Vizio M470NV will not turn on
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8065
    Re: Vizio M470NV will not turn on
    VLED to 1-1... VLED to 1-2 etc...
    • bjhunnicutt
      • Mar 2016
      • 38
      • Usa
      #42
      Sorry, CapLeaker but could you elaborate.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8065
        Put the meter to measure DC. Put one probe to the VLED pin then the other to 1-1, 1-2, 1-3, etc pin. Go through them on both connectors. Take note of the voltages measured and report back. One probe is always on the VLED pin, while the other probe goes to each numbered one (1-1 up to 1-3, then 2-1 -> 2-3, on the other connector same thing.
        • bjhunnicutt
          • Mar 2016
          • 38
          • Usa
          #44
          They will each show 105-110 volts for about 3-5 seconds after the power is turned on then go to zero. This corresponds to the screen flashing on for a few seconds when the power is turned on and then going dim.
          • bjhunnicutt
            • Mar 2016
            • 38
            • Usa
            #45
            PS- Thanks for the detailed instructions, I am learning quite a bit
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8065
              The backlight actually does come on for a second or two... that is better and what we expected compared to nothing at all. Isn't one VLED rail that shows a big difference compared to the others? Since the PSU actually does put out, you have to disassemble the panel and see if all LED's come on.
              • bjhunnicutt
                • Mar 2016
                • 38
                • Usa
                #47
                I didn't notice a big difference between the VLED rails.
                Any speculation on what causes the shutoff after a few seconds?
                  Do the same test again but this time put the black probe on the chassis and the red probe on 1-1, 1-2, and so on.
                  • bjhunnicutt
                    • Mar 2016
                    • 38
                    • Usa
                    #49
                    With black probe on the chassis and red probe on 1-1 etc. I get 0v on all 12, not even the temporary 105v I get when doing 1-1 etc to VLED as earlier posted. The screen still flashes for a 2 or 3 count when power is first applied. It looks to be the entire screen, no obvious gaps.
                    • bjhunnicutt
                      • Mar 2016
                      • 38
                      • Usa
                      #50
                      Because the thread has become a bit lengthy (I appreciate all of the assistance) I thought I would recap where I am with this TV.
                      While watching tv there was an audible pop and the unit died and wouldn't turn on. After a bit of trial and error I have the following voltages coming off the power supply board.
                      With PWR_ON and BL_ON jumpered:
                      5V out of all the 5V
                      11-12V out of all the 12V
                      340-360V out of the 450V caps
                      105-115V out of the VLEDs when tested with the hot probe on the VLED and the gnd on the chassis
                      105-115V out of the VLEDs for about 3 secs when tested with the hot probe on VLED and gnd on 1-1....4-3. Then drops to 0.
                      0V out of 1-1....4-3 with the hot probe on 1-1...4-3 and gnd probe on the chassis.
                      Also, when power is applied with PWR_on and BL_on jumpered, the screen does flash white for about 3 sec.
                      The orange VIZIO logo standby light doesn't light up when power is applied.
                      Thanks for all the help. I am preparing to take it apart further to look at the LED strings per post 46
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8065
                        a bad led string (backlights), making the PSU shut down.
                        • bjhunnicutt
                          • Mar 2016
                          • 38
                          • Usa
                          #52
                          When I get the panel disassembled will that bad string be visually obvious (not lighting up or blackened looking etc) or will I need to do some more testing?
                            I still need to do some more thinking since all the Cathode returns (1-1,1-2,.. ) of ALL the strings with Ref to the Chassis to GND readings ALL show 0V, I cannot see that all the strings will have open circuits, unless the VLED Voltage has to be higher than 115V.
                            Need to find out how many LEDs there are in each string, I sure hate to open up the panel and taking a chance of damaging the LCD Glass panel.
                            We need to see if we can find the pictures of the LED strings on the web.
                              BTW, to make sure I get this correctly, you DO SEE the backligts do come on for seconds?
                              • bjhunnicutt
                                • Mar 2016
                                • 38
                                • Usa
                                #55
                                Yes the screen flashes white (a uniform flash covering the entire screen) for about 3 sec then goes black. This did correspond to the VLED to 1-1...4-3 probe test where the voltage goes from 105ish to 0 after about 3 secs. FYI, I am using an analog multimeter.
                                Also I won't be tinkering with it this weekend, so you will have time to think about it further.
                                I appreciate everybody's time and input.
                                • bjhunnicutt
                                  • Mar 2016
                                  • 38
                                  • Usa
                                  #56
                                  I found these. It is unclear if the associate picture is a generic LED or the specific one
                                  http://vizpartsdirect.com/productDet...temInfoId=1763
                                    Ahh, analog meter! I which we know that at the beginning or may be it was mention some where in the thread.
                                    OK, you are using the analog meter which is not going to be fast enough to catch the Voltage readings between GND and 1-1, 1-2, ... before it goes into protection mode.
                                    • bjhunnicutt
                                      • Mar 2016
                                      • 38
                                      • Usa
                                      #58
                                      I don't believe I mentioned it earlier, my mistake.
                                      Can you explain how the protection mode works?
                                      How does that change the diagnosis?
                                      And should I go by a digital one?
                                        If one string of the LED has open circuit the VLED will go up above the Over Voltage trip point, it also has detection for over current draw if one or more of the LEDs are shorted out.
                                        See PDF of the typical LED driver function.
                                        • bjhunnicutt
                                          • Mar 2016
                                          • 38
                                          • Usa
                                          #60
                                          Ok, so it doesn't really change the diagnosis and I will still need to take a look at the LED strings.
                                          Also, I found this picture and description -
                                          http://www.vizpartsdirect.com/produc...temInfoId=1763
                                          • Mulp
                                            VIZIO M65-C1 Does Not Turn On
                                            by Mulp
                                            Hi All,
                                            I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                            When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                            I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                            01-13-2024, 09:57 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
