troubleshooting TV SMPS sequence
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8146
    Re: troubleshooting TV SMPS sequence
    I am not sure what to think anymore soon. We covered almost everything in between.
    Switching over to Win10 isn't helping much either... AAAAARRRRGGHH!
    • ilikesteel
      • Jul 2012
      • 284
      • usa
      #102
      Budm, CapLeaker,
      Ok, we got some real results now!
      removed copper coil L6. did a resistance measurement of it out of circuit. It measures .1 on the 200 ohm scale.
      then fired up PS, fully connected minus L6 and got +16.70V across CS32. I didn't mess with CS55 at all .....yet.
      resistors RS14 is marked 3302 = 33K (measured 2.20K on 20K scale)
      resistor RS19 is marked 1602 = 16K (measured 2.250K on 20K scale)
      tell me we're closer than ever!
      Thanks,
      ilikesteel
        Well, what I have you done is to isolate the second Pi filter from the circuit to see if the Voltage will go back up and it does so now we need to find what is loading down the 12V section, what ever it is it is after the inductor LS6.
        What you need to disconnect next is the 12V output wire that goes to what ever the load is first then put LS6 inductor back in place and power it up again to see if you will have DCV on cap CS8.
        • ilikesteel
          • Jul 2012
          • 284
          • usa
          #104
          Budm,CapLeaker
          Please explain to me using the schematic what you want me to remove after L6. looks like only resistors and capacitors are left in circuit. Caps are all new, Panasonic FR series caps. do I just remove the next resistor closest to the L6? sorry I'm confused.
          ilikesteel
            There must be a wire that is connected to that 12V output.If you look at the diagram you will see Inductor LS6 with '2' label on the right and you see that +12V, that +12V has to go out from the power supply board through a connector some where on the board which then goes out to load outside the power supply to feed the load, we need to disconnect that 12V wire that feeds the load.
            • budwich
              • Jul 2015
              • 3097
              hopefully not to confuse, but just measure the resistance of the circuit from the "missing L6" outward with everything connected BUT NOT powered. What does it read?
              • ilikesteel
                • Jul 2012
                • 284
                • usa
                #107
                Budm, CapLeaker,
                Got it! the +12 leaves the board on Conn3 on Pin 1 (red wire). Conn3 connector connects to the scaler board on BP103 connector. I can remove the red wire from Conn3 pin1. I did that earlier in the troubleshooting phase.
                I'll remove the wire, resolder L6 back in the board and take a measurement at the Pin 1 on the PS connector for the +12v, which is now isolated from the scaler board.
                Thanks,
                ilikesteel
                  Read post 10 and later, what his reports does not make sense, it should show 750 ohms or less, that is why I am starting it over by isolating the path a bit at a time.
                  • budwich
                    • Jul 2015
                    • 3097
                    no problem. It does seem strange. I will back track and be quiet... :-)
                    having said that, it seems to me that the problem is in the feedback / control circuit based on the output measurements. quiet now... :-)
                      Oh no problem chiming in, sometime wrong readings or wrong info can put us into tail chasing mode that is why I kept away from the thread for a while to see what develops.
                      It is very confusing to have one common transformer that has two output windings, one for 12V and one for 24V, the 12V is only showing a few Volts of out put, but the 24V is putting out 20V.
                      The regulation feedback is sensing both Voltages for regulation, if the percentage of Voltage drops should be about the same but they are not, to have 12V with 5.5A output current capability power supply drops down to a Volt or so something has to burn up pretty good. the 24V is capable of 6A.
                      Something is not making sense at all.
                      • ilikesteel
                        • Jul 2012
                        • 284
                        • usa
                        #111
                        Budm, CapLeaker, BunWich,
                        OK, here we go.
                        Reinstalled the L6 inductor. removed the red wire from Pin 1 of the PS connector Conn3. all other wires are are connected. The +12 is now isolated from the TV.
                        I measured 10.3 to 11.1V, again, watching the meter you can see it cycling up to 11.1 and then back down to 10.3, then back up to 11.1V and so forth.
                        I measured the +24 for the hell of it and it was 21.0V to 22.6V, again exhibiting the same cycling on the meter between 21.0v and 22.6v. you can watch the tenths of volts increasing and decreasing between the voltages.
                        The last two times I did this I got the very small readings of 1-2V.
                        almost like a cap was charging but not quite fast and high enough to maintain a solid reading. however, the reading is still below the +12 that should be present at the Pin 1 output pin on the PS for the +12 without connections.
                        anxious!!!
                        Thanks guys,
                        ilikesteel
                          OK, what happen if you also disconnect the 24V output wire?
                          • budwich
                            • Jul 2015
                            • 3097
                            Re-read things. Wow lots of fun. :-(
                            I think the one point that stands out significantly is the "light bulb test". If I understand what was hooked up, I don't think that the bulbs should have been blinking. Surely, the DC regardless of level can't that bad. Its either a "wave form intrusion" or some form of timing circuit shunting down.
                            Is it possible that there is some form of "leakage" between the AC and DC sides in terms of coupling capacitor?
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8146
                              We've been there and done that test before.
                              No the bulbs should not be blinking.
                              You mean a leaking snubber cap? I've never seen them leak, only go up in smoke.
                              • ilikesteel
                                • Jul 2012
                                • 284
                                • usa
                                #115
                                CapLeaker-Budm-BudWich,
                                ok, here goes.
                                removed two wires for the +24V, Pins 5 and 6. one goes to scaler, and the other I think I read it was the LCD panel. so +12 and +24 generated is not leaving the PS. There's no Load on the PS for those voltages.
                                First, for what it's worth. I noticed that when the TV has been off a long time and I want to fire it up for testing; It wouldn't power on right away.
                                so this morning when I powered the TV on, I measured the 5V STDBY on the small 1W board. It was about 3.8V and climbing slowly. it took between 2-3 minutes for the 5V to climb and stabilize at 5.36V.
                                then I powered TV on and it came on for me to check voltages.
                                the +12 measured 10.4v - 11.12v, same cycling as before.
                                the +24 measured 20.1v - 22.2v, same cycling as before.
                                I checked the 5V STDBY again and it dropped to 5.19V steady.
                                also measured the Pin 7 P-On/P-off and it was 3.23V steady.
                                I hope this is useful info!!
                                Thanks for your unyielding patience.
                                ilikesteel
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #116
                                  slowly climbing 5volt standby maybe its a bad start up capacitor?
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    Yes that's the testing that I was referring. Basically, your / that test is the equivalent of a poor man's scope.
                                    Was the blinking measured... how many "blinks" per minute were there (count for 15 seconds and multiply)... hopefully its not something like 60... :-(.
                                    Further, sorry for not reading everything very carefully, but my new question is "what was the original problem"? ie. What voltages were measured before ANY capacitors were replaced??? Basically, why were the capacitors replaced? Also, have the capacitors been rechecked to ensure that their polarities have been installed correctly?
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      Interesting observations on the 5v. Question about your "setup"... when you say, "when the set has not been ON for a long period of time"... has it actually been plugged in during the time or been unplugged, then plugged in, then the "start up" attempted?
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8146
                                        Capacitors were replaced on both rails with Panasonic FM. The original problem is that the TV can't power up, since the 12/24V isn't working proper. With the measurement of 2V on 12V rail and 20 something Volt on the 24V rail, I thought there is a short on the 12V rail. Then the hunt began... At one point he had only 1 - 2 Volts on both voltage rails. So I thought the PFC isn't working, but actually it did (measured 360VDC).
                                        Got no idea how fast that lamp trick was blinking.
                                        ilikesteel: change the caps on that little 1W / STBY voltage board. See that you get stable power.
                                        • ilikesteel
                                          • Jul 2012
                                          • 284
                                          • usa
                                          #120
                                          CapLeaker, Budm, BudWich,
                                          just to recap. MY original problem was TV would not power all the way up, no backlights, no video, no sound. red LED would be on without powering up. after powering on, red LED turns to Green and blinks continuously. I first checked the 5V STNDBY PS (small board upper right corner). The 5V STNDBY was there 5.36v.
                                          I then checked PS output voltages. the +12v read about 1.9 V and the +24 rail measured about 19.0 to 21.0 V.
                                          So I arbitrarily decided to change the 6 caps in the output section. I replaced the caps with Panasonic FR series. tried the voltage measurements again and got the same results as above.
                                          There was a suggestion to check the main cap.
                                          the main cap was 360v with TV powered on.
                                          then I removed the PS connections to the scaler board, had to jump the 5V VSB to the PS through a 1K resistor to get PS to come on. I still measured low voltage.
                                          I then jury rigged auto lamps # 89 lamps, on across +12 rail and two in series across +24V rail. the lamps blinked at a steady pace on and off. I can't remember what the rate of blinking was.
                                          Then it was suggested to check everything in and around the TDA 16888 IC and components connected to it. I checked many resistors, diodes, and capacitors. I did find one OPEN resistor, R36 a 510K SMD connected to pin 18 of TDA 16888. made more checks.
                                          I found a SMD 510K resistor and soldered it in place for R36. checked voltages again, again, voltages low. it was suggested to remove inductor L6 and measure across cap CS32.
                                          Did that and got higher voltages readings. +12 was at 10.3v - 11.1v, and the +24 was 21.0v - 22.6v. voltages were oscillating between the readings I just said.
                                          reinstalled L6, removed two wires from PS for 24V, and 1 wire from PS for the +12v. installed connections back from PS to scaler board, however, +12 and +24 have been isolated from the TV.
                                          for what it's worth. I noticed that when the TV has been off a long time (unplugged from power outlet) and I want to fire it up for testing; It wouldn't power on right away.
                                          so this morning when I connected TV to outlet and powered the TV on, I measured the 5V STDBY on the small 1W board. It was about 3.8V and climbing slowly. it took between 2-3 minutes for the 5V to climb and stabilize at 5.36V
                                          after I was done testing I measure the 5V VSB again and it was steady at
                                          5.19v.
                                          That's what my memory says!!! That's where I'm at.
                                          so with no load on +12 and +24 on the PS, the +12 measured 10.4v - 11.12v, same cycling as before.
                                          thanks for the responses,
                                          ilikesteel
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • madan1
                                            Troubleshooting half-bridge smps
                                            by madan1
                                            Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
                                            The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
                                            Both mosfets were tested outside circuit with a component tester and seem to be fine.
                                            With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
                                            So I guess the mosfet driver is faulty?
                                            01-23-2025, 06:05 AM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • dkneyle
                                            Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                            by dkneyle
                                            This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                            Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                            02-01-2022, 02:08 AM
                                          • ShadowAi
                                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                            by ShadowAi
                                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                            03-15-2024, 10:46 AM
