Post The Led Backlights Your Fixing Here.
  • theojt
    • Jun 2017
    • 48
    Re: Post The Led Backlights Your Fixing Here.
    Originally posted by Foxmorg
    I have the same, one bad LED.
    Did you replace the strip or just the one LED?
    Where did you get your part?
    Sorry for the delay, I missed your post. I replaced the strip. I got it from eBay https://www.ebay.com/itm/142219238430
    $18.
    • YoshiK1
      Hi folks,
      I've did a search on the forum but can't find an answer so am posting here as this seems the most suitable place to post.
      I've got an LG 42LB5500 LED TV with a backlighting issue - I still get a picture if you shine a torch on it. I've found 4 bad LEDs across multiple strips. My issue is I can't find the parts I need to replace them. I don't know much about TV parts however from research you apparently need to have the exact same parts when replacing. Is this true for LEDs?
      The strips I have are:
      A Strip: 6916L 1709A
      B Strip: 6916L 1710A
      I can find ones with similar numbers i.e. 6916L 1709B 6916L 1710B or completely different numbers but for the same TV. Am I able to use any strip that's for my TV model or does it need to be the exact same part? The connectors etc look all the same.
      Thanks!
      • Michale32086
        • Nov 2011
        • 1453
        Originally posted by YoshiK1
        Hi folks,
        Thanks!
        It's been my experience that if the connectors fit and the size fits, you should be OK..
        • SupcoVG64
          • 3
          I see a lot of posts where 1 or 2 led's are replaced. Given that the remaining led's are all the same age, and a strip of 100 on a slow boat from China is very inexpensive, would it not be prudent to just change all of them at the same time ?
          • diif
            • Feb 2014
            • 6978
            • England
            #125
            I wouldn't want to swap all 52 LEDs in the last couple of TVs I've repaired the LEDs on. Replaced the dead one, turned the back light down and that's it.
            • nwcs
              • Dec 2015
              • 311
              • usa
              #126
              I have repaired hundreds of led's in tv's and they almost always come back with more bad so I now just replace all of the led strips. And for the first time I had a Samsung UN55ES6100 that when I removed the panel to test the led's the positive wire had come disconnected from one led strip and that caused what I thought would be a bad led strip.
              • diif
                • Feb 2014
                • 6978
                • England
                #127
                A total of 92 LEDs in this Sony 46", edge lit top and bottom. Removed all 4 strips, but nothing faulty round. Wondering if it was a dodgy connection..
                • zomi
                  • Nov 2011
                  • 509
                  #128
                  Have you tested the leds from the plug connection to see if they light up
                  or led to led.
                  Had it on a samsung where the leds tested fine.
                  but from the plug ta section would not light up
                  turned out to be a burnt trace.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #129
                    or led to led.
                    Tested from the 15 pin connectors and also the 6 sets of 8 LEDs on each of the strips.
                    Think I'll reassemble and test without the LCD screen, it's possible one of the ribbon cables wasn't located properly or is damaged. Or it's the driver board.
                    • zdsh07p9
                      • Nov 2013
                      • 155
                      I've been fixing TV's on the side for 12-13 years now ever since I was 14. My Dad had a Vizio 42" under his bed that was broken that I fixed with 2 caps and that started it all! Anyways - heres a list of TV's I've fixed LED's in within the last month - prepare yourselves lol:
                      Vizio e470i-a0
                      Hisense 50h5g
                      Sharp LC-60LE681u
                      Samsung UN75F6300 - yes you read that correctly. I replaced these by myself with no special contraption.
                      Vizio P502ui-B1E (this was because of an issue with the LED Driver board, not the actual LED's themselves)
                      LG 47LN5400
                      Anyways, the broken TV market has been pretty good to me lately.
                      • dskall
                        • Oct 2016
                        • 2905
                        • usa
                        #131
                        Of course if you were using an led tester to check. Main drawback is they don't drive the led's very hard. So may not break down under light load.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          #132
                          I tested with my LED tester and thought the same.
                          I then used my bench tester set at 24v and set the current limit at 800mA, tested on each set of 8 LEDs they are drawing 60-70mA. Seems they are not drawing much current.
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            #133
                            I think panel drives them alot harder than 60-70ma
                              You should see the current goes up much higher once you turn up the Voltage beyond 24V (I would limit the current to 100mA first) since the Vf of all 8 LEDs may not be 3V exact, some may be higher or lower you will have to look at the spec sheet of the LED.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #135
                                I have no idea of the spec of the LEDs but my LED tester ramped up to 22.7v per set of 8, so I figured they were 3V LEDS, hence the 24V.
                                The current did seem low, but they are bright at 3V, maybe they are 6V though.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #136
                                  Vizio will drive theirs around 400ma which is why they don't last. Funny thing is you can modify current to about half and they are still plenty bright. Makes you wonder if it is preplanned obsolescence.
                                    But I thought you use 24V power supply with current limit to 800mA.
                                    The LED tester only put out about 30mA that is why you see total Vf of only 22.70V, they are 3V LED at higher current.
                                    • diif
                                      • Feb 2014
                                      • 6978
                                      • England
                                      #138
                                      Yes, I set the voltage at 24V (3V for each LED) and 800mA limit (100mA) for each LED.
                                      When I applied the probes to the sets of LEDs the power supply showed 60-70mA, I was expecting it to hit the current limit but it wasn't close.
                                      Testing a handful of individual LEDs with the voltage set at 3v and the current limit 100mA, I see current draw between 40mA to 80mA
                                      Why do 8 LEDs draw as much current as a single one ? I'm confused, what am I missing ?
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        #139
                                        Current is same throughout series circuit. Each led will have same current. But voltage will have to change each time you add led to maintain current
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #140
                                          Of course ! I'm confusing myself unnecessarily. It's been a very long time since i did any electrical theory, thanks for jogging my memory. I went and had a little read too.
                                          • Pipolups
                                            Corsair K70 LUX RGB dying LEDs
                                            by Pipolups
                                            Hi there !
                                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                                            10-08-2024, 11:58 AM
                                          • TrisHCl
                                            LED TV Boot loop - UE40F6500SB
                                            by TrisHCl
                                            First post...
                                            I have this TV, which was working, then suddenly would not turn on. It would get the clicking relay then flash up the screen for less than a second, off for a second then on again. Removing the plug the relay continues to click on and off for a few cycles, which I don't think it did before.
                                            Left it a few months, then finally got round to taking the back off, and it worked as it should. So I tested various bits and all was well. Then turned it on again, and back to the clicking relay.
                                            I disconnected the main board from the power...
                                            02-06-2025, 08:42 AM
                                          • max789
                                            Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                            by max789
                                            Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                            I made the following tests:
                                            1. Disconnected the main board from Power Board = backlight works.
                                            2. Connected the main board and disconnected the T-Con = backlights does not work.
                                            So I ordered a main board from Ebay also BN41-02156A but from...
                                            01-18-2024, 06:56 AM
                                          • bpcannan
                                            VIZIO M557-G0: Backlights or ???
                                            by bpcannan
                                            'Morning,
                                            I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                                            Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                                            I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                                            I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                                            10-29-2023, 06:36 AM
                                          • jesterace
                                            Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
                                            by jesterace
                                            Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
                                            However, I am in a dilemma.
                                            I tested the backlight outputs with the lights disconnected...
                                            10-20-2024, 10:15 AM
