Rca led50b45rq
  • x_orange90_x
    • May 2015
    • 727
    Re: Rca led50b45rq
    Thank you! Just ordered a couple of them. I'll update you guys when i get them! Thanks again for all of your help!
    • x_orange90_x
      • May 2015
      • 727
      Re: Rca led50b45rq
      Diodes will be here Thursday. Before i put one in though, i need some reassurance from you experts about the AC connector that i accidentally shorted the other day. I already intend to fix the solder on it, but i would like to know if beforehand if i possibly damaged something else. I'm thinking best case scenario is the bad diode actually protected the rest of the circuitry from the short. What do the experts say?
      • vinceroger69
        • Mar 2012
        • 6714
        #63
        Re: Rca led50b45rq
        when you caused the short did the fuse blow on the power supply?
        • x_orange90_x
          • May 2015
          • 727
          Re: Rca led50b45rq
          Not really sure as it's not a glass tube type, it's a sealed black square fuse soldered to the board. However, i still has power going through because the standby light still comes on, and the screen still flashes when i try to power up (bad diode).
          • vinceroger69
            • Mar 2012
            • 6714
            #65
            Re: Rca led50b45rq
            that sounds fine then all you can do is wait untill the diode comes fit it and try the tv hopefully its all fine.
            • x_orange90_x
              • May 2015
              • 727
              Re: Rca led50b45rq
              The Diodes came early.. However, after installing a new one the EXACT same problem persists. I noticed there are two more diodes across the broad from D4 labeled D17A and D17B. Could one or both of these be bad?i
                Re: Rca led50b45rq
                So the PS-ON is present and you are still getting only around 160VDC between the two legs of the main filter cap?
                The other two diodes are the low Voltage diode in the secondary side of the power supply, they are not the same as that PFC diode.
                BTW, verify that the new diode did not short out again and properly installed.
                • x_orange90_x
                  • May 2015
                  • 727
                  Re: Rca led50b45rq
                  I will check voltages again tonight at PS-ON and at EC1 and EC1A. Is there anything else you want me to check besides these and the new diode? I only get about 20 minutes in a day to do this, so I'd like to get you as much information as you need.
                  Do you need me to check EC1- to PIN 12 of L6599 again?
                  Edit - just stumbled across this thread http://www.diyforums.net/rca-led50b4...ch-129823.html
                  The OP describes exactly what is happening with my set. Turned out to be bad backlights. I'm going to try what he did in post 15 and see if i get the same results as he did.
                    Re: Rca led50b45rq
                    You need to get the PFC Boosted Voltage working first before going further.
                    • x_orange90_x
                      • May 2015
                      • 727
                      Re: Rca led50b45rq
                      Ok. I'll check the diode and voltage at EC1 and EC1A tonight and let you know what i find out.
                      • x_orange90_x
                        • May 2015
                        • 727
                        Re: Rca led50b45rq
                        Just finished checking. I've got 171.8v on EC1 and 171.4v on EC1A. D4 diode reads 000 one direction and 461 in the other. I did the flashlight test and CAN see the menu on screen, so I'm pretty certain now its one or more bad LED backlights.
                          Re: Rca led50b45rq
                          So the PFC is not wroking, without that boosted Voltage for the LED driver power supply, that section is not going to work, bad LED is another problem if it is bad, so you may have more than one problem.
                          You have PS-ON but no boosted Voltage at this point which need to check furthEr to see if the PFC IC is getting the VCC to run or not.
                          • x_orange90_x
                            • May 2015
                            • 727
                            Re: Rca led50b45rq
                            What do i need to check now?
                            • x_orange90_x
                              • May 2015
                              • 727
                              Re: Rca led50b45rq
                              As poorly written as this is, it's relevant enough that i now understand what your trying to say. I'm only getting 171v at those caps when they SHOULD be much greater than that (the boosted voltage).. In turn not supplying enough voltage to the main board. This is why i can power on and see the menu with a flashlight ONLY when the LED connector is unplugged (because there's enough voltage to power the display without the LEDs trying to rob that power).
                              He said there's only two things between the rectifier and filter caps: The PFC IC and resistors. So the resistor/s may be bad, or the IC, correct? If so, which ones and how do i check them?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #75
                                Re: Rca led50b45rq
                                you need to find the pfc ic and carefully check the voltages whilst the tv is in the on condition (dont let your probes slip as this will cause damage if ic shorted)
                                find the pfc ic then the data sheet for it and see what the vcc voltage is.
                                • x_orange90_x
                                  • May 2015
                                  • 727
                                  Re: Rca led50b45rq
                                  Found the datasheet for L6599. In the attached picture, i need to check DC voltage been PIN 10 and 12, right? What would be the correct voltage if the IC is in good shape?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #77
                                    Re: Rca led50b45rq
                                    Im still learning but it looks like its operating voltage is between 8v and 16v so take all voltages of the ic as im sure budm will advise you further then.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #78
                                      Re: Rca led50b45rq
                                      See post #42
                                      • x_orange90_x
                                        • May 2015
                                        • 727
                                        Re: Rca led50b45rq
                                        Do i check with my black probe on PIN 10, or the EC1- leg?
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #80
                                          Re: Rca led50b45rq
                                          The EC1 negative leg would probably be easier and less risk of shorting pins on the IC accidentally.
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • jasonbay13
                                            Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                            by jasonbay13
                                            picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                            am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                            12-01-2023, 09:55 PM
