tv lcd Philips 42pfl9632d/10 Power board ko
  • Bibu
    • Mar 2016
    • 88
    • Italy
    Re: tv lcd Philips 42pfl9632d/10 Power board ko
    Originally posted by Diah
    on the hot area near to the ac in after the IC big caps, - & + with DC read how much volts DC YOU HAVE IT SHOULD be 350 to 400 Volts
    Do you mean in the black connector?
    • Diah
      • Feb 2013
      • 6371
      sorry to tell, you are not able to repair, or checking, find some one near to you, other wise you may hurt your self . its dangerous
      • Bibu
        • Mar 2016
        • 88
        • Italy
        Diah i know that in the black connector ther is ac current, for this reason i say Where do you mean that i must make the test...
        • Diah
          • Feb 2013
          • 6371
          be careful. you ahve 2 dick caps 330uf with DC - and + you need to read it had DC and how much
          • Diah
            • Feb 2013
            • 6371
            i think you dont haave volts at all on them because i can see you have burned Resistor and the AC-DC IC 100% defekt
            so if no volts you need to replace these in the photo.
            sorry cant help any more.
            • Bibu
              • Mar 2016
              • 88
              • Italy
              #26
              now i understand, later i make the test
                Devices 1003, 1005 are protection device (500V Gas discharge/sparkgap), they should show open circuit, they are NOT RESISTORS, they are for protection an not needed for the circuit to function.
                R3318 (for 25V PS) you have already tested.
                You will not have DCV on the two filter caps if the relay 1350 is not activated.
                You still did not indicate if the main fuse have blown or not with those two shorted out MOSFETs you have indicated.
                • Bibu
                  • Mar 2016
                  • 88
                  • Italy
                  #28
                  I tested the Dc on the two caps and is 0.
                  The fuse is good.
                  But know i have a news... There isn't video, there isn't light and led, but there is a noising sound from the speakerslike a zzzzzzzzzzzzz
                    I am still looking through the diagrams.
                      This is the closest board layout/SCH I found so far.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #31
                        Capacitors have dick's ?
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          #32
                          In his delusional mind they probably do,he sees every tv as a Salvadore Dali project. Unless he's just talking out of his a$$ as usual. I call him the greek resurrected.
                          Proud owner of dozens of broken TV's and many,many,many boards.
                          Our website and passion:http://hollenhundshepherds.com/
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Probably, I seen the other post he commented on about that "bad panel" on that Panasonic 58" and your reply, that was jokes haha Ohh well will let him get one with it and just correct when needed lol
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #34
                              Youve got me thinking now lol i know the greek man you mean but i cant remember his user name, im not sure reece was around then but i do agree with you about the greek resurrected quote.
                                https://www.badcaps.net/forum/showpo...9&postcount=25
                                Be careful, do not quote his comments!
                                Originally posted by budm
                                'ReeceyBurger123 i have on hand new nick name for you hahahah ReeceyBurger123PANEL hahahah you are very expensive at repair LOL'
                                You would have won big bet from the so called 'PROFESSIONAL TECH'. Who is laughing now?
                                How many times now that we were told they are not panel problems?
                                don't put your ass between other talking, when i write to some one you don't have right to make comment or quote it, and from now on don't quote my name any more. end.
                                it seam you are still kids, don't worth any more to comment but at the last one you should know and keep it like ring at your ears .... electronic like ocean and you still swimming at baby beach.
                                I wonder what the 'QUOTE' button is for then.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  #36
                                  I wasn't around for that era unfortunately
                                    Kiriakos GR
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #38
                                      Lol im going to read that now didnt see it was updated
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        #39
                                        Jeez I think its just the translation between Eng and Germ which is causing this but its hard to make it all out
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #40
                                          Kiriakos GR
                                          Cheers budm its been a while since hes been mentioned in any threads etc.
                                          just saw his site
                                          http://www.ittsb.eu/
