17pw26-4
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17pw26-4
    You know how you tested the fuse ? Your meter beeps if its good, same with a shorted component if a part is shorted your meter will beep when you probe the legs of a device. To test the fets go up and down the board in diode mode and probe the pins of each fet.
    • charlierfc
      • Mar 2013
      • 93
      • scotland
      Re: 17pw26-4
      thanks reeceyburger. will give that a try, need to head out now, i noticed it was a bit discoloured underside near the ones at the top, so ill guess thats the ones to start with
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: 17pw26-4
        Glad to help, normally the top ones that blow hopefully they did not take out the resistors too if so not going to be easy.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Re: 17pw26-4
          i wonder if its worth also replacing that controller ic SEM2017 Ic as in reece thread post 82 it may save more parts blowing and wasting money etc
          https://www.badcaps.net/forum/showth...=Ssi_400_14a01
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: 17pw26-4
            Probably is tbh Vince, mine was sending a crazy Vcc voltage to the fets causing them to blow when ever it did meaning the controller had failed intermittently.
            • u666sa
              HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
              by u666sa
              Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
              Platform: ipa32 la-m024p rev 1b
              Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
              I found a short on the other side:
              10-04-2025, 05:03 PM
            • x_orange90_x
              Vizio E55-E1 bad backlights or bad inverter?
              by x_orange90_x
              I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
              I don't know how exactly to test the inverter itself. Is it...
              01-29-2025, 09:24 PM
            • supermattch
              HP 15dy-2021nr wont power on mystery volts
              by supermattch
              Hi everyone.
              I am diagnosing my personal laptop, because it wont power on and no leds light up.
              At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
              Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
              09-23-2025, 12:13 PM
            • MisterAIL
              PS5 digital / No Power / No Beep / Good power supply
              by MisterAIL
              Brought a non functionnal PS5. Apparently only a bad PSU...
              No beep, nothing.
              After some tests i found this :
              - PSU is fine (12 volts stable)
              - 12 volts line is shorted
              - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
              - By the way, nothing change. No signal, no power, no beep.
              Mesuring all rails with my workbench psu (12 volts input)
              - 0.00 amp drawing
              - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
              03-12-2024, 03:24 PM
            • Gentian
              APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
              by Gentian
              I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
              It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
              03-06-2023, 07:07 AM
