Dead Vestel 17IPS71 power board
  • cheeky2
    replied
    5 years later from the previous post! It's unlikely you will get an answer. I suggest you create a new post with your issues or start reading through some of the threads to check for yourself where to start checking
  • robert1000
    replied
    Originally posted by FullnameJon
    Re: Dead Vestel 17IPS71 power board
    Forgot to say that it made no difference if I heated those capacitors up. Still resets.
    Hello, how did you fix it? Please reply. Thank you!
  • FullnameJon
    replied
  • FullnameJon
    replied
    Ok, I can't even find the marking for C295. C302 isn't populated. C296 read 95.76uF and 0.40ohm.
    C64 110nF no ESR reading.
    C73/C33 (double marking, same spot) is a 100uF 35V that read 105.2uF 0.34ohm.
  • FullnameJon
    replied
    I have checked those. I will check the caps as soon as I can.
    replied
    OK, try to locate the lytics caps as shown in the solid red boxes I marked, then heat them up with hair dry for few minutes then power up the board by itself to see if the Voltage will become stable or not.
    BTW, you did check all the power diodes in the cold side correct since I see some of the legs had to be soldered back in place, correct?
  • FullnameJon
    replied
    Yes sir
    replied
    If I test the DC output with the mainboard connected, the voltages drop even faster than before. Measured HV from FAN6300A to 320V and VDD peaks at 20.68V but dies almost directly then goes back up and repeats.
    Are you still getting unstable output if main board is not connected?
  • FullnameJon
    replied
    I've tested another mosfet and optocoupler, no difference. U202 or something before it keeps resetting it seems.
    replied
    I did not read the latest thread in details yet to see what is going on with FullnameJon's board.
    Can we see good clear straight shots of the whole bottom side of your board?
    I also attach the Vestel training manual for 17IPS71 for reference.
  • FullnameJon
    replied
  • dick_barton
    replied
    Disconnect the mainboard from the power supply and power up. Check if Pin 9 of CN4 = 5V. If not then this voltage comes from the mainboard and is fed back to the power supply.
  • FullnameJon
    replied
    I noticed that too but they're connected. Didn't bother tidying it up yet.
    Pin 9 shows 1.5V. Where does that come from? There's no Q1.
  • dick_barton
    replied
    It looks like the diodes have had their legs cut to check them but D13 and D15 look as though they are not soldered back in place correctly.
    You have missed some of the voltages on the connector
  • FullnameJon
    replied
    1 - 24V
    4 - 2.5V
    10, 11, 12 - 12V
    Again, it moves around a bit as the supply restarts.
  • dick_barton
    replied
    FAN6300A was what I meant but ignore for now.
    Can you post a photo of your board.
    Can you also give the voltages you have on each of the pins of connector CN3 or CN4 whichever one is fitted to your board.
  • FullnameJon
    replied
    Board is R4.
    Pins 1-8 where?
    C19 is 320-321V
  • dick_barton
    replied
    What version is your board r2, r3 etc???
    What voltage do you have on the pins 1 - 8. Use the negative leg of C19 as the ground for your meter. Be carefull since there is high voltage on this part of the circuit so measure with a steady hand.
    What voltage do you have between the two pins of C19. Should be close to 400V and steady
  • FullnameJon
    replied
    I've gone through this thread a couple of times but my issue doesn't seem to match, I think. I get 12 and 24V outputs, but not stable. I can hear something restarting every couple of seconds and the voltages on the DC side drop just a little bit before it goes up again, and then down a bit. No standby light and no life in the TV other than the unstable voltages. I've replaced FAN6300A as I thought that was causing the issue, but no luck. Bad caps? Bad IC?
    replied
    Yep, that schematic, 17ips71-r3, from post #17 is not from Vestel, it looks like it was drawn by some one else with lots of wrong value parts, I.E. lots of resistors are marked as '10R', and connections.
