Another LC-80LE632U 2-5 thread
  • jacksnife
    • Jan 2016
    • 26
    • usa
    I picked up this TV hoping I might get lucky. I read all the 2-5 error code threads I could find, as well as some 1-1 and 2-3 error code threads and TIP-1541.
    I do have some hope because it appears the T-con is shorting out the 12V lines. If I disconnect the 4 pin connector I have 12V sitting there (until the PS clicks and goes into shutdown). If during this time I connect the cable back to the Tcon the voltage drops to near 0V. So according to TIP1541 I should replace the Tcon board.
    I don't mind buying all new boards, but I don't want to throw any good money at it without knowing the panel is good. I can't see any visible signs of damage... but I also do not get any backlight flashing or any sign of life coming from the screen. Is there anything I can do to trick the backlight on? Or any other things I can try that might make me feel confident the screen is ok?
  • jacksnife
    • Jan 2016
    • 26
    • usa
    Re: Another LC-80LE632U 2-5 thread
    I should probably mention I followed Tip1541 by removing the ribbon cables... there was no back light and the 2-5 code is still present.
    • sordids999
      • May 2013
      • 2161
      Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
      • jacksnife
        • Jan 2016
        • 26
        • usa
        • jacksnife
          • Jan 2016
          • 26
          • usa
          Right now I would like to figure out how to turn on the backlight power... or maybe measure voltage at the pins to see if it's just plain dead? I can borrow an o-scope if needed. I need to try to see if there is any damage to the screen before I really put some time in on it. I looked at it in the sun and couldn't see anything obvious.
          Are these backlights just simple LED's with constant voltage? Or is brightness controlled by duty cycle?
          • freakaftr8
            • Oct 2012
            • 3743
            These sharp 80-inch panels are built very closely in relation to the 70-inch panels that are failure prone. You could attempt to try to power up the panel with one driver cable disconnected at a time at the secon and see if the TV comes up using the reset code Vol-+ and ch- while plugging it in. Once the backlight attempt to power on release all buttons.
            • jacksnife
              • Jan 2016
              • 26
              • usa
              Ok, holding all three buttons stops it from going to the 2-5 blink state. But I never see or hear any sign of a backlight.
              I have .7V on the 12V pin of PD, then disconnect the 4-pin PL connector on the tcon board and the 12VDC comes back. i.e. the Tcon is either shorting out the 12VDC, or the power supply no longer can supply enough current to turn it on so the volts drop to near 0.
              • freakaftr8
                • Oct 2012
                • 3743
                okay now disconnect both white flat ribbon cables going from the tcon to the panel in try the restart code again
                • jacksnife
                  • Jan 2016
                  • 26
                  • usa
                  Please correct me if I'm wrong, but in my mind the Backlight and the LCD Panel are two completely different animals. If the display was dead it wouldn't kill the backlight (and vice-versa) would it?
                  So right now I have the V light on constant (no error code), I have the Tcon 4-pin disconnected and 12VDC is up. Shouldn't I be able to read some voltage on the backlight connectors?
                  • jacksnife
                    • Jan 2016
                    • 26
                    • usa
                    ok sorry I jumped the gun... I'll go do that.
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Well you are correct they are two different systems however the t-con panel voltage is the first that the mainboard reads to make sure that all systems go if that system shorts out you will get no back lights. If it's a panel failure you will normally get 2- 5 error code
                      A 1-1 error is related to led backlight failures in Sharp
                      • jacksnife
                        • Jan 2016
                        • 26
                        • usa
                        Same result, .7VDC sitting on the 12VDC with PL connected.
                        Also while I was there I decided to probe on the bank of transistors. I'm guessing they are for powering up the backlight and that there should be a rail voltage sitting on the Collector, Base being pulsed, and the actual LED sitting on the Emitter. 0VDC on all of them.
                        • jacksnife
                          • Jan 2016
                          • 26
                          • usa
                          Ok, thanks for the help...
                          So considering I have the display ribbon cables disconnected I can assume the display itself is no longer influencing the fact I still have a shorted 12V power at the Tcon. It doesn't mean the display is good... but I can't say for certain it is bad until I get a known good Tcon board, correct?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Possibly. You could try removing the power source to tcon and try reset code and probe tcon 12v output voltages and see if they briefly come up.
                            • jacksnife
                              • Jan 2016
                              • 26
                              • usa
                              Ok, I assume the Tcon power source is the 4 pin connector (PL)? When it is disconnected there is 12V coming from the power supply sitting at the disconnected 4 pin connector. When I connect the 4 pin connector back to the Tcon board there is 0.7V.
                              "probe tcon 12v output voltages and see if they briefly come up" <- Are you referring to the power supply 12V output? Or does the Tcon also have a 12V output?
                              Man, schematics sure would be nice! If I just had a power supply schematic I know I could figure out a way to power up those backlight led's... without a Tcon or a main board even connected. I'd bet the main board is just sending discrete signals to it.
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                I would have thought that if the Tcon was taking down the 12v line that it would have blown the onboard fuse on the Tcon. Can you load up the 12V line when disconnected from the Tcon with resistors and check it is supplying reasonable current. Power supply problem?
                                Regards
                                • jacksnife
                                  • Jan 2016
                                  • 26
                                  • usa
                                  I was thinking the same thing... the Tcon board measures about 4 ohms between the +12V pin and gnd and is dropping the voltage to 0.7V. Is my thinking right for that 12V PS to only be sourcing 175mA?
                                  I wouldn't mind spending a few bucks to get a spare, but i'd rather do everything I can to determine if the screen is good/bad before ordering one. I suppose the only thing I can do is visually look for physical damage, so this is why I want to rig the backlights to come on.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    you would be better off tracking / checking ALL the voltages "labeled" on the power supply. I doubt that the tcon is bad. More than likely you lost a section of the power supply... further check all diodes on the power supply as some have found ones to have been "broken". Once replaced, they are happy.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      I'd agree with budwich and take a real good look at the power supply. Check the fuse rating of the fuse on the Tcon and that should tell you what it expects in terms of current.
                                        It this your exact power supply-LED driver board?
                                        Sharp RUNTKA903WJN1 Power Supply LED Board.
                                        http://www.shopjimmy.com/sharp-runtk...pply-unit.htm#
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          by sam_sam_sam
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • netgearnetgear
                                          TCL 43S423 TCON OR PANEL FAULTY???
                                          by netgearnetgear
                                          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                          08-20-2025, 06:04 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
