Luxor LUX-22-822-COB stuck in standby
    Re: Luxor LUX-22-822-COB stuck in standby
    If the standby 5V and the 14.5V are steady (these two Voltages are present the minute the TV is plugged into the outlet, they are generated by the same transformer) then it has to be the control signal or those switches are not working properly, I have yet to get the answer as to those two STBY Voltages are steady or not.
    • sordids999
      • May 2013
      • 2158
      hi budm
      the +5STBY is steady but today i cant get any other voltages to work and thats with the PSU disconnected and connected to the MB
        Originally posted by sordids999
        hi budm
        The 14.5V is also present and steady?
        • sordids999
          • May 2013
          • 2158
          No 14 volt present
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Heat the Psu see if it improves.
            • sordids999
              • May 2013
              • 2158
              #26
              nope tried that reece
                No 14 volt present
                That is strange because the 14.5V power supply is also an always on power supply and it is generated by the same transformer for the +5VDC.
                May I ask what test point you use to test the 14.5V? At the Fuse F101?
                BTW, Can I get straight shot pictures of the top and bottom sides of the board?
                I am beginning to wonder if the diagram I use for the reference matched your board.
                • sordids999
                  • May 2013
                  • 2158
                  #28
                  Pictures as requested
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    I think it may be the same if not very similar to the 17IPS17-2 pdf. I see there is a fuse on the underside F101.
                    • sordids999
                      • May 2013
                      • 2158
                      #30
                      Can you point me to it i can not find it ?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Sorry Sordids999 Can't find the fuse or the schematic?
                          I see the F101 SMD with '0' printed on top, at about 1 o'clock of the blue stand off. Page 2 top left of the SCH.
                          https://www.badcaps.net/forum/attach...5&d=1461868563
                          BTW, diagram on my post #14 which DB gave the link to Elektrotanya.
                          • sordids999
                            • May 2013
                            • 2158
                            #33
                            sorry i mean F101 looking now on the board but cant seem to find it
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              Here it is. An SMD "0" resistor.
                              • sordids999
                                • May 2013
                                • 2158
                                #35
                                F101 fuse is not blown and also no voltage is coming from the fuse
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  Strange.????
                                  Edit
                                  Did you download the psu schematic given in an earlier post?
                                    That makes no sense since it is just the simple rectifier diodes and filter caps and choke.
                                    Check the connection paths from the Transformer leg to the diodes, choke, etc.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      If IC804 is down then you lose the 14.5V and 12V supply.
                                      Edit
                                      Or if the caps are down C822, 823, 826
                                      Diodes D813 and the diode pair above it in the schematic.
                                        IC804 (12V regulator/switch) is fed by the always on 14.5V.
                                        I hope that the basic tests have been done in that section already such as checking to solder joints, rectifier diodes, inductor L810, etc.
                                        • sordids999
                                          • May 2013
                                          • 2158
                                          #40
                                          This what im saying i have intermittent voltages yesterday no voltages then later on i had 5v/12v voltages but now nothing ?
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • nono34
                                            Hisense stuck in Colors cycle like test pattern.
                                            by nono34
                                            I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                            I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                            10-24-2024, 04:31 PM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
