Vizio M470NV will not turn on
    Re: Vizio M470NV will not turn on
    I have never those before, if that is the case, then there must be another board inside the LCD panel since those connectors are not what we are seeing on the LED connectors.
    • bjhunnicutt
      • Mar 2016
      • 38
      • Usa
      #62
      Hmmmm, that could make things interesting then.
        I sure like to know what it looks like inside the panel.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8090
          me too.
          • bjhunnicutt
            • Mar 2016
            • 38
            • Usa
            #65
            I will post pictures when I get to that stage. It will be a few days though.
            • bjhunnicutt
              • Mar 2016
              • 38
              • Usa
              #66
              One last question before I start trying to get at the LED strings.
              If I can get the screen to flash on initially by jumpering PWR_on and BL_on, why wont the screen flash (with everything connected) when the power on button is pushed (manual or remote)?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8090
                maybe the mainboard isn't sending PSon and or BLon...
                • bjhunnicutt
                  • Mar 2016
                  • 38
                  • Usa
                  #68
                  I didn't fully ask my question....
                  - We were going down the path that a bad led was causing the unit to shut off after the screen flashed on for a few seconds.
                  - If this were the (only) issue wouldn't the screen flash on briefly just by pushing the power button the same way it does when the power is "jumpered" on?
                  - Conversely, if the issue were (only) the mainboard not sending the proper signals to the power board, would the backlight not stay on when "jumpered" on?
                  Does, this mean that I have both a bad mainboard and a bad led string? Or I am doing something wrong.
                  I want to make sure before I start disassembling the unit further to get to the led strings. Which looking at the unit will be a dicey task, given my skill level.
                  Thanks again
                  • Electronic Handyman
                    • Apr 2016
                    • 58
                    That main board has two fuses on it , you'll notice them pretty easily bec their small at both of their metal ends are gold in colour.See if anyone of those two fuses are open or just check to see if any DC voltages are at both ends of each fuse.Their probably one 12v fuse and one 5v fuse.
                    • bjhunnicutt
                      • Mar 2016
                      • 38
                      • Usa
                      #70
                      the 12v and 5v fuse both are working and the proper voltage coming out. So I would like to restate my question from a few weeks ago.
                      I am going to have to put off tearing it down to get to the leds for a while till things calm down around here.
                      Thanks again
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8090
                        Well... just take some measurements from the ribbon cable that goes from the power supply to the main board. Use pin out name with the DC voltages measured with TV on and TV off. Other than that it just makes my head spin reading all that. lol
                        • raduryea
                          • Feb 2017
                          I am having the same problem with my Vizio M470NV as bjhunnicutt did. It will not turn on, just has the Vizio logo on. I followed the instructions you gave through post 13 of this thread. When I measured the voltages on the power board all the 5V pins measured 5V but all the 12V pins only measured 9V. Any suggestions on what to do next?
                          • capwizard
                            • Jun 2016
                            • 1991
                            " 12V pins only measured 9V" Tengo el mismo problema. Es porque el SoC IC no terminó el ciclo de auto-prueba. Para la protección, SoC IC es baja abajo 12v a 9v.
                            • dskall
                              • Oct 2016
                              • 2905
                              • usa
                              #74
                              Sorry my reply was 3 pages late
                              • capwizard
                                • Jun 2016
                                • 1991
                                " 12V pins only measured 9V" I found out was the TV in shutdown mode because I've had twins TV to monkey around with.
                                Primero, pensé was power supply or LED, Después I used poormans LED tester and another Good power supply to isolate the problems, Me entero, el problema es main PCB.
                                PS: I hope you can understand that I am learning Spanish.
                                • Mzam220
                                  • Nov 2018
                                  • Usa
                                  #76
                                  I have the same problem on the same tv i chacked all the caps they were good and voltages were good orher than the 145 was at 115 i reseated all the connections and nothing happened the orange logo still stays orange all the fuses and microfuses are good what sould i do?
                                  • Mulp
                                    VIZIO M65-C1 Does Not Turn On
                                    by Mulp
                                    Hi All,
                                    I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                    When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                    I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                    01-13-2024, 09:57 PM
                                  • pajdek
                                    Lenovo Y700-17ISK turn on and off
                                    by pajdek
                                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                    09-20-2023, 02:49 AM
                                  • RdeveLabs
                                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                    by RdeveLabs
                                    To all the members here...
                                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                    05-05-2025, 04:59 AM
                                  • SS454
                                    vizio e650i-a2 backlight flashes then turns off
                                    by SS454
                                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                    panel: au optronics T650HVN05.4
                                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                    08-20-2020, 03:57 PM
                                  • robante15
                                    Acer Aspire 4520 won't turn on after reboot
                                    by robante15
                                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                    If I remove the...
                                    04-06-2024, 06:50 PM
