While watching the TV there was a pop and it powered off. Now while plugged in the vizio logo will be orange but the unit will not turn on. None of the boards have any obvious defects. I have replaced the remote batteries, tried the manual power on button and replaced the power supply board with no luck. Any suggestions?
Vizio M470NV will not turn on
Tags: None
Re: Vizio M470NV will not turn on
Upload good clear pictures of the whole backside of the TV so we can see all the boards and how they are connected together will be a starting point.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Have you taken any voltage readings on the power supply to see if any are missing.Willing to help but I'm no expert.Comment
I have a problem with Quadro Tv 32" "LED SMART 32HN90. Turn on the TV to the power supply, the red light appears but will not play the channels with the remote and no button on the side.
This set uses:
power supply model : VESTEL 17IPS19-5 V.1 061112 barcode 23128588
motherboard model : VESTEL 17MB95S V219x 27076720 DIJ
Panel : VES315UNVL-01
U prilogu su I slike , molim Vas za pomoc.Comment
This set uses:
Attached are pictures I please for help.Comment
This set uses:
I agree. And I am working on getting the voltage readings. ThanksComment
So far I am getting 5v out of all 5 of the 5v outputs. I am not getting anything out of the 12v outputs, but I believe this is because I am not tripping the power on circuit correctly. This is a new power board btw, my first troubleshooting was to replace the power board. I have not tried the 145v outputs yet (Though I had a few EE classes back in the day I am a novice and teaching myself as I go along).Comment
Take a 1k Ohm resistor and jumper PSon or PWRon to STBY 5V. Take another 1k resistor and jumper BLon to STBY 5V. Do not plug any boards into the power supply, just leave the backlights connected. Plug the power supply in and you should have the backlights turned on and all voltage rails up and running.
Here is how the power thingy goes: The 5V STBY power is always on, regardless if the TV is on or not. That goes to the main board. You turn the TV on, the main board sends the power supply a PSon and BLon signal. The power supply turns itself fully on and the TV is up and running.
If the main board does not send PSon, you can press the On button on the TV all day long and nothing will happen. So verify that the main board is sending a PSon signal >2.5V to the power supply. If there is no PSon signal there, you need a new main board.Comment
Okay, So I was able to jumper a 5v to the power_on pin (fourth on from the top) and got 12v on all 3 of the 12v pins. When I jumpered a 5v volt to BL_on I got nothing from the backlight. Just to confirm is BL_on 2nd from the top or third? (see most recently attached picture) The first is hidden by the plastic retainer and the Power_on label takes up two pins. Also, originally the Vizio logo (stby light) would glow orange when plugged in, but no longer does. I still get the feeling I am missing something.
Thanks allComment
There's some information here:
https://www.badcaps.net/forum/showthread.php?t=16852
When you attempted to bring on the backlights what voltage was at the Led terminals?Willing to help but I'm no expert.Comment
Following the recommendation of a previous post, I left the led terminals plugged in. I will unplug them and try to check the voltageComment
Also, the unit will not turn on at all, no sound, backlight or anythingComment
Edit
Do you have a picture of the LED on board connector you can post showing the legendsLast edited by dick_barton; 04-10-2016, 04:15 PM.Willing to help but I'm no expert.Comment
I will look for budm's posts as well, thanks for the help. It has become a pet project of mine.Comment
Also, did you see my question about confirming which pin was actually BL_ON? (the 3:36 pm post)Comment
by MulpHi All,
I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here.... -
by pajdekHello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
by RdeveLabsTo all the members here...
Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But... -
by robante15Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
If I remove the... -
by SS454vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
panel: au optronics T650HVN05.4
72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
https://www.shopjimmy.com/vizio-56-0...-power-supply/
Vizio 55.75J01.001G (91.75J10.004G) Main Board... - Loading...
