17pw26-4
+ More Options
Posts
  • charlierfc
    • Mar 2013
    • 93
    • scotland
    17pw26-4
    hi guys, i fixed this tv a while ago by replacing the bad capacitors.
    now tv wont fire backlight. though tv does turn on the back light is off
    i tested the backlight volts....its measuring 53 volts from psu?!
    after taking cover off inverter i saw one of the fuses was blown
    what would be causing the high volts to the inverter?
    ic? sorry, im very much a novice!
    any pointers would be appreciated.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17pw26-4
    Unhook the inverter and mainboard, plug the Tv in the Psu starts all voltage rails check the 24v output see if its persistent first I had one where the inverter done some damage to the Psu due to shorting the 24v rail. Also make sure you have a good chassis ground and measuring in DCV !
    Also can you upload images of the Tv please ?
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      Re: 17pw26-4
      still the same volts with boards unplugged
      ill up load some pics now
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 17pw26-4
        Hmm thats odd, are you using chassis ground and DCV ? If still out of whack your meter is dud because if the Psu did go that high and out of spec it would not work at all.
        • charlierfc
          • Mar 2013
          • 93
          • scotland
          Re: 17pw26-4
          was seriously starting to doubt my meter, i put another battery in but still the same. for some reason my pictures are not uploading
          • charlierfc
            • Mar 2013
            • 93
            • scotland
            Re: 17pw26-4
            pic? if it uploads
            • charlierfc
              • Mar 2013
              • 93
              • scotland
              Re: 17pw26-4
              more pics
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: 17pw26-4
                Your measuring it on ACV lol set it to DC and let us know what you read.
                • charlierfc
                  • Mar 2013
                  • 93
                  • scotland
                  Re: 17pw26-4
                  ahhhh wrong setting on multimeter! what a t*t.... ok so getting 24v to inverter, but one of the 125v fuse is out, how can this be blown with the 24v going in? must indicate another problem on the inverter... any ideas?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Re: 17pw26-4
                    And bad news too I know the fault with your inverter not an easy fix Will link my thread about the same one.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Re: 17pw26-4
                      Plug your black lead into the port marked COM and measure again.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Re: 17pw26-4
                        Repair of this inverter, also your Psu will need some caps changing before it fails next too.
                        https://www.badcaps.net/forum/showth...=Ssi_400_14a01
                        • charlierfc
                          • Mar 2013
                          • 93
                          • scotland
                          Re: 17pw26-4
                          any point in replace F102 on the inverter? chances are it will instantly POP?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Re: 17pw26-4
                            Heres a Pw26 I repcapped, I really urge you to replace the caps on it as they wont be long off failing, replace them with brand new high quality capacitors.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Re: 17pw26-4
                              Yes read my thread I linked, if the fets blow the fuse will blow as well in most cases.
                              • charlierfc
                                • Mar 2013
                                • 93
                                • scotland
                                Re: 17pw26-4
                                so.....ebay for a new inverter..... i can replace caps ect...fets naaaa
                                thank you for all your help it is much appreciated.
                                • charlierfc
                                  • Mar 2013
                                  • 93
                                  • scotland
                                  Re: 17pw26-4
                                  http://www.ebay.co.uk/itm/4614-Inver...IAAOSwHaBWiobD
                                  would this pack fix the inverter? at only 3 quid.. worth a shot...they inverters are hard to get
                                  • michael dranfield
                                    • Jan 2016
                                    • 232
                                    • England
                                    Re: 17pw26-4
                                    Most common fault on the inverter is the FET s going short part is A04614 .
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Re: 17pw26-4
                                      I have used this company before never had a issue with them some good prices too so for that price certainly worth a try.
                                      • charlierfc
                                        • Mar 2013
                                        • 93
                                        • scotland
                                        Re: 17pw26-4
                                        how do you figure out the faulty ones? the top fuse is blown, so i assume its the top of the board, how do you test these?
                                        • x_orange90_x
                                          by x_orange90_x
                                          01-29-2025, 09:24 PM
                                        • supermattch
                                          HP 15dy-2021nr wont power on mystery volts
                                          by supermattch
                                          Hi everyone.
                                          I am diagnosing my personal laptop, because it wont power on and no leds light up.
                                          At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
                                          Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
                                          Yesterday, 12:13 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
