Hisense stuck in Colors cycle like test pattern.
This topic has been answered.
  • nono34
    • Oct 2024
    • 12
    • Espagne
    I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
    I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to pkg, forcedupgrade.bin, Mstarupgrade.bin, loader, etc. I followed the repair guide for Hisense MTK9618, but it still doesn't work.
    Do you know any tips to regain access to the factory menu?
    Thank you very much!​
  • Answer selected by nono34 at 10-25-2024, 05:20 AM.
    Diah
    • Feb 2013
    • 6568
    it sound yours TV still at service menu....put the TV in standby .. then unplug it from wall... wait 1 minute then plug it again in wall,,
    if this didnt help flash firmware again compleete... you can find at hisense FTP under 55 size yours model
    link
    Password : Hisense1234
    • Diah
      • Feb 2013
      • 6568
      link
      • nono34
        • Oct 2024
        • 12
        • Espagne
        Hello Diah,
        Thank you very much for your help. I followed your instructions, but it didn't work. However, I followed your link, but I couldn't find the firmware for the U7KQ series.
        Thank you very much, have a good day.
        • Diah
          • Feb 2013
          • 6568
          did you played with LVDS cable? if you did then you may damaged pins.. when LVDS had short contact of pins screen go to RGB.
          about the firmware... call yours local Hisense and give them yours TV serial No and the HSSO number they will give you link on recovery firmware.
          • nono34
            • Oct 2024
            • 12
            • Espagne
            I have never opened the TV. I do have the serial number, but there is no HSSO number on the label, nor on the back of the TV. I have already called Hisense, and they sent me the firmware usb_mtk9618_EU.bin.
            ​ Thanks
            • Diah
              • Feb 2013
              • 6568
              can you upload photo of the TV label on the back
              • nono34
                • Oct 2024
                • 12
                • Espagne
                Voici la photo.
                • Diah
                  • Feb 2013
                  • 6568
                  so the firmware should be as they send to you .bin. but yours PC be sure the file extension can be viewed to avoid written double .bin.bin
                  plug tv out from wall and put the usb stick at USB 1 . press power on the RC while you pressing plug the tv in wall... the upgrade will show
                  • nono34
                    • Oct 2024
                    • 12
                    • Espagne
                    I have already tried these various methods, the update never appears on the screen. However, the firmware is installed on the TV because the key is read by the TV (it flashes). Then after about ten minutes the television stops and starts again.
                    • Diah
                      • Feb 2013
                      • 6568
                      then don't do it any more..its written .. you need to open it to see if there way we can reset it
                      • nono34
                        • Oct 2024
                        • 12
                        • Espagne
                        Le systeme est Vidaa
                        • Diah
                          • Feb 2013
                          • 6568
                          you still have guaranties.... reclaim it
                          • Diah
                            • Feb 2013
                            • 6568
                            if no more guaranties., you can do it in blind way to inter service menu again ... project id are under design watch this movie and do it step by step with yours RC in blind way
                            • nono34
                              • Oct 2024
                              • 12
                              • Espagne
                              Merci beaucoup pour vos conseils. Si je change la carte mere par une 55u7kq de la meme serie, est ce que cela peux fonctionner ?
                              • Diah
                                • Feb 2013
                                • 6568
                                i think yours mainboards all in one. mean the power boards on it too ... if it so then will not work because of the LED backlight.. you need first to open and take look
                                • nono34
                                  • Oct 2024
                                  • 12
                                  • Espagne
                                  Je viens de regarder sur internet, la carte d alimentation se trouve à part de la mainboard.
                                  • Diah
                                    • Feb 2013
                                    • 6568
                                    yes it work. but afraid you need to inter the service menu again LOL
                                    try connect the TV with LAN cable to yours router. and be sure it got ip in router.... call you tube or netflix.or any app you have on RC. hope one app will come on so you navigate the menu
                                    • nono34
                                      • Oct 2024
                                      • 12
                                      • Espagne
                                      Je vais récupérer un câble LAN et je vais essayer. Merci beaucoup
                                      • nono34
                                        • Oct 2024
                                        • 12
                                        • Espagne
                                        Cela ne fonctionne pas, c est une tv qui a été acheté d occasion et qui n est plus garantie.
                                        Quand j aurais un moment, je l ouvrirais pour prendre la reference de la mainboard.
                                        Merci beaucoup
                                        • nono34
                                          • Oct 2024
                                          • 12
                                          • Espagne
                                          Bonjour.
                                          Bonnes nouvelles. J ai laissé le téléviseur débranché toute une nuit. Et ce matin la Tv a redémarrée normalement. Je suis retournée dans le menu service et tout était OK. Du coup Je pense que je n avais pas modifier les paramètre mais que la Tv a buggé. En 6 mois de service, je n avais jamais rencontré de probléme avec ma Tv.
                                          Encore merci. Bonne journée.
                                          • Prott
                                            Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
                                            by Prott
                                            Hello fellow Badcappers,
                                            I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
                                            I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
                                            Thank you!
                                            03-01-2024, 08:23 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • thesame
                                            JVC LT-40V750 stuck in service mode switching colors.
                                            by thesame
                                            The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
                                            01-12-2024, 10:39 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • ojmc
                                            Hisense 65H6570G - Color inverted after replacing LED backlight
                                            by ojmc
                                            Background:
                                            • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                            • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                            • The TV worked again perfectly for ~2 weeks.
                                            • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                            10-17-2024, 02:29 PM
