshooting a MacBook Air M1 Model A2337, Logic Board 820-02016 that suddenly went completely dead with no signs of life, no trackpad click, no display.
                    Here is what I have done and found so far.
                    Initial testing involved trying a soft reset and testing different USB-C chargers including a 75W PC charger, but the board pulled no current and remained unresponsive.
                    Battery isolation was the next step. I opened the Mac and disconnected the battery connector. Testing on wall power yielded the same result, it was totally dead....
                    06-04-2026, 01:45 PM
                  • RGDuarte
                    Help identifying QFN-16 PMIC on Wiim Pro Plus audio streamer board - overheating, RCA dead
                    by RGDuarte
                    Hello everyone, I hope someone can help identify an SMD IC on the main digital board of a Wiim Pro Plus music streamer (manufactured by Linkplay Technology, powered by 5V USB-C).
                    Symptoms:
                    • The chip runs extremely hot to the touch
                    • RCA analogue outputs are completely dead
                    • Optical/digital output works normally
                    • This strongly suggests the chip is supplying power to the analogue board (which contains the AKM4493SEQ DAC and TI PCM1861 ADC)
                    Package:
                    • Definitively QFN-16 style — 4 leads clearly visible on each of the 4 sides
                    • Approximate body size appears to be 3×3mm or 4×4mm
                    • Black
                    06-12-2026, 04:52 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • Asraf Atb
                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                    by Asraf Atb
                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                    01-27-2025, 05:02 PM
