PHILIPS 26 PFL3403/10 slow start up
  • domix
    • Jan 2014
    • 168
    • Slovenia
    i have this TV PHILIPS 26 PFL3403/10 and after a time when is turned off or unpluged i have some problem. When i power it on shows a slowly changing pattern of coloured vertical lines for about 10 minutes before the TV image appears. Than work perfect.
    I opened it to check if there are any blown caps, but they looks okey, i think. Any ideas how to remove that, because it is annoying to wait sometimes 10 min to tv turn on.
  • Diah
    • Feb 2013
    • 6437
    Re: PHILIPS 26 PFL3403/10 slow start up
    take photo to the power supply, its bad capacitor at the line to provide the main board with VDC
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Measure your power supply voltages and see if there is a problem.
      Service manual available for download:-
      • Diah
        • Feb 2013
        • 6437
        its not Voltage, he will find the 12 Volts, but this 12 V hat less currents where it should be 4A
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          PFL series suffer with bad secondary caps with out the obvious sign,gluxen caps if memory serves me right,replace on sight and test again,
          the 12v to the main could be low causing the lines,does the on screen menu show when the lines are there?,it could be a main board issue ,use a hair drier to heat the power board at first startup and note if the tv corrects itself faster,then try with the main board,which would indicate capacitor issue,though i think this is maybe a main board issue
          fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
          please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Check your 24V/6A, 12V/4A supplies and see if one of them is low and rising while warming up.
            • domix
              • Jan 2014
              • 168
              • Slovenia
              Here is the pics of supply board and caps, this tv is so not so easy to open like other where yuo just take down back cover :P
              • Diah
                • Feb 2013
                • 6437
                change all caps near the white socket photo 1
                • domix
                  • Jan 2014
                  • 168
                  • Slovenia
                  3x blue and 3x black ?
                  • Diah
                    • Feb 2013
                    • 6437
                    black you have 4 pieces
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Guys please ! This is a panel fault, what screen is used ? Guessing a V260B1 from Cmo ?
                      • domix
                        • Jan 2014
                        • 168
                        • Slovenia
                        yes, exactly this one
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Right knew it, panel fault. I will link a video to the repair of the panel.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Link to video on repair:
                            https://m.youtube.com/watch?v=mMo3NBGLwH0
                            • domix
                              • Jan 2014
                              • 168
                              • Slovenia
                              No it not panel fault, i place tv on stand and plug it in then need 10 min to scow picture, than can i turn on and off how many imes i want and it work, but if i plug the cable out and leave one time and than plug in back then need again 10 minutes to turn on
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                So then its a panel fault, panel fault can take ages to get working then it will work fine. But fine if you dont want to listen go ahead and waste your time checking voltages.
                                • Nick's Tvs
                                  • Jan 2014
                                  • 621
                                  Domix,
                                  Very easy way to figure this out, if you have checked ReeceyBurger123's youtube video at all, you will notice that he twists/bends the frame of the set a bit to cause small movements on the screen and frame. This causes the issue to either appear and or disappear dependent on how you move and twist the tv. Give that a try, if you can't get the issue to go away by doing that within the first 10 minutes and or make it reappear after 10 minutes of the screen being on, then go ahead and mess around with the power supply, but it is a very easy check and won't take more than a few minutes to try.
                                  Good luck
                                  • Diah
                                    • Feb 2013
                                    • 6437
                                    the 12 Volts should have 4A, any less than this value it will be delay to start.. and make noise at picture. wasting time and spend penny on caps better than starting with panel which it may broken at any little human mistake.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Its alright Diah is always correct no one else's EXPERIENCED view matters
                                      • Diah
                                        • Feb 2013
                                        • 6437
                                        Its alrigigh
                                        ReeceyBurger123 i have on hand new nick name for you hahahah ReeceyBurger123PANEL hahahah you are very expensive at repair LOL
                                        • Cornito
                                          Philips 50PUH6400 bad color and gosting / slow motion on one side
                                          by Cornito
                                          Hello Team,
                                          New issue on LCD panel where I need to find out the cause and the potential solution.
                                          This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                          I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                          When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                          I've checked voltages, no issue found comparing right and left side of the panel driver.
                                          VHG VGL CKV... are the sames on...
                                          03-08-2024, 06:41 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • gjlpereira
                                          MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                                          by gjlpereira
                                          Hi forum.
                                          I'm working on a macbook pro, model a1708, that is running extremely slow.
                                          Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                                          One other symptom of the problem with the machine is that the fan is always running at full speed.
                                          This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                                          09-06-2022, 07:45 PM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
