Vizio M470NV will not turn on
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Vizio M470NV will not turn on
    Hello bjhunnicutt, could you also post a clear picture of the circuit board shown within the white box.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Looking through previous posts it looks like VLED to chassis = 145V
      https://www.badcaps.net/forum/showpo...21&postcount=7
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        BL_On appears to be the 3rd pin down. Sharper picture would help since it's quite blurry.
        Put your 1K resistor from 5VSTB to Power_On (4th pin down) and place another 1K from +5V to BL_ON with mainboard disconnected and then measure VLED
        Basically follow same advice as in post #10
        • CapLeaker
          Leaking Member
          • 8352
          Originally posted by bjhunnicutt
          Okay, So I was able to jumper a 5v to the power_on pin (fourth on from the top) and got 12v on all 3 of the 12v pins. When I jumpered a 5v volt to BL_on I got nothing from the backlight. Just to confirm is BL_on 2nd from the top or third? (see most recently attached picture) The first is hidden by the plastic retainer and the Power_on label takes up two pins. Also, originally the Vizio logo (stby light) would glow orange when plugged in, but no longer does. I still get the feeling I am missing something.
          Thanks all
          You got something wrong with the pins. PSon is only ONE pin (#4 counted from right to left) BLon is #3, no connection on #2, PWM for #1.
          Force the PSU on (like in my post #10 earlier) with just the backlights hooked up... Check all the voltage rails and measure each LED string. I am not sure how much juice is on the LED string exactly but it should be around 100VDC or so.
          • bjhunnicutt
            • Mar 2016
            • 38
            • Usa
            Here are some higher resolution photos of my boards.
            • bjhunnicutt
              • Mar 2016
              • 38
              • Usa
              #26
              Daughter Board
              • bjhunnicutt
                • Mar 2016
                • 38
                • Usa
                #27
                Post 12 has a clear close up of the 5v/12v/Pwr on section of the power board
                Post 18 has a clear close up of the LED connectors
                • bjhunnicutt
                  • Mar 2016
                  • 38
                  • Usa
                  #28
                  Thanks for the clarification on the pins, I will reattempt this afternoon. And post the vled voltages
                    OK, so you are able to force on the power supply board using the resistor, we need to find out if the PFC Voltage booster is working or not by check the DCV between the two legs of the main filter caps (two 450VDC caps laying on their side) to see if it has close to 400VDC or not since the LED backlights circuit requires that boosted Voltage to work.
                    • bjhunnicutt
                      • Mar 2016
                      • 38
                      • Usa
                      #30
                      BudM, forgive this basic question, but where do I put the tester probe to check that? (I do know which ones are the 450v caps and I see the two legs)
                        You can check either one of the two caps since they are connected in parallel, red probe on the plus leg, black probe on the negative leg.
                        • bjhunnicutt
                          • Mar 2016
                          • 38
                          • Usa
                          #32
                          Here are the voltages I got:
                          All the 5v = 5v
                          All the 12v = 11-12 volts
                          The 4 VLEDs = 105-115
                          The 450 Cap = 340-360
                          With the LED connectors plugged in. But no Backlight.
                          Does this mean the backlight array is dead? Or are the voltages to low? Is it common for the entire array to die?
                          • CapLeaker
                            Leaking Member
                            • 8352
                            The backlights are like X-Mas lights. One fails, all go out in that string. The 4 VLED's voltages are at 105 to 115 V DC but no backlight?
                            • bjhunnicutt
                              • Mar 2016
                              • 38
                              • Usa
                              #34
                              Correct, no backlight with the voltages stated. Also, no sound if it matters
                              • CapLeaker
                                Leaking Member
                                • 8352
                                weird. there must be an open somewhere on the LED strings. Are you measuring with the probes from VLED - to VLED +?
                                  You have 12 strings of LEDs (1-1, 1-2, 1-3, 2-1, 2-2, 2-3, 3-1, 3-2, 3-3, 4-1, 4-2, 4-3: These pins are the Cathode returns of each LED string) driven by 12 LED drivers.
                                  VLED pins are the outputs of the boost converter circuits and connected to the Anode of all the LED strings.
                                  So for sure if you look at the panel in the darkened room you did not see the backlights flash on for seconds? I doubt that all 12 strings of LED will be bad.
                                  • bjhunnicutt
                                    • Mar 2016
                                    • 38
                                    • Usa
                                    #37
                                    I agree it doesn't make sense which makes me think I am doing something wrong.
                                    I checked the voltage with the hot probe on the vled pin (all four, one at a time) and the ground probe on a point on the frame.
                                    I have done this in a dark room, no light at all from the unit.
                                    Is there a fuse or something downstream of the vleds and prior to the led strings?
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      No. you have to measure each LED string like budm mentioned in his last post.
                                      • bjhunnicutt
                                        • Mar 2016
                                        • 38
                                        • Usa
                                        #39
                                        So probe each of the 1-1, 1-2 etc pins individually?
                                        • bjhunnicutt
                                          • Mar 2016
                                          • 38
                                          • Usa
                                          #40
                                          When I turn the power on with the PWR_ON and BL_ON jumpered the screen does flicker initially and then returns to black (or at least imperceptibly dim) I missed it before because I wasn't looking straight at the screen at power up due to the set up of my work space. What does this change?
                                          Also, how do I measure the individual LED strings? Currently I get 110 on all the vleds (far left and far right of each plug) and 0 on the 12 (1-1....4-3) cathode returns
                                          • Mulp
                                            VIZIO M65-C1 Does Not Turn On
                                            by Mulp
                                            Hi All,
                                            I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                            When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                            I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                            01-13-2024, 09:57 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
                                          • masoksian
                                            Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                            by masoksian
                                            I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                            The system does not turn on, there is no post.
                                            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                            The problem continues in the same way.
                                            I tried to turn on the Fn key, nothing came to the screen....
                                            02-15-2025, 12:08 PM
