Sharp LC-52D85U Won't turn on
  • birdboy385
    • Nov 2015
    • 145
    Re: Sharp LC-52D85U Won't turn on
    Slave board
    775
    778
    780
    778
    785
    783
    786
    785
    785
    785
    • birdboy385
      • Nov 2015
      • 145
      The other board's were all around 770
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        My apology for the confusion Birdboy385. I should have been clearer with the request. I know the image is small but the intention was for you to check the resistance of each transformer to see if it matched the value as shown in the picture between those pins.
        • birdboy385
          • Nov 2015
          • 145
          no problem lol. Well it would appear that none of them are reading the 1.3K OHms. Idk what them mostly reading around 775 means. Then there is the one that gives off no reading.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            It does look as though one of them is faulty so hopefully you have found the fault.
            • birdboy385
              • Nov 2015
              • 145
              I wasn't sure if the others reading only around 775 instead of around 1.3K is a problem or if that's not as much an issue. Basically my question is are they all relatively bad at 775 or just the one i found.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #47
                The picture was taken off the internet so I'm not certain how accurate the 1.3K is for the transformer.
                However since all the transformers measurements were very similar except for one which you said gave no reading then I would suspect that it is only that one that needs to be replaced.
                • bangjay
                  • Apr 2016
                  • 23
                  • indonesia
                  #48
                  I had problems with Sharp LCD TV type LC-32L50M, current conditions, if I turn it on the LED indicator green and red flashing alternately several times, after that only a red LED that flashes 5x, when the red flashing, all the buttons do not work.
                  according to my analysis, this tv failed to start because of a protected, I've tried to enter service mode with Vol - and TV / Video and plug the power, but the tv screen was still dark, there is no display anything on the screen. and LED indicators remain blinking as described above.
                  I've done a test voltage, everything is normal,
                  1. BU1.8V ok
                  2. BU2.5V oK
                  3. BU3.3V OK
                  4. BU5V OK
                  5. BU12V OK
                  6. DC 14V / 24V OK
                  anyone can help me? whether about the problem?
                    You should start a new thread with make and model and picture so it will not confuse other people.
                    • bangjay
                      • Apr 2016
                      • 23
                      • indonesia
                      #50
                      thank you,
                      • birdboy385
                        • Nov 2015
                        • 145
                        Ok so update. I replaced the transformer and the tv seemed to be ok. I held the power button the light went orange. I turned it on and it came on like normal. Then i went to factory reset it and i'm getting a new error code that i can't bypass. It's alternating between blinking power and power + opc alternatively. I'm going to look in the manual to see if i can lock it down. Anyone know off hand what it might be?
                        • birdboy385
                          • Nov 2015
                          • 145
                          It's difficult to read the error code with he manual but I can say that it alternates between blinking 1 power and 1 power + opc. Trying the Channel down / Volume down + input reset doesn't work. If i unplug the tv and plug it back in it blinks power infinitely like it did before.
                          • birdboy385
                            • Nov 2015
                            • 145
                            ok new update. I let the tv sit for awhile unplugged then went back to it a few hours later. I managed to get it completely reset andf it seems to be working fine. Not sure why it was flashing those codes before but it seems fine now. I will keep you guys updated.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #54
                              Sound like good news.
                              • birdboy385
                                • Nov 2015
                                • 145
                                Thus far I've encountered no issues. I'd like to take this opportunity to thank everyone who contributed to help me not just for this tv but for everyone on these forums who are there to help. Is there a way to donate to the cause? Once i get this tv sold i'd like to make a contribution.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #56
                                  I think the best contribution to the Forum is the offer of help to others as and when you can although there is a Donate button at the bottom of the page.
                                  • nobbnobb1
                                    • Nov 2019
                                    • 76
                                    Sorry to bump an old thread but I am also trying to diagnose a no picture/start up issue with this TV. The green Power LED just has a continuous blink. Similar to what was mentioned on the last page, when I try to enter the adjustment mode (holding volume down & input buttons while applying power), there is a brief blue screen that lights up (backlight powers up briefly), then it goes back to blinking with the power supply seemingly shut off.
                                    I am reviewing the service manual () and there appears to not be any references to what the voltages on the power supply board should be? The PCB does not appear to label all the voltages clearly.
                                    Any thoughts?
                                    EDIT: I was able to force the TV to turn on. Inverter seems to attempt to strike the backlight briefly but then it goes off. While power button stays lit, I tested various points on the power supply and got a range from 3.3, 5, and 12V. Once again, things aren't labelled properly on the PCB so I'm having trouble telling what the voltages should be.
                                      Did you read post 36 and later and check the transformer winding resistance?
                                      • nobbnobb1
                                        • Nov 2019
                                        • 76
                                        Doh! Turns out I was measuring the wrongs pins. The arrows in the image on post #36 should actually be reversed. I think I found the bad transformer now (just one on the master board)...will try to replace this part and see what happens.
                                        Did further testing and I'm fairly confident the power supply board is good, even if I couldn't find reference material on the proper voltages.
                                        I also tried the hairdryer trick on the capacitors on the inverter board, no change.
                                        Will report back when I get this transformer changed out!
                                        EDIT: It doesn't seem I can source the transformer with part number 2874025500 anywhere. Would there be a way to lookup a compatible part? Or perhaps someone here diagnosing these boards has an extra they could sell?
                                        • nomoresonys
                                          • 12206
                                          • U.S.
                                          #60
                                          Something there, the first one is just a transformer, it's about as much as a whole board tho, there's a little test they included on the first one: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
                                          • JunkmanJimbo
                                            Sharp lc-55p6000u won't turn on
                                            by JunkmanJimbo
                                            Sharp lc-55p6000u won't turn on. The standby light is on but nothing happens when the power button on the tv or remote is pushed. I'm thinking this is a main board issue but they are expensive. I was wondering if anybody could tell me how to repair the main board I have. There is a repair service on Ebay but they're also expensive. Since there's a repair service for this main board I was hoping somebody could help me with the repair. The main board part number is 221999. Thanks!!...
                                            09-28-2024, 12:56 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • Egidio85
                                            SHARP LC-40LE814E does not turn on 2 flashes
                                            by Egidio85
                                            hi, I have a sharp tv model LC-40LE814E with DPS-126CP-1 A power supply.
                                            the tv initially turned on, displayed the image for 10 seconds and then turned off. so in a loop until the power was cut off.
                                            reading the classic optocoupler problem I changed the mounted cosmos with SHARP PC817 recovered from other boards.
                                            now the TV turns on for 1-2 seconds and turns off giving 2 flashes in the front LED.
                                            to avoid banging too much I preferred to take an identical tested and working card (or so the supplier says)
                                            07-21-2023, 11:49 AM
                                          • Mitike
                                            SHARP LC-70UC30U starts up with RESET then turn off and blink 1 LONG 1 SHORT
                                            by Mitike
                                            Hello guys,
                                            I have SHARP LC-70UC30U which won't turn on and the stand by LED blinks the 1 LONG 1 SHORT error
                                            According to other sharp SM-s it is lamp error (I can't find SM for this model)
                                            And yes I checked other blink error threads on the forum about other Sharp models and still can't make it work.
                                            If I unplug the set and hold the POWER and INPUT buttons while I'm plug it back the set fires up and shows sharp logo and after that the Android logo and turn itself off again and starts the blinking and wont turn on again except if I do the RESET procedure again....
                                            02-16-2020, 08:11 PM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
